soltek sl-kt600-c1 in zadeva imenovana: Redstorm overclockiing tech"
sash69 ::
"Finally, a function called "RedStorm Overclocking Tech" is included, and allows the system to be tested and Overclocked to its maximum according to a set of pre-selected stability criteria. Once activated, "RedStorm Overclocking Tech" tweaks the CPU a little at a time in order to determine the highest frequency it can support. Once that frequency is determined, the system is rebooted at said frequency, and your done. We'll be taking a closer look at this function later-on in this article."
tako se glasi "definicija" tegale tehnika.:D zdej mene zanima,kako se ta stvar obnese v praksi,in ali jo je ze kdo sprobal,pa se kaksne nasvete glede tega...any1?:8) pa se to,ce obenem zvisa frekvence ostalih vodil in rama ce mogoce kdo ve?lp!
sash
p.s:aja,sm nekaksen zacetnik,kar se navijanja tice:8)
prov pogledat sm mogu datum te teme....
ta redstrom so mele soltekove plate ze 3.5+ leta nazaj...
Core 2 Duo E4400 navijanje!
Oddelek: Navijanje
213650 (3367) Razy
2x256 ali 1x512 rama
61735 (1572) boštjan
Navijanje AMD-ja
Oddelek: Navijanje
322603 (1874) Boky
Soltekov RedStorm Overclocking: sanje ali beda?
61047 (918) kuglvinkl
Red Storm Overclocking!!!!!!!!
Oddelek: Navijanje
81358 (1260) R@C@
