rahlo navijanje sistema
rob ::
Ravnokar se ukvarjam z enim compom. Rad bi ga porihtu da bi bil čim bolj stabilen in da bo čim hitrejši s čim manj pregrevanja. Skratka mora bit "rahlo navit" z optimalnimi nastavitvami.
Ker vem da je tle med vami ogromno pravih mojstrov,
je vsak nasvet še kako dobrodošel :D !
Tukaj so trenutne nastavitve
Verjetno bi blo dobr tud novejši bios dobit.....
CPU = XP 2200+
MB = ASUS A7N8X - EAY
RAM = 2 x 256 MB 400 MHz PC3200 CL3 DUAL MODE
TEMPERATURE:
CPU
v Speedfan-u 44 C
v BIOS-u 52 C
MB
v Speedfan-u 23
v Biosu 24
HDD 37 C
DMI BIOS
BIOS #1
vendor Phoenix Technologies, LTD
version ASUS A7N8X2.0 ACPI BIOS Rev 1005
date 05/14/2003
CPU #1
manufacturer AMD
model AMD Athlon(tm) XP
clock speed 1775.0MHz
FSB speed 169.0MHz
multiplier 10.5x
Number of CPUs 1
Name AMD Athlon XP
Code name Thoroughbred
Specification AMD Athlon(tm)
Family/Model/Stepping 680
Extended Family/Model 7/8
Package Socket A
Core Stepping A0
Technology 0.13µ
Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
Clock Speed 1776.0 MHz
Clock multiplier x10.5
Front Side Bus Frequency 169.1 MHz
Bus Speed 338.3 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 256 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 1776.0 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Chipset
Northbridge nVidia nForce2 Ultra 400 rev. C1
Southbridge nVidia nForce2 MCP rev. A4
Graphic Interface AGP
AGP Revision 2.0
AGP Transfert Rate 4x
AGP SBA supported, not enabled
AGP Aperture 64 MBytes
Memory Type DDR
Memory Size 512 MBytes
Memory Frequency 169.1 MHz (1:1)
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 7
Memory SPD
DIMM #1
General
Memory type DDR-SDRAM
Manufacturer (ID) Nanya Technology (7F7F7F0B00000000)
Size 256 MBytes
Max bandwidth PC3200 (200 MHz)
Part number M2U25664DS88B3G-5T
Manufacturing date Week 19/Year 03
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 133 166 200
CAS# 2.0 2.5 3.0
RAS# to CAS# delay 2 3 3
RAS# Precharge 2 3 3
TRAS# 6 7 8
DIMM #2
General
Size 256 MBytes
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
CAS# 2.0 2.5 3.0
TRAS# 6 7 8
  • spremenil: Predator ()
Gonilniki
Oddelek: Programska oprema
122422 (2305) Housy
navijanje della
Oddelek: Navijanje
61580 (1472) MecH
Priporočila za nadgradnjo (AKA kako najbolj poceni pridem, do mal hitrejšega delovanj
51551 (1502) bluefish
Navil Athlona 64 FX venice z gigabyte GA-K8NF-9 (strani: 1 2 )
Oddelek: Navijanje
837515 (5636) S!lentHunter
Kwa je bolše: AMD 1700+ & 2500+ (strani: 1 2 )
Oddelek: Navijanje
535661 (4662) Mulh
