SuSe 9.1 Problem pri installu Tk-ja za perl
kihc ::
Zdej sem se lotu inštalirat Ghoti (irc klient), ker bom zaradi x-chata znorel. No, potegnem dol source, preberem readme in noter piše da rabim 3 dodatne perl module. Zajebava me ta "Tk" in sicer ko hočem nardit "perl Makefile.PL" mi butne ven errorje v stilu da ne najde nekih X11 include fajlov;
kihc@khista:~/Tk800.024> perl Makefile.PL
/usr/bin/perl is installed in /usr/lib/perl5/5.8.3/i586-linux-thread-multi okay
PPM for perl5.008003
Test Compiling config/signedchar.c
Test Compiling config/unsigned.c
Test Compiling config/Ksprintf.c
Test Compiling -DSPRINTF_RETURN_CHAR config/Ksprintf.c
Test Compiling config/tod.c
Test Compiling -DTIMEOFDAY_TZ config/tod.c
Test Compiling -DTIMEOFDAY_NO_TZ config/tod.c
Test Compiling -DTIMEOFDAY_DOTS config/tod.c
Problem gettimeofday()
Using -L/usr/X11R6/lib to find /usr/X11R6/lib/libX11.so.6.2
Cannot find X include files via /usr/X11R6/include
Cannot find X include files anywhere at ./myConfig line 312.
Compilation failed in require at Makefile.PL line 17.
BEGIN failed--compilation aborted at Makefile.PL line 19.
Zdej, če pogledam v /usr/AX11R6/include so neki fajli samo nimam pojma katere hoče. Se morda komu svita kaj bi moral nardit? Google ne najde nic pametenga...
x
der_Alte ::
Odpri YaST2 in Namesti in odstrani programsko opremo.
Filter nastavi na Išči.
poišči paketa perl-Tk in Xfree86-devel ter ju namesti. Tako ti ne bo potrebno čarat s perl-Tk. Zakaj ga sploh hočeš "na roke" spravit k delovanju?
radeon 9200 suse10 brightness problem
Oddelek: Operacijski sistemi
252376 (2192) roli
K3B problem
71692 (1570) theD3viL-
Linux - zagon programskega jezika
Oddelek: Programiranje
101258 (1100) BigWhale
manjka ukaz emerge
251797 (1567) Brane2
Linux / ATI Radeon / problem z driverji
132216 (2033) ahac
