Forum » Strojna oprema » AGP APERATURE SIZE
AGP APERATURE SIZE
WhiteWolf ::
Ce imas grafo, ki ima npr 256 rama ali se v biosu APERAUTURE SIZE nastavi na 256 ali na 128?
Nekje sem prebral da se nastavi ravno na polovico kot ima grafa rama,
spet drugi pravijo, da se nastavi na enako vrednost kot je količina pomnilnika na grafični.
Kako je sedaj otpimalno?
"Maximus Decimus Meridius: What we do in life, echoes in eternity"
- premaknilo iz Pomoč in nasveti: bastadu ()
BaRtMaN ::
Adrian Rojak's BOG - AGP Aperture Size
It is recommended that you keep the AGP aperture around 64MB to 128MB in size, even if your graphics card has a lot of onboard memory. This allows flexibility in the event that you actually need extra memory for texture storage.
DominusSLO ::
Moj bios sam nastavi in zaklene na 128, ko dam na turbo settings.
Drugače pa je najbolj merodajno, če zadevo stestiraš.
cpu&nb watercooled, gpu on air at the moment
| » | grafika versus LCDOddelek: Pomoč in nasveti | 1561 (1342) | jouza |
| » | Navijanje GeForce FX 5900XT (NV35XT)Oddelek: Navijanje | 1723 (1369) | Sami |
| » | AGP aperture size ?Oddelek: Pomoč in nasveti | 1425 (1354) | Dr_M |
| » | Je z mojim računalnikom nekaj narobe?Oddelek: Pomoč in nasveti | 2493 (1893) | AtaStrumf |
| » | Hercules8500LeOddelek: Pomoč in nasveti | 2854 (2055) | rap3r |
