Gentoo kaj se dogaja?
Shaman ::
Ko emergam kak program se pojavlja sledeca napaka " error 28: No space left on device" in seveda se zadeva ustavi.
Kje ni prostora na kateri napravi????????
Ko pozenem "df" mi javi da je disk zadeden le 14%!! Particije so enake velikosti kot primer v handbook.
Neki sem googlal pa mi se vedno nc jasno ni. Tam omenja /var/tmp vendar se ga ze pocistil pa vedno isto se mi ponavlja???
A je mel kdo ze tak problem prosim za nasvet, kaj mi je storiti??
Ce kaj pomaga Gentoo, kernel 2.4.26-gentoo-r9.
Hvala za pomoc.
Naredi
# emerge info
# df -h
in postaj rezultate. Drugače lahko le ugibam da imaš polno root particijo.
Shaman ::
Portage 2.0.51-r2 (default-linux/x86/2004.3, gcc-3.3.4, glibc-2.3.4.20040808-r1, 2.4.26-gentoo-r9 i686)
System uname: 2.4.26-gentoo-r9 i686 Intel(R) Celeron™ CPU 1300MHz
Gentoo Base System version 1.4.16
Autoconf: sys-devel/autoconf-2.59-r5
Automake: sys-devel/automake-1.8.5-r1
Binutils: sys-devel/binutils-2.14.90.0.8-r1
Headers: sys-kernel/linux-headers-2.4.21-r1
Libtools: sys-devel/libtool-1.5.2-r7
ACCEPT_KEYWORDS="x86"
AUTOCLEAN="yes"
CFLAGS="-O2 -mcpu=i686 -fomit-frame-pointer"
CHOST="i386-pc-linux-gnu"
COMPILER=""
CONFIG_PROTECT="/etc /usr/X11R6/lib/X11/xkb /usr/kde/2/share/config /usr/kde/3.3/env /usr/kde/3.3/share/config /usr/kde/3.3/shutdown /usr/kde/3/share/config /usr/share/config /var/qmail/control"
CONFIG_PROTECT_MASK="/etc/gconf /etc/terminfo /etc/env.d"
CXXFLAGS="-O2 -mcpu=i686 -fomit-frame-pointer"
DISTDIR="/usr/portage/distfiles"
FEATURES="autoaddcvs autoconfig ccache distlocks sandbox sfperms"
GENTOO_MIRRORS="http://gentoo.osuosl.org http://distro.ibiblio.org/pub/Linux/dis...
MAKEOPTS="-j2"
PKGDIR="/usr/portage/packages"
PORTAGE_TMPDIR="/var/tmp"
PORTDIR="/usr/portage"
PORTDIR_OVERLAY=""
SYNC="rsync://rsync.europe.gentoo.org/gentoo-portage"
USE="x86 X apm arts avi berkdb bitmap-fonts cdr crypt cups encode esd f77 fam flac font-server foomaticdb fortran gdbm gif gnome gpm gtk gtk2 imagemagick imlib ipv6 jpeg kde libg++ libwww mad mikmod motif mpeg ncurses nls oggvorbis opengl oss pam pdflib perl png python qt quicktime readline sdl spell ssl svga tcpd tiff truetype truetype-fonts type1-fonts xml2 xmms xv zlib"
Filesystem Size Used Avail Use% Mounted on
/dev/hda3 37G 4.6G 30G 14% /
none 252M 0 252M 0% /dev/shm
Hmm... če je kle napaka je ne vidim. Razen tega da maš mal čudne CFLAGS pa CHOST.:|
Gentoo forum zna bit uporabna zadeva. Povej če ti kaj pomaga.
zee ::
poskusi z: emerge sync
nato pa: emerge (program)
zee
BigWhale ::
Napisi se, kaj ti vrne mount
Shaman ::
# mount
/dev/hda3 on / type xfs (rw,noatime)
none on /dev type devfs (rw)
none on /proc type proc (rw)
none on /dev/shm type tmpfs (rw)
moj_nick ::
Kateri program emerge-aš?
110111001001010001010000
Brane2 ::
Čakaj malo.
Kot je videt, ti boot particije sploh nimaš in imaš vse skupaj v root.
Zakaj imaš opcijo "noatime" ? Ta je mogoče dobra za boot particijo ali kaj podobnega, lahko pa je vir tvojh problemov, ker portage hoče vedet, kdaj je bilo kaj spremenjeno...
Brane sej /boot se sploh ne mounta po defaultu v Gentoo. Morš na roke. Zna pa bit noatime.
Brane2 ::
Ja, to sem pozabil. Saj zato pa ima hda3, če je delal po priročniku. Na prvo particijo je dal /boot, druga je swap in tretja je root. Silly me... :8)
/dev/hda6 on / type reiserfs (rw,noatime)
none on /sys type sysfs (rw)
none on /dev/pts type devpts (rw)
/dev/hda3 on /home/media type ext3 (rw,noexec,nosuid,nodev)
/dev/hda1 on /home/portage type reiserfs (rw,noatime)
none on /proc/bus/usb type usbfs (rw)
noatime očitno ne bo kriv :|
Brane2 ::
NIsem ziher. Ni nujno da reiser upošteva to opcijo na enak način kot XFS.
Če tip sploh ima XFS gor in mu ni ta opcija ostala "po defaultu"... :\
Tudi tu bi znala biti napaka, da ima naveden XFS, v bistvu pa je ext3 ali reiser.
Tud jaz sem enkrat to pozabu, pa se je škatla čudno obnašala. Bogve zakaj... :D
Preverit s fdisk oz. cfdisk torej.
BigWhale ::
Kaj ko bi kdo prebral man page? ;)
noatime
Do not update inode access times on this file system
(e.g, for faster access on the news spool to speed up
news servers).
In pa za xfs
noatime
Access timestamps are not updated when a file is read.
OT:
Na žalost mi # man ne dela :8)
# man sex
x T latin1
x res 240 24 40
x init
F -
p1
x font 1 R
f1
s10
V40
H0
md
DFd
tSEX(6)
h600
itd, itd... po netu se mi pa ne da iskat. Sm prelen. |O
Shaman ::
No mislim, da sem nasel problem in sicer v superblock-ih. (nekonsistenten disk)
Tezavo se odpravil sumim pa, da je do tega prislo zaradi nepravilnega shutdown.
Zanima me kako vi izvedete shutdown?
Jaz sem do sedaj z ukazom # shutdown now. Zadeva pa se je ustavla pri
saving random seed in tam je konc???
Brane2 ::
Ja, tudi meni se tam ustavi in zato uporabljam "reboot". Ni se mi dalo iskat sedaj p skriptah, da bi se zaj* še s tem.
Anyway, ni blo videt do sedaj prevelike škode zaradi tega. Pal stvar je najprej remountala diske read-only, nato pa ni mogla sejvat random seeda. Zajeb u koracima ampak nič tragičnega. Je pa nadležno, koliko časa je že ta bug gor, pa še ni odpravljen...
  • spremenil: Brane2 ()
Simulacrum ::
Hejla, da ne bom odpiral nove teme, bom kar tu povprasal.
Kaksna je razlika pri zaustavitvi sistema z ukazom shutdown now ter poweroff (morda sem se kaksnega pozabil...)? Le v tem, da shutdown now ne deluje? :\
Lep pozdrav.
Simulacrum
64202 ::
Ocitno gentoo dev-i ne ugasajo kist :).
BigWhale ::
64202:
Ja, jaz sem glih hotel rect, da nevem kako sem do sedaj jaz to pocel, najbrz se nisem ugasnil. Ce pa ze, pa ponavadi naredim reboot in potem ugasnem med 'stetjem memorije'.
Dokler nisem imel kdm (en mesec nazaj) sem brez problema ugasal z halt. Zdaj to zame dela kdm (logout - turn off).
  • spremenil: Poldi112 ()
borchi ::
hmm, na niti eni gentoo kišti nisem imel problema z:
# shutdown -h now
l'jga
nicjasno ::
meni je "poweroff" ali pa "killall" vredi deloval
www.nicjasno.com | www.vsejasno.com
CaqKa ::
mene zanima na vsake koliko časa poženete emerge world?
Jaz osebno 2-3x na mesec. Ravnokar laufa. 17 paketkov.
Brane2 ::
Jaz tudi nekako tako. No, odvisno od mašine. Na svoji delovni postaji že, server mogoče 1x mesečno ali redkeje, laptop pa mogoče 1x na 2-3 mesece.
BigWhale ::
emerge world prakticno nikoli. Prevec je paketov, ki jih ni treba upgrade-at, prevec je takih, ki jih ne smem downgrade-at... :P
BW: pa jih dej u /etc/portage/profiles/package.mask in /etc/portage/package.keywords
emerge world pa nardim enkrat na dva mesca, razen če se kje pojav kak res mal bl kritična luknja.
CaqKa ::
bigwhale ja kako pa potem posodabljaš sistem? to me predvsem zanima za spletni strežnik.
moj_nick ::
Za strežnik bi bil najbolj primeren GLSA.
GLSA ima na malo bolj čudno sestavljenih sistemih probleme. Meni recimo po emerge world javi ravno toliko ranljivosti kot pred tem. Pa še emergat hoče par paketov k jih niti približno nimam (recimo 3 kernel verzije). Trenutno je moj komp "affected by 27 GLSA"... zadnji emerge world je bil pa včeraj.
Praktičen primer:
Your computer is affected by the 200405-05 GLSA
Opis te GLSA dobite tukaj.
To pa pravi moj Gentoo:
pithlit # etcat -v utempter
[ Results for search key : utempter ]
[ Candidate applications found : 1 ]
Only printing found installed programs.
* sys-apps/utempter :
[ ] 0.5.5.5-r1 (0)
moj_nick ::
A ti hoče emerge-at utempter, če poženeš glsa-check --fix all?
BigWhale ::
Pith, ne bom jih dal med masked packages, ker se vedno hocem budno spremljat kako gre razvoj naprej. ;>
Caqka: kako delam upgrade?
# emerge -vp world
Potem preverim kaj je novo in kaj ne, sledi
# emerge -vp package1 package2 package3 ... packagex
Ce je vse ok, potem se finalni
# emerge -v package1 ... packagex
# etc-update
Pri etc update ponavadi preverim vse datoteke kako so bile spremenjene.
Hja, sem pac control freak... :P
moj_nick ::
Zakaj ne uporabljaš -a namesto -p?
BigWhale ::
Pojma nimam. A ask vprasa za vsak paket posebej ali kako ali za vse skupaj?
BW: sej daš =paket-verzija pa je :P Sicer pa sem jaz isto k ti delal do pred kratkim, pol pa sem se odločil da bom to delal medtem ko spim. Tako da kako uro preden grem spat nardim emerge sync, popedenam vse pakete tako da na koncu emerga sam to k hočem/rabim... in ko se zbudim je ponavadi zrihtano (sam se etc-update poženem).
moj_nick: jep. Točno to mi gre na živce. Enkrat sem dal emerge world, zatem glsa-check -f all. Potem sem tko za foro dal še enkrat emerge -pv world... in se prijel za glavo ;( Od takrat se pač ne zajebavam več.
P.S. mene emerge -a vpraša za vse pakete hkrati. Tako da ostajam pri -p. :D
64202 ::
A gentoo podpira, da bi bootstrapnil zadevo z nule s kako staro (2.2.x) verzijo glibc-ja? Sicer trenutni plan je debootstrap od debian woodya v en direktorij pa potem chroot, samo potem pac dobim glibc 2.2.5 in to je to, ni toliko kontrole.
Namrec nameravam buildat ultraportable c++ executable, delno staticno zlinkane.
BigWhale ::
Pri meni povprecno to traja kakih deset, dvajset minut. Razen pri kaksnih vecjih paketih, samo me zadeva tako ali tako ne moti blazno pri delu.
Hmmm PIII/996MHz laptop - sam firefox rabi okol 4 ure :P Kar se dela tiče mam pa PORTAGE_NICENESS="10" tko da tud ni panike. Sam mi gre na živce k venti tuljo k zmešani...
64202: sej maš 2.2.5-r9 ebuild... a rabiš starejšega? Če se to sliš kot neumnost se opravičujem... ne delam bootstrap-ov ker se mi zdi mal brezveze.
CCfly ::
Mene pri prevajanju moti prevsem, da z distcc vsak tretji emerge nesrečno crkne. Imate morda podobne izkušnje ?
(gcc različice so identične tudi glibc je svež)
"My goodness, we forgot generics!" -- Danny Kalev
64202 ::
Pithlit: aja, kr ebuild za glibc je? Kewl! :) Nisem domac na gentoo, samo za tole zadevo bo pa zgleda svinjsko dober. Mislim si skupaj spravit eno build okolje znotraj chroot-a, ki bi z nartaboljmodernim[tm] g++ 3.4.x out-of-the-box produciralo executable, ki delujejo na poljubni distribuciji, ki imaj vsaj glibc 2.2.x. Ja, vem za '-static', samo je toliko problemov s tem,... vidis kak en navadn bug od buga je glibc/gcc. Treba je libc pa libpthread dinamicno zlinkat, to je to.
Mene pa gcc-4.0.0_beta20050305 ful mika... sam nekako sem cvikalica ker ta komp nima ne floppy-ja ne cd-rom-a. Pa mi ni čist jasno kako drugač spravit Gentoo gor (al pa bilo kaj druzga).
64202: sej so tud starejši ebuild-i. Nekje sem najdu 2.1.2, sam poguglat morš pa ga u overlay zalimat.
64202 ::
Zanimivo... ce bo uspelo z glibc 2.1.x, je sansa celo za debian potato 8-O 8-O :D
Malo me je sicer strah, kaj bo s threadi na tako starem distrotu.
Pithlit, a ni 10 default tudi ce ne nastavis?
Default je 3 se mi zdi. Al je celo 0. V vsakem primeru je vrstica komentirana. V starejših različicah pa te vrstice sploh ni bilo v make.conf.
[Gentoo] Kernel upgrade (strani: 1 2 )
Oddelek: Operacijski sistemi
676455 (5981) Trubadur
mysql 5.0.16 gentoo
101656 (1574) yimi
K3B problem
71700 (1578) theD3viL-
KMetabar
151483 (1315) kriko1
Gentoo problem (strani: 1 2 )
675711 (5236) Senzacionale
