Unattended install for Windows
Microsoft ::
Imam problem pri avtomatskem nalaganju Windowsev iz CDja.
Kreiral sem datoteko winnt.sif in jo shranil na disketo. Prakticno vse, kar sem nastavil in shranil v to datoteko, se med instalacijo izvede.
Samo mi pa se ni uspelo v ta fajl vkljuciti takega keya, ki bi recimo avtomatsko formatiral disk v NTFS (ali pa pustil disk "pri miru" in instaliral Winse na prvo particijo). Sedaj je tako, da morem sam nastavit, kaksen bo disk (stevilo particij, velikost posamazne particije, na katero particijo se naj instalira OS).
Gledal sem ze tudi navidila, ki so prilozena v DEPLOY.CAB datoteki (na CDju). Med drugim sem nasel tole:
FileSystem
Value: ConvertNTFS | LeaveAlone
Specifies whether the primary partition should be converted to NTFS or left alone.
Note If you plan to use ExtendOemPartition during Setup, set FileSystem = ConvertNTFS. For more information, see “ExtendOemPartition,” earlier in this document.
Zgled fajla, ki je pa na disketi, pa je taksen:
;SetupMgrTag
[Data]
AutoPartition="1"
MsDosInitiated="0"
UnattendedInstall=Yes
[Unattended]
ExtendOemPartition=1
UnattendMode=FullUnattended
OemSkipEula=Yes
OemPreinstall=No
TargetPath=Win2k
[GuiUnattended]
AdminPassword=***
AutoLogon=Yes
AutoLogonCount=1
OEMSkipRegional=1
TimeZone=95
OemSkipWelcome=1
[UserData]
ProductID=F6PGG-***...
FullName=****
OrgName=****
ComputerName=****
[Display]
BitsPerPel=32
Xresolution=1024
YResolution=768
Vrefresh=60
[Identification]
JoinWorkgroup=JimiBtn
[Networking]
InstallDefaultComponents=No
[NetAdapters]
Adapter1=params.Adapter1
[params.Adapter1]
INFID=*
[NetClients]
MS_MSClient=params.MS_MSClient
[NetServices]
MS_SERVER=params.MS_SERVER
[NetProtocols]
MS_TCPIP=params.MS_TCPIP
[params.MS_TCPIP]
DNS=No
UseDomainNameDevolution=No
EnableLMHosts=Yes
AdapterSections=params.MS_TCPIP.Adapter1
[params.MS_TCPIP.Adapter1]
SpecificTo=Adapter1
DHCP=No
IPAddress=192.168.0.2
SubnetMask=255.255.255.0
DefaultGateway=192.168.0.1
DNSServerSearchOrder=193.2.1.66,193.2.1.72
WINS=No
NetBIOSOptions=0
(Tam, ko so ***, je kej tazga, kar si jst ne bi zelel, da vi vidite...)
Zdele sem modificiral, in sem dodal ProductID. Bom videl, ce bo sedaj delalo. Samo tisto pa se kar ne dela, in moram sam manualno nastavit particijo... :(((
Naj se povem to, da sem enkrat uporabil key FileSystem = ConvertNTFS, drugic pa FileSystem = LeaveAlone, vendar je v obeh primerih bil rezultat enak. :(
Any ideja, kako naj popravim ta fajl, da bo delalo popolnoma avtomatsko?
by Miha
ToniT ::
Če hočeš, da ti bo na novo ustvaril particije, moraš dodati naslednji ukaz v
[Unattended]
Repartition=Yes
Microsoft ::
Sem dodal key in mislmi, da dela. 8-) Disk ze formatira, samo pocakat se morm tolko, da se vse ostalo naredi (kar pa prej tud je).
Drgac pa vse pise:
Repartition
Value: Yes | No
Specifies whether or not all partitions on the first drive on the client computer should be deleted and the drive reformatted with the NTFS file system.
Important Repartition is only valid when performing an unattended installation by booting the computer from the Windows 2000 CD.
Sam enkrat bom mogu jet cez cel dokument...:\
Next question.:D
V fajl sem dodal [Components], tam pa dodal vse mozne komponente; accessopt = on, calc = on, cdplayer = on,... Samo potem, ko mi je Winse instaliral, mi ni nalozilo vseh komponent. Zamislil sem si tako, da bi nalozilo poleg standardnih komponent se recimo Netwotrking Services, Other Network File and Print Services,....
Kater section header in keys bi pa tu moral dodati?:\
by Miha
[Windows XP] Vaš račun je potekel (strani: 1 2 3 )
Oddelek: Operacijski sistemi
11916090 (12925) fosil
Ubuntu -instalacija - particije
121779 (1639) BlaY0
Unattended install for Windows - beginner
61621 (1574) TitanSLO
Kako Command prompt-u 'povedat', da gre za presledek?
252290 (1928) hruske
W2k in folder properties
211292 (1161) andrej
