Forum » Pomoč in nasveti » Kok dobim za ploščo Acorp 6VIA82p FC-PGA
GanjaFarmerMcBorcy ::
Kok dobim za ploščo Acorp 6VIA82p FC-PGA????
Specifikacije:´ChipsetˇG VIA693A+ 596B
ˇ´CPU SupportˇG Intel Socket 370 processor 300~933 MHz CPU
ˇ´Voltage RegulatorˇG VRM 8.4 (Auto Detect )
ˇ´Bus CLKˇG 66/ 75 / 83 /100/133 Mhz
ˇ´Bus ArchitectureˇG 1 x AGP Bus
3 x PCI Bus
1 x ISA Bus Compatible Slot
ˇ´System MemoryˇG 3 x 168 pin DIMM socket 768 MB (Max)
ˇ´USB SupportˇG 2 x Universal Serial Bus port
ˇ´On board I/OˇG 1 x Floppy , 2 x Serial Ports , 1 x Parallel Port
( ECP, EPP, SPP ) 1 x Infrared Port (IR)
ˇ´DMA SupportˇG Ultra DMA 66
ˇ´Power SupportˇG ATX Power Connector Support
ˇ´BIOSˇG AWARD AGP BIOS with ACPI , DMI Green , Plug and Play Features 2MB -Bit Flash
ROM , Support CD-ROM , SCSI , LAN boot
ˇ´Special FeaturesˇG Temperature Sensor , Warning By Sound , Auto Detect CPU Thermal pin
Wake On LAN (W-O-L) , Wake on Modem , Wake on Alarm
Support SB-Link , Bus CLK Setup with BIOS
Hard-ware monitor (option)
ˇ´Board SizeˇG 19 x 24.3 cm (MATX Form)
3 x PCI Bus
msmiha ::
Odvisno kolk kerega nategneš. Pomoje enih 15K-20K SIT
| » | Sempron 2,8 Ghz?Oddelek: Pomoč in nasveti | 1943 (1553) | Blinder |
| » | Qdi kinetiz 7b + Athlon 1800+Oddelek: Strojna oprema | 2320 (2127) | Blinder |
| » | ASUS ploščaOddelek: Pomoč in nasveti | 2186 (1918) | AngelOfDeath |
| » | Sempron 2400+ in A7S8X-MXOddelek: Navijanje | 2067 (1835) | Hardstyle |
| » | Je kriva plosca za memtest errorje/nestabilnost?Oddelek: Navijanje | 2270 (2122) | AtaStrumf |
