Forum » Loža » Športne stave - je sploh možno uspeti?
webmaher ::
POVZETEK 15.1.2021: +8,3 ENOT
POVZETEK VSE: +8,3 ENOT
YIELD 1dan 8 tekem = 103,75%
0,83/0,8*100
8 stav v živo 5 zadetih, 3 zgrešene
0,83/0,8*100
webmaher ::
Dost hecanja za soboto
POVZETEK 16.1.2021: +7,4 ENOT
POVZETEK VSE: +15,7 ENOT
YIELD 2dan 16 tekem = 98,12%
1,57/1,6*100
9 stav v živo 6 zadetih, 2 zgrešeni in 1 denar nazaj
- spremenilo: webmaher ()
webmaher ::
webmaher ::
webmaher ::
koyotee ::
Pointless objave...
Rear DVD collector!
JTD power!
JTD power!
jonystar ::
Od William HIlla sem prejel mail, kjer od mene zahtevajo podatke ali pa mi bojo zaprli račun. Mi lahko kdo pove kaj točno želijo. Z boldanimi sem označil stvari, kjer nisem siguren kaj želijo. Email spodaj:
Good day.
Please accept our apologies for this inconvenience but due to updated regulatory requirements for customers who exceed a set threshold of deposits and withdrawals, we now need to complete further identity checks. This means that we cannot process any withdrawals until you have updated your details or provided ID documents.
Proof of Address (less than 6 months old and should match the address on your account)
1. Credit Card Statement - Bančni izpisek
2. Utility bill, Bank statement - ??
3. Signed Credit agreement - ??
4. Council Tax Bill (less than 6 months old and should match the address on your account). - ??
Please scan or take a photo of any of them. Make sure they're all clear and visible and saved in a .jpeg or pdf format. Click here submit your documents.
We hope to hear from you soon. Please note that we will be required to suspend your account if we are not able to verify your identity in the next 30 days.
Regards,
Matthew
Customer Verification Team
William Hill Online
Good day.
Regards,
Matthew
William Hill Online
- spremenil: jonystar ()
reeves ::
Ja, stavnice in poker strani na vsake toliko zahtevajo ponoven KYC.
Pri tebi zahtevajo samo potrditev naslova. Jaz v takem primeru pošljem .pdf bančnega izpiska, ki ga potegnem s spletne banke. Do sedaj še nisem imel problemov, nimam pa računa pri William Hill.
jonystar ::
Sem bil v kontaktu s William Hill live chatom in so mi rekli, da naj jim pošljem potrdilo o mojem stalnem prebivališču v angleškem jeziku. Kje lahko to dobim? na e-upravi je sicer možno oddati vlogo za izpis o stalnem prebivališču ampak to je v slovenskem jeziku.
reeves ::
Pozabi na angleški jezik. Ne poznam nikogar, ki bi moral prevajati.
Pojdi na strani tja, kjer imaš upload documents, izberi bank statement in pošlji bančni izpisek.
Ko ga bodo dobili, ti bodo javili, če še kaj potrebujejo oz. aktivirali račun.
Kvinta ::
Zakaj bi se sploh na Wiliam Hill prijavo ? Ko pamarecimo Bet365 dosti boljšo ponudbo.
A.C.A.B
jonystar ::
@reeves, bom še tako naredil. Želel sem preko live chata zato, da je takoj urejeno.
@Kvinta, imam tudi Bet365.
BorutF ::
link
Liberalizacija sportnih stav sla cez prvo branje.
Zanima me kako nekateri lahko stavite na William HIllu, a ni Slovenija blokirana??
BorutF ::
reeves ::
Ali ne zahtevajo preverjanja identitete? Ce se prav spomnim so mi na Bwin pred leti zaprli racun, ker sem iz Slovenije.
Zahtevajo. Ampak kar se njih tiče lahko igraš vse razen pokra na Williamu, če si iz Slovenije.
https://williamhill-lang.custhelp.com/a...
BorutF ::
Zanimivo, kaj pa BetFair? je mozno igrati iz Slovenije?
Aamadej ::
Že od leta 2016 ne več, takrat so izločili Slovenijo, kakor tudi 3/4 držav zahodne evrope.
Imaš pa zato na voljo Betfair White labels preko azijskih brokerjev.
reeves ::
Ne.
Pri tujih stavnicah imamo dve težavi.
Prva je ta, da naša zakonodaja ne dovoli igranja na skoraj nobeni tuji stavnici. Zato so naročili slovenskim ISP-jem, da v svojih DNS-ih blokirajo tuje stavnice ali pa jih preusmerijo na stran, kjer nekaj piše o nekem ministrstvu. To oviro zelo enostavno rešiš tako, da v vseh napravah (oz. tam kjer rabiš) spremeniš DNS v npr. Googlove 8.8.8.8 in 8.8.4.4.
Večino igralnic prav nič ne moti, da naša zakonodaja to nekako prepoveduje in nas z veseljem sprejmejo. Najbrž gledajo na to kot, da je pač naš problem kako bomo z našo davkarijo zrihtali. Njim se naših zakonov itak ni potrebno držati.
No, druga težava pa je nekaj stavnic, ki pa že same prepovedujejo igranje slovenskim državljanom. Tukaj pa ni pomoči. Strani že same zaznajo, da si iz Slovenije, če uporabiš pa VPN (če sploh uspe...nekatere strani tudi to zaznajo) ti pa itak ne bo šel KYC skozi. BetFair je ena izmed njih.
reeves ::
Zakaj bi si sploh odpiral recimo WilliamHill ,če pa na Bet365 vse dela![]()
Arbitrage betting
https://oddspedia.com/surebets
Aamadej ::
Ne.
Prvič slišim za zakon, ki Slovenskim državljanom ne dovoli igranja na tujih spletnih stavnicah.
Lahko poveš kateri zakon konkretno to določa, ter ga citiraš?
reeves ::
Ni dejansko zakona za to. Sem se narobe izrazil. FURS ima dovoljenje, da naroči ISP-jem, da blokirajo strani.
Če bi bil zakon, bi imel težave z izplačevanjem, tako pa lahko brez težav poveš, da je denar iz tuje stavnice.
__Devil__ ::
Mislim, da se da veliko zaslužit z stavami nasploh oz. preko bet356, sodelavec je nonstop na tem, najbrž ne zastonj :). Ampak moreš najbrž biti fan nogometa, redno spremljat tekme oz. poznat neke finte kako (čimbolj) zadeti rezultat in stavit precej denarja ampak tega nebom nikoli razumel.
Kvinta ::
Arbitrage betting
To so take male razlike v kvotah meni totalno nepomembne
To sploh ni res jaz recimo igram občasno 1-3x na mesec malo že vem ne spremljam pa skoraj da ne nič pa vseeno dobim
A.C.A.B
BorutF ::
Aamadej ::
Razlika je v tem, da je vmes posrednik - azijski broker. Torej se moraš registrirat preko brokerja in potem preko njegove platforme dostopaš do Betfaira. V tej platformi pa je istočasno na voljo še cel kup "high limit" stavnic, kot so Pinnacle, BetISN, Maxbet, 18bet.... itd. Na tak način na istem mestu dobiš najvišjo možno kvoto. V tej platformi pa so na razpolago še ostale stavne borze, kot sta npr Betdaq in Matchbook, ki si ga že omenil.
Matchbook je pa podobna stavna borza kot Betfair, s to razliko da so usmerjeni najbolj v severno ameriške športe, NFL, NBA, MLB, NHL. Pri teh športih imajo najvišjo likvidnost, dosti nižja je pa pri nogometu. Če staviš večinoma na nogomet, je Betfair še vedno daleč pred ostalimi stavnimi borzami tako v smislu ponudbne, kot likvidnosti.
Aamadej ::
No saj ravno zato sem vprašal, ker kot si sam omenil, takšnega zakona pri nas ni. Pa tudi če bi ga dejansko uzakonili, bi padel na ustavnem sodišču.
Blokade FURS-a pa seveda poznam, ampak je tudi ta praksa zelo ustavno sporna, saj je bila sforsirana s strani lobijev, ki imajo močne povezave z nacionalno Športno loterijo. In edini namen teh blokad je preprečit odliv denarja na tuje športne stavnice in posledično čimveč profita za Športno loterijo, iz katere se že leta in leta napajajo številni državni paraziti.
vprasam ::
Kakšne ideje kako staviti, mislim na taktiko? Ne predlogi dogodkov, ampak na kakšen način kaj zaslužiti s stavami..
Od nogometa mi je bilo OK staviti na brazilska klubska tekmovanja, ampak tudi tu je zadnje čase veliko presenečenj.
- spremenilo: vprasam ()
| » | Stavni nasveti (strani: 1 2 3 )Oddelek: Loža | 50582 (25844) | Pinturicchio |
| » | Stave? (strani: 1 2 )Oddelek: Loža | 25516 (15709) | Dzhimen |
| » | Športne staveOddelek: Loža | 9077 (7388) | bdoxx |
| » | sistem športnih stav (strani: 1 2 )Oddelek: Loža | 28623 (27133) | kinggovhell |
| » | športne stave (strani: 1 2 )Oddelek: Loža | 19912 (10820) | GregiB |
