asp.net in AD
asp.net in AD
strel ::
kako naj se iz asp.net aplikacije dokopljem do Active directorija.
Zanima ma predvsem Ime in Priimek userja in member of.
Zaenkrat dobim podatke z NT prijavo
Dim MyIdentity As WindowsIdentity = WindowsIdentity.GetCurrent()
Dim MyPrincipal As New WindowsPrincipal(MyIdentity)
'Principal values.
Dim PrincipalName As String = MyPrincipal.Identity.Name
Dim PrincipalType As String = MyPrincipal.Identity.AuthenticationType
Dim PrincipalAuth As String = MyPrincipal.Identity.IsAuthenticated.ToString()
'Identity values.
Dim IdentName As String = MyIdentity.Name
Dim IdentType As String = MyIdentity.AuthenticationType
Dim IdentIsAuth As String = MyIdentity.IsAuthenticated.ToString()
Dim ISAnon As String = MyIdentity.IsAnonymous.ToString()
Dim IsG As String = MyIdentity.IsGuest.ToString()
Dim IsSys As String = MyIdentity.IsSystem.ToString()
Dim Token As String = MyIdentity.Token.ToString()
Tole zaenkrat dela npr : MyIdentity.Name vrne : Domena\username
C# INSERT statment ne vpise podatkov
Oddelek: Programiranje
111581 (1455) darkolord
ASP.NET pisanje datoteke
91402 (1280) King80
[C#] Prosim pomagajte! Potrebujem program, ki bi pobiral podatke iz ene strani
213232 (2842) David1994
[VB 2005] branje teksta
241991 (1659) mNeRo
API+VB
262573 (2277) webblod
