Problem v Control Panel
Dejancek ::
Mislim da bo slika največ povedala ....
Skratka ko kliknem Add/Remove Programs se mi to pokaže ... ;(( ;(( , tak da ne morem it v to ...
Ok kaj da fak je narobe sedaj ?!? :|
Imam pa Win XP (SP1 integriranim) original ....
In inštalirano mam še vse popravke ki se ti inštalirajo na updates ko sem naložil Winse, brez SP2 !!!
Any IDEA :\
flipflop ::
Service Pack 1 Parser Message: Value creation failed" at line 472" error when add/remove programs is opened
This error can occur after installing SP1 when you are running a non Microsoft visual style and the folder
containing the customised styleshell.dll has a differing name from the themes name (as shown in the appearances tab).
To get rid of this error you can switch back to a Microsoft Theme or go to
/WINDOWS/Resources/Themes/ [Name of theme in use] and rename the shell folder to the name of the visual style shown in the appearance tab. If you have a theme with multiple variations you must make this change for each subfolder containing a differing styleshell.dll file
ali pa tukaj
Včasih prideš prej do odgovora če pogledaš z googlom
  • spremenil: flipflop ()
Modri dirkač ::
Problem se pojavi samo v tej temi oz. kožici XBOX. Sem imel isti problem, vendar je avtor to napako že odpravil, tako da si na themexp.org downloadaj verzijo 2 te kožice, ki ima ta problem odpravljen.
Everybody lies!
Dejancek ::
Ma najlepša hvala obema in točno to je bilo 0:) :D
Mac OS Snow Leopard na PC
Oddelek: Operacijski sistemi
485581 (4129) Gray_Warden_
težave z inštalacijo msn-ja
71516 (1427) Dragoyx
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187246 (7105) ManDriver
Logitech MouseWare bug (?)
272588 (2184) Swiwer
Norveška: don't cry for me, Microsoft
Oddelek: Novice / Brskalniki
123488 (3488) andrej
