Forum » Igre » shogun ne dela?
shogun ne dela?
tec ::
mam P3,256 ram, geforce2,abit plata pa mi noce delat shogun total war, nobenega erorja nic, sm crn ekran rata pol pa fukne nazaj u win(ko hocm zagnt) kolegu pa isti cd normalno dela na AMD.
PROSIM CE MI LAHKO KDO DA KAKSN NASVET.
HVALA
L.P
tec
HVALA
L.P
tec
|KoRn| ::
Jaz imam tudi podobne težave s tem špilom. Na P2 350 laufa super, a lej ti zlomka na AMDju TB800 mi noče delat! Najper črn zaslon pol pa koj nazaj v winse... kaj bi lahko blo narobe pojma nimam... morda ji ne paše grafična GeForce2MX?
Freak on a leash!
Dr.Miha ::
men je brez problema delal na P3 700 mhz, 128 mb rama in Geforce DDR....
Čisto možno da je kriva grafična kartica, saj vemo koliko igre se tepe z MXom...
Za domovino z Nintendom naprej!
joze ::
tocno to, zamenjaj driverje za geforca.V geforce faq je ta problem omenjen, opisana pa je tudi resitev
tec ::
Sm probal z novejšim driverjem pa še vedno ne dela shougun, ostele igre delajo normalno.
Kaj nardit?
HVALA
L.P
tec
Kaj nardit?
HVALA
L.P
tec
joze ::
ni važno da so najnovejsi.
preberi tole:
. Shogun: Total War crashes to the desktop before the opening screens. How can I fix it?
The following driver versions work best with Shogun: Total War:
5.32
6.18
7.17
10.50+
10.80+ is the best version to use. If these driver sets still don't work, the following website contains other Shogun troubleshooting tips:
http://erado.totalwar.org
You may also be able to fix any problems by starting Shogun: Total War in windowed mode. You can do this with the following steps provided by Steve Evest:
Right click on the shortcut that you launch the game from.
Click Properties.
Click the shortcut tab.
Where it says
"C:\Program Files\Total War\Shogun - Total War\Shogun.exe" (note it may be in a different folder)
change it so it says
"C:\Program Files\Total War\Shogun - Total War\Shogun.exe" /deb
The game will now run in a window, although battle sequences run slower.
preberi tole:
5.32
6.18
7.17
10.50+
Click Properties.
Where it says
| » | Shogun 2: Total War (strani: 1 2 3 4 )Oddelek: Igre | 29229 (624) | Polda |
| » | Katere igre bi mi delovaleOddelek: Igre | 1757 (1608) | opeter |
| ⊘ | dobre Strategije (strani: 1 2 )Oddelek: Igre | 12883 (10682) | Tilen |
| » | The Godfather (strani: 1 2 )Oddelek: Igre | 11468 (6986) | Mavrik |
| » | A je kdo za eno strategijoOddelek: Igre | 2086 (1837) | frenk |
