Forum » Programska oprema » Problem v Control Panel
Dejancek ::
Mislim da bo slika največ povedala ....
Skratka ko kliknem Add/Remove Programs se mi to pokaže ...
, tak da ne morem it v to ...
Ok kaj da fak je narobe sedaj ?!?
Imam pa Win XP (SP1 integriranim) original ....
In inštalirano mam še vse popravke ki se ti inštalirajo na updates ko sem naložil Winse, brez SP2 !!!
Any IDEA
Any IDEA
flipflop ::
Service Pack 1 Parser Message: Value creation failed" at line 472" error when add/remove programs is opened
This error can occur after installing SP1 when you are running a non Microsoft visual style and the folder
containing the customised styleshell.dll has a differing name from the themes name (as shown in the appearances tab).
To get rid of this error you can switch back to a Microsoft Theme or go to
/WINDOWS/Resources/Themes/ [Name of theme in use] and rename the shell folder to the name of the visual style shown in the appearance tab. If you have a theme with multiple variations you must make this change for each subfolder containing a differing styleshell.dll file
ali pa tukaj
Včasih prideš prej do odgovora če pogledaš z googlom
ali pa tukaj
- spremenil: flipflop ()
Modri dirkač ::
Problem se pojavi samo v tej temi oz. kožici XBOX. Sem imel isti problem, vendar je avtor to napako že odpravil, tako da si na themexp.org downloadaj verzijo 2 te kožice, ki ima ta problem odpravljen.
Everybody lies!
| » | Mac OS Snow Leopard na PCOddelek: Operacijski sistemi | 5626 (4174) | Gray_Warden_ |
| » | težave z inštalacijo msn-jaOddelek: Pomoč in nasveti | 1532 (1443) | Dragoyx |
| » | Apache - localhost JA, IP naslov NEOddelek: Omrežja in internet | 7271 (7130) | ManDriver |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2600 (2196) | Swiwer |
| » | Norveška: don't cry for me, MicrosoftOddelek: Novice / Brskalniki | 3512 (3512) | andrej |
