Forum » Programiranje » [C/C++] unsigned long lala = -1;
BigWhale ::
Kdaj je tole upravicno in smiselno?! narediti?
Glede na to, da compiler warninge ven pljuva... ;>
Vesoljc ::
zakja pa ne :)
so pa seveda tudi lepšejši načini
const unsigned int uint32_max = -1;
Vesoljc ::
zdej ne vem kako je sz standardom ampak dotične implementacije std-ja imajo razne limits, numeric_limits template (dinkumware, hp, itd...). no, devc++ inu msvc7 imata tudi limits.h, ampak guess what :)
iz devc++ (pomoje lahko objavimo?)
@sergio
ccc...
/* This administrivia gets added to the beginning of limits.h if the system has its own version of limits.h. */ /* We use _GCC_LIMITS_H_ because we want this not to match any macros that the system's limits.h uses for its own purposes. */ #ifndef _GCC_LIMITS_H_ /* Terminated in limity.h. */ #define _GCC_LIMITS_H_ #ifndef _LIBC_LIMITS_H_ /* Use "..." so that we find syslimits.h only in this same directory. */ #include "syslimits.h" #endif #ifndef _LIMITS_H___ #define _LIMITS_H___ /* Number of bits in a `char'. */ #undef CHAR_BIT #define CHAR_BIT __CHAR_BIT__ /* Maximum length of a multibyte character. */ #ifndef MB_LEN_MAX #define MB_LEN_MAX 1 #endif /* Minimum and maximum values a `signed char' can hold. */ #undef SCHAR_MIN #define SCHAR_MIN (-SCHAR_MAX - 1) #undef SCHAR_MAX #define SCHAR_MAX __SCHAR_MAX__ /* Maximum value an `unsigned char' can hold. (Minimum is 0). */ #undef UCHAR_MAX #if __SCHAR_MAX__ == __INT_MAX__ # define UCHAR_MAX (SCHAR_MAX * 2U + 1U) #else # define UCHAR_MAX (SCHAR_MAX * 2 + 1) #endif /* Minimum and maximum values a `char' can hold. */ #ifdef __CHAR_UNSIGNED__ # undef CHAR_MIN # if __SCHAR_MAX__ == __INT_MAX__ # define CHAR_MIN 0U # else # define CHAR_MIN 0 # endif # undef CHAR_MAX # define CHAR_MAX UCHAR_MAX #else # undef CHAR_MIN # define CHAR_MIN SCHAR_MIN # undef CHAR_MAX # define CHAR_MAX SCHAR_MAX #endif /* Minimum and maximum values a `signed short int' can hold. */ #undef SHRT_MIN #define SHRT_MIN (-SHRT_MAX - 1) #undef SHRT_MAX #define SHRT_MAX __SHRT_MAX__ /* Maximum value an `unsigned short int' can hold. (Minimum is 0). */ #undef USHRT_MAX #if __SHRT_MAX__ == __INT_MAX__ # define USHRT_MAX (SHRT_MAX * 2U + 1U) #else # define USHRT_MAX (SHRT_MAX * 2 + 1) #endif /* Minimum and maximum values a `signed int' can hold. */ #undef INT_MIN #define INT_MIN (-INT_MAX - 1) #undef INT_MAX #define INT_MAX __INT_MAX__ /* Maximum value an `unsigned int' can hold. (Minimum is 0). */ #undef UINT_MAX #define UINT_MAX (INT_MAX * 2U + 1U) /* Minimum and maximum values a `signed long int' can hold. (Same as `int'). */ #undef LONG_MIN #define LONG_MIN (-LONG_MAX - 1L) #undef LONG_MAX #define LONG_MAX __LONG_MAX__ /* Maximum value an `unsigned long int' can hold. (Minimum is 0). */ #undef ULONG_MAX #define ULONG_MAX (LONG_MAX * 2UL + 1UL) #if defined (__STDC_VERSION__) && __STDC_VERSION__ >= 199901L /* Minimum and maximum values a `signed long long int' can hold. */ # undef LLONG_MIN # define LLONG_MIN (-LLONG_MAX - 1LL) # undef LLONG_MAX # define LLONG_MAX __LONG_LONG_MAX__ /* Maximum value an `unsigned long long int' can hold. (Minimum is 0). */ # undef ULLONG_MAX # define ULLONG_MAX (LLONG_MAX * 2ULL + 1ULL) #endif #if defined (__GNU_LIBRARY__) ? defined (__USE_GNU) : !defined (__STRICT_ANSI__) /* Minimum and maximum values a `signed long long int' can hold. */ # undef LONG_LONG_MIN # define LONG_LONG_MIN (-LONG_LONG_MAX - 1LL) # undef LONG_LONG_MAX # define LONG_LONG_MAX __LONG_LONG_MAX__ /* Maximum value an `unsigned long long int' can hold. (Minimum is 0). */ # undef ULONG_LONG_MAX # define ULONG_LONG_MAX (LONG_LONG_MAX * 2ULL + 1ULL) #endif #endif /* _LIMITS_H___ */ /* This administrivia gets added to the end of limits.h if the system has its own version of limits.h. */ #else /* not _GCC_LIMITS_H_ */ #ifdef _GCC_NEXT_LIMITS_H #include_next <limits.h> /* recurse down to the real one */ #endif #endif /* not _GCC_LIMITS_H_ */
@sergio
ccc...
- spremenil: Vesoljc ()
| » | Pomoc pri nalogiOddelek: Programiranje | 2614 (2420) | FuI2cY |
| » | [C] random do poljubne številkeOddelek: Programiranje | 2514 (2181) | napsy |
| » | [C/C++] ifdefOddelek: Programiranje | 1110 (1044) | CCfly |
| » | [visual c++] #ifdef _DEBUGOddelek: Programiranje | 1429 (1370) | Vesoljc |
| » | UnicodeOddelek: Programiranje | 1621 (1512) | Vesoljc |
