Hacking
Hacking
xabre ::
Malo kontroverzna temo pa vseeno.
Želim pa izvedet, kje/kako bi dobil kako literaturo ali www stran, po možnosti v slovenščini in sicer na temo, kako brskaš po tujih računalnikih.:O
Nočem (ali pač) da tukaj pišete kako pa kaj, ker bo tema verjetno zaklenjena, bi bilo pa fajn da bi mi kdo pomagal.
O programiranju nimam blage veze, okno v svet je dial-up tako da bi prišel prav kaki priročnik za telebane, pa osnove, mogoče kakšen programček:)
Zheegec ::
Janez Janša, 29.04.2014
mirage ::
root987 ::
xabre, nauči se programirat ter nato svoje programe prodajaj/delaj za programska podjetja. Iz lastnih izkušenj lahko povem, da je stvar VELIKO bolj donosna in koristna. Razen če boš über hack master, ki bo potem kradu informacije multinacionalkam ter jih na črnem trgu prodajal, ampak v takšnem primeru dvomim v tvojo dolgo življensko dobo.
"Myths which are believed in tend to become true."
--- George Orwell
andrej ::
mogoce ne bi blo slabo, da na zacetku ugotovis kdo sploh so pravi hackerji in kaj pocnejo...
andrej ::
Hacker is a term used by some to mean "a clever programmer" and by others, especially journalists or their editors, to mean "someone who tries to break into computer systems."
1) Eric Raymond, compiler of The New Hacker's Dictionary, defines a hacker as a clever programmer. A "good hack" is a clever solution to a programming problem and "hacking" is the act of doing it. Raymond lists five possible characteristics that qualify one as a hacker, which we paraphrase here:
A person who enjoys learning details of a programming language or system
A person who enjoys actually doing the programming rather than just theorizing about it
A person capable of appreciating someone else's hacking
A person who picks up programming quickly
A person who is an expert at a particular programming language or system, as in "Unix hacker"
Raymond deprecates the use of this term for someone who attempts to crack someone else's system or otherwise uses programming or expert knowledge to act maliciously. He prefers the term cracker for this meaning.
2) Journalists or their editors almost universally use hacker to mean someone who attempts to break into computer systems. Typically, this kind of hacker would be a proficient programmer or engineer with sufficient technical knowledge to understand the weak points in a security system. For more on this usage, see cracker.
Torej, kaj zelis?
xenon74 ::
V konzorciju v LJ imajo kar nekaj knjig na tvojo temo.
X74
BigWhale ::
Najprej gres sem, si pogledas seznam literature potem pa tukaj vso preberes! Potem bos mogoce nekaj ze znal...
... ne, ne hecam se...
Se prej pa preberes andrejev post, da bos sploh vedel katere izraze uporabiti...
Gandalfar ::
Izvorna koda kaksne distribucije tud ni slabo pocitnisko branje :]
darkolord ::
s čitanjem izvorne kode se pa res ne naučiš dosti
rokpok ::
Za real hacking pač moraš znati zelo ampak zelo dobro programirati...
Uplink - pač neka grafična igra
Try2Hack - od level 7 dalje mogoče že 1/10 tistega ta pravega
Rad bi bil pingvin.
Vikking ::
kako brskaš po tujih računalnikih!!! Pojdi gledat film Troya in podi pozoren na trojanskega konja!!! To je to kar iščeš.... za dodatne informacije uporabi google!
BigWhale ::
Tole treba nekam nalimat... med neumnosti meseca... ;>
xabre ::
Nisem mislil profesialno hackanje:D jao
Naslov je tak zato da bolj pritegne bralca. Zgleda, da is bo za začetek treba kakega trojanca izmislit, pol bo pa že nekaj (eden od načinov dostopa do tujega računalnika?)
Si bom med poletnimi počitnicami malo časa vzel za te stvari.
Nadaljne ideje so pa vsekakor dobrodošle.
Gandalfar ::
Ce rabis poletne pocitnice..
to ni pravi frame of mind.. preberi si andrejev post..
nicnevem ::
Če boš sam sprogramiral troyanca pol greš po pravi poti, sicer je pa vse skup bol kot en script kiddie....ampak ne se sekirat, nekje pač morš začet in da bi kar takoj začel z zapletenim programiranjem mislim da je kr mal huda...razen če maš železno voljo ;)
sicer pa velik sreče
ExOrcisT21 ::
Je že gdo poskuso heckat na tej strani?
Gandalfar ::
Tachyon: trojanca niti ni tolk easy spisat..
xenon74 ::
do tujega računalnika se da brez trojanca zelo enostavno dostopat npr. preko telneta! Trojanec predvsem olajša delo in odkrije tiste, ki niso zaščiteni namesto, da se izpostavljaš in ročno iščeš ranljive. OK, pa ne samo za to :D , da se ne boste zdaj preveč spotikal
X74
http://setiweb.ssl.berkeley.edu/team_display.php?teamid=30319
Ce se z branjem izvorne kode ne naucis dosti, od kje potem stavek
Use the source, Luke!
BigWhale ::
xabre...
Preberi tole temo. Da se ne bom ponavljal, bos zvedel marsikaj pametnega...
nicnevem ::
>...trojanca niti ni tolk easy spisat..
rad verjamem,...ampak če bi ga že samo poizkusil in vložil nekaj tednov (raje mesecev) truda, pa tud mislim da bi se marsikaj uporabnega naučil - to je pa v bistvu fora tega da si hacker....
pa še en advice, inštaliraj si linux, da boš mel en orenk OS s katerim se vsaj lahko kaj igraš, ne kot pri winsih, ki so sicer čist ok, samo poln enih zadev je lepo skritih in zakamufliranih...
CCfly ::
Zanimiv opis za hackerja je bil nekako tak, da je to človek, ki ima šop ključev in ne ve kateri ključ odklene vrata. In ko bi že vsi ostali obupali nad iskanjem, on še vedno poskuša odpreti vrata, dokler mu ne uspe.
rokpok ::
Djgregec: to ti hack-ne google. :D
Link
Rad bi bil pingvin.
ExOrcisT21 ::
Se pravi, da je striček google hacka, treba ga bo zapret:D
iggy ::
Probaj http://www.hackthissite.org kjer so kar pošteno teške naloge.
]Fusion[ ::
BW: v tisti temi si tudi malo mimo fasal. Ker ti tudi ne veš podrobnega delovanja vsake naprave/programa itd. pa jih vseeno uporabljaš. Človek je samo vprašal kak se pinga. Če bi vprašal kak porte scanat al pa kaj podobnega (recimo ta tema) bi ti mogoče opravičil, drugače pa :\.
P.S. Malo preveč si si vzel zadevo k srcu...
"I am not an animal! I am a human being! I... am... a man!" - John Merrick
Hekerski napad ohromil največjega norveškega proizvajalca aluminija
Oddelek: Novice / Varnost
138021 (6690) AštiriL
Potrjen standard Bluetooth 4.1
1813277 (9980) antonija
Kdo so "Hekerji" in kaj delajo
144680 (4305) Matri[X]
Hekerji (strani: 1 2 3 )
Oddelek: Programiranje
13314891 (6336) darkolord
Hacker vs Cracker
53045 (2845) Tr0n
