Kako bi lahko zaklenil le določene filee v windowsih?
skrc ::
Oj!
Zanima me če obstaja kak program s katerim bi lahko zaklenil le določene mape u winsih? Vem da bi lahko naredil še en account ki bi imel limited access, samo tega ne želim imeti, ker bi potem imel totalno "zbrko"... :\
že v naprej hvala in upam da kdo pozna rešitev za moj problem.
SanDLL
Hammer ::
File Securer
Opis:
File Securer is a powerful tool designed to protect your sensitive folders and personal files. The program includes some strong security, embedding the protection into the Windows system kernel, both in command mode and windows mode.
With exceptional ease of use, File Securer enables you to hide your folders and files anywhere. The locking and unlocking object functions are integrated with the system pop menu. Simply select the object, click the right mouse button, then click 'lock' or 'unlock', that's all!
Should someone try to access your locked object, the system will say "Sir, give me your password please!", and the tools will record all the error passwords and win-user, then report to you.
Key features:
* Hide and lock your personal folders and files on Windows system kernel
* Password to prevent other users and hackers access
* Integrated with system pop menu
* Drag and Drop method locking object support
* Protected folder and file list check
* Settings wizard support
* All activities are logged
* Password recovery
* Password required for uninstall
skrc ::
Najlepša hvala za tole:)
Skype problem
Oddelek: Programska oprema
81852 (1257) tv6865
Ne morem dostopati do folderja
5853 (813) medenko
Šifrirana mapa
Oddelek: Operacijski sistemi
92831 (2302) amigo_no1
Internet explorer se ugasa - sam od sebe... HELP !
102086 (1974) jarni2
Kako v Win2k premakniti mapo Documents and Settings?
62526 (2492) Mercier
