Forum » Pomoč in nasveti » 17˝ LCD Monitor
17˝ LCD Monitor
kalcek16 ::
Zanima me , če je res 17˝LCD Monitor enakovreden kakor navadni 19˝monitor? Zanima me v čem je enakovreden a po velikosti vidne površine al kaj?
JOKER ::
19" monitor ima vidno polje 17.8 , LCD 17" pa ima vidno polje 17.2 .
V četrtek sem kupil 17" LCD monitor in smo prav o tem debatirali z prodajalci in z mojstri,ki testirajo monitorje.Človek se pač pred nakupom mora vse pozanimat,ker te stvari niso pocen.
________________________________________________________
Ka te češ ....
Ka te češ ....
- spremenilo: JOKER ()
JOKER ::
Kupil sem : 17" LG FLATRON L1715S
Display Type 17.0" (17.2" VIS) color active matrix TFT LCD screen
Display Area 13.3" X 10.6" (338 mm X 270 mm)
Display Colors More than 16.1 Million (6 Bits + FRC)
Pixel Pitch 0.26 mm x 0.26 mm pixel
Pixel Configuration RGB vertical stripe
Surface Treatment Hard coating (3H), anti-glare
Electronic Interface LVDS
Backlighting 4 CCFL lamps
Maximum Resolution 1280 x 1024
Brightness 250 cd/m2
Contrast Ratio 450:1
Response Time
16 ms(Typical)
Viewing Angle H:160°, V:140°
Horizontal Scanning Frequencies 30-83 KHz, auto-synchronous
Vertical Scanning Frequencies 56-75 Hz, auto-synchronous
Auto Sync Support 640 x 350 up to 70 Hz
640 x 480 up to 75 Hz
720 x 400 up to 70 Hz
800 x 600 up to 75 Hz
832 x 624 up to 75 Hz
1024 x 768 up to 75 Hz
1152x870 up to 75Hz
1280 x 1024 up to 75Hz
Control Type On-screen display of adjustments
Input Signal RGB Analog
Sync Signaling Separate H/V
Input Connector Standard VGA D-Sub 15-pin
Memory Modes 13 factory preset, 10 user-settable
VESA Plug and Play Level DDC2B
Digital On-Screen Controls Brightness, Contrast, Horizontal/Vertical Position, Clock, Phase, Language Select, Color Temp (9300K, 6500K, User), OSD Information, Image Size, OSD Position, LightView
Front Panel Controls Power, Menu, Adjust (Up/Down/Left/Right), Auto-Select
Mounting (Arm assembly) VESA compliant for wall or arm mounting alternatives
Power Requirements 90-264 VAC, 47-63 Hz
DPMS Power Consumption On: 40 Watts
Stand-by: 3 Watts
DPMS Off: 3 Watts
Dimensions With Base (WxDxH) 15.2" X 6.0" X 14.7" (386mm X 152mm X 372 mm)
Shipping Dimensions (WxDxH) 17.2" X 6.6" X 18.7" (438mm X 167mm X 476 mm)
Weight Net: 9.5 lbs (4.3 Kg); 12.6 lbs. (5.7 Kg) Shipping
Safety/Regulatory TCO'99, MPR-II, UL1950, FCC-B, EPA Energy Star, IEC950, CE, TUV-GS, SEMKO, GOST, ISO 9241-3,7,8, C-TICK, VCCI-2
Accessories Power cord, Manual
Install Disk
Signal cable (15 pin D-sub to 15 pin D-sub)
Na to,da sem prej imel cevastega 19" ....
Glede nato,da je star komaj tri dni ti lahko rečem,da sem osupnil nad barvami in vsem ostalim.Dosti lažje berem stvari in barvna ostrina ...... nepopisno.
Res sem navdušen in ni mi žal.
Zgoraj je pa nekaj podatkov.
Response Time
16 ms(Typical)
1152x870 up to 75Hz
Stand-by: 3 Watts
DPMS Off: 3 Watts
Install Disk
Ka te češ ....
Ka te češ ....
| » | koliko bi dobil za Monitor LG Flatron 915FT Plus?Oddelek: Kaj kupiti | 1826 (1760) | Utk |
| » | Sempron 2400+ in A7S8X-MXOddelek: Navijanje | 2066 (1834) | Hardstyle |
| » | 1 nakup lcd monitorjaOddelek: Kaj kupiti | 2156 (1994) | raab himself |
| » | MonitorOddelek: Kaj kupiti | 1946 (1761) | jerry2000 |
| » | Kateri monitor?Oddelek: Kaj kupiti | 1949 (1800) | boštjan |
