Forum » Navijanje » soltek sl-kt600-c1 in zadeva imenovana: Redstorm overclockiing tech"
sash69 ::
"Finally, a function called "RedStorm Overclocking Tech" is included, and allows the system to be tested and Overclocked to its maximum according to a set of pre-selected stability criteria. Once activated, "RedStorm Overclocking Tech" tweaks the CPU a little at a time in order to determine the highest frequency it can support. Once that frequency is determined, the system is rebooted at said frequency, and your done. We'll be taking a closer look at this function later-on in this article."
tako se glasi "definicija" tegale tehnika.:D zdej mene zanima,kako se ta stvar obnese v praksi,in ali jo je ze kdo sprobal,pa se kaksne nasvete glede tega...any1?
pa se to,ce obenem zvisa frekvence ostalih vodil in rama ce mogoce kdo ve?lp!
sash
p.s:aja,sm nekaksen zacetnik,kar se navijanja tice
sash
prov pogledat sm mogu datum te teme....
ta redstrom so mele soltekove plate ze 3.5+ leta nazaj...
| » | Core 2 Duo E4400 navijanje!Oddelek: Navijanje | 3650 (3367) | Razy |
| » | 2x256 ali 1x512 ramaOddelek: Kaj kupiti | 1735 (1572) | boštjan |
| » | Navijanje AMD-jaOddelek: Navijanje | 2603 (1874) | Boky |
| » | Soltekov RedStorm Overclocking: sanje ali beda?Oddelek: Strojna oprema | 1046 (917) | kuglvinkl |
| » | Red Storm Overclocking!!!!!!!!Oddelek: Navijanje | 1358 (1260) | R@C@ |
