MAX. navijanje graficnih kartic
majstor ::
MAX OC'S
For those of you wandering how far you can push cards, here are some
popular cards i have used and overclocked to the brim with stock
cooling:
Geforce 2 mx200 DDR: stock 175/266 max:240/310 (64 bit)
Geforce 2 mx400 DDR: stock 200/266 max:235/310 (64 bit)
Geforce 2 TI: stock 250/400 max:285/475 (BAD overclocker)
Geforce 3 ti200 DDR: stock 175/400 max:230/480
Geforce 4 mx420 SDR: stock 250/166 max:275/180 (BAD overclocker)
Geforce 4 mx440 DDR: stock 270/400 max:285/450
Geforce 4 ti 4200 128mg: stock 250/500 max:310/610
Geforce fx5200: stock 250/400 max: 320/480
Geforce fx5600: stock 325/550 max: 400/610
Geforce 6800: stock 325/700 max: 390/830
Geforce 6800GT: stock 350/1000 max: 400/1100
Radeon 9000: stock 250/400 max:280/450
Radeon 9200: stock 250/400 max:290/440
Radeon 9550: stock 250/400 max:390/460
Radeon 9600: stock 325/400 max:420/500 (GREAT Overclocker)
Radeon 9600 pro: stock 400/600 max:520/710 (GREAT overclocker)
Radeon 9600 XT: stock 500/600 max:560/680
Radeon 9800 pro: stock 380/680 max:420/770
Now all of those are from personal expierence and vary from card to
card. Dont get me wrong even though some cards dont overclock well
like the 9800 pro, it dosnt mean its not good, the 9800 pro dosnt need
overclocking to be a speed demon. Thats all for now, ill edit this
post a little more in the fututre with more card results as i
overclock more cards. Good Luck
JACK1 ::
hi
Me pa res zanima s kerim programom bi lahka navil mojga radeona 9600pro k piše de se da navit na max:520/710 :)) Če bi najdu program bi bil zelo vesel z ati tools sem lahko navil samo na 450/330 oz.ddr 660.
Če kdo ve za kak program naj mi pošle link.:D
majstor ::
Probaj tu:
KLIKNI SEM
To so OMEGA predelani driveri, mislim da omogocajo tudi navijanje.
jRk0 ::
No da se dodam:
Radeon 8500LE: stock 250/480 max:300/610
majstor ::
evo za ATI graficne:
Download Radclocker for ATI cards (google it)
Boki_ ::
Evo še mene.
Radeon 7500 250/230@333/250(4ns rami, niti vmod ni pomagal. Ni šlo čez 250 pa še se ubiješ)
I'm back
DjTonic ::
To niso ravno nevem kakšni dosežki, zgleda, da uporabnik ni bil neki pravi navijalec.
_Dejan_ ::
Ja sej z originalnim hlajenjem pr določenih karticah ne prideš daleč.
Moja GF4 TI4200 stock 250/513@310/615
ASUS P5E3, INTEL Q6600(3000Mhz 333x9), ATI HD 2600XT,
A-Data 4x2GB PC3-10700H(9-9-9-24-2T),LSI 9260-8i,
4x OCZ Vertex Turbo 30GB(RAID10), 3x1TB (RAID1+Spare)
majstor ::
Kak ventilator se mi splaca nabavit za FX5200? In kje naj ga nabavim, kolk je cena.
Navil sem na 281/371 vec ne gre, to pa se mi zdi kar malo...
Cranchi ::
nekaj me zanima zakaj mi pri RivaTunerju ne omoga navijanja, sicer vse kaze frekvence ramov itd.. pa vendar nemorm obljukat opcije navijanja..
So to normalne frekvence FX 5500 z 128 mbit vodilo:
270 / 365 ?
boštjan ::
pri riva tuneru moraš it na spodnji zavihek,ne zgornjega
NF7-S,2500+@2200MHz,MSi 5900SP,LCD Philip 190X6,Maxtor DM+9 120GB SATA,
2*256 3200/A KHX, PSU 420W DF chieftek
Cranchi ::
hvala lepa, uceri sm se lotu malcek OCjat zadevo in mi je ratal slednji rezultat..
FX 5500 128MB DDR Ram 128 MBit = 270 / 366 @ 310 / 450 @ Stock quler, imam obcutek da je se kar nekaj rezerve rami ter Gpu je pa tudi prov prijetno mlacen tako da se zadeva niti malo ne segreva..
jest10 ::
R9000pro 275/550 na 322/570
R9600xt 500/676 na 515/744
m4dj ::
Jst mam FX5200 128DDR. original je 250/332, navil sem jo na 280/390 in za sedaj ostajam pri teh novih nastavitvah. Seveda gre tudi več...
Ko igram se kar malo pozna in je šlo na boljše....
M4DJ
sid911 ::
mogoče je smešno sam vseeno
redon 9200se 200/166 na 315/230 (ventilator obrnjen prti hladilniku)
msms ::
Jaz sem mojo grafo geforce 2 TI od Leadteka navil na 285/525 original je 225/400.
Boki_ ::
ASUS 9800XT 412/365 @ 530/435
Bi šlo še več sam se mi ne da delat vmoda :D
I'm back
Katero graficno kartico uporabljate? (strani: 1 2 3 4 )
18714037 (10573) mtosev
Nekaj več od GeCube ATI 9550GT
Oddelek: Navijanje
162044 (1731) sid911
grafična
382746 (2014) pinx
Vprašanje glede memory clock-a Sparkle fx5200 128 tv out
81726 (1659) m4dj
OC baza: Geforce 256-4800
Oddelek: Navijanje
93527 (3290) njok
