HardOCP - Sicer smo pred kratkim na Slo-Techu že imeli test grafičnih kartic, za katerega se je naš bwana Sergio pošteno namučil ([:P]), a vendarle ... Na [H]ardOCP so včeraj stestirali ATI-jevega najnovejšega Radeona, različico 9500 Pro. Različica Pro se od svojega ne-Pro bratca razlikuje samo po številu cevovodov (štiri proti osem), medtem ko je njun takt enak. V kolikor vas mika nova grafična kartica, klik!
Novice » Grafične kartice » Radeon 9500 Pro
_Mortal_ ::
So while UT2003 may say “NVIDIA, the way it was meant to be played”, ATI shows us that the 9500 Pro is actually the better card to have if you want excellent performance with quality graphic settings when compared to the Ti 4600.
Is reading in the bathroom considered as multi-tasking?
ghibly ::
However, in our tests the 9500 Pro is able to outperform the Ti 4200 in everything: no anti-aliasing, anti-aliasing, and anti-aliasing with anisotropic. In fact, it's close to the Ti 4600 with no anti-aliasing and no anisotropic. Once you enable AA or AF, however, the 9500 Pro just takes off and outperforms the Ti 4600!
krho ::
in jest mam cajt čakat da bodo pr atiju spacal skup softver za AIW oz. za tuner ki ne bo rusil winXP oz. bo vsaj delal.
ENO LETO SO NUCAL DA SO SPACAL DRIVERJE ZA WINDOWSE XP jih en K... gleda. NO MORE ATi.
| » | AMD R670 in R680Oddelek: Novice / Grafične kartice | 4719 (3219) | dukenukem |
| » | Nakup AGP grafične karticeOddelek: Kaj kupiti | 1544 (1374) | Sami |
| » | Ati Radeon 9600 pro?Oddelek: Kaj kupiti | 3535 (2697) | DeadMeat |
| » | Radeon 9800 proOddelek: Novice / Grafične kartice | 3373 (3373) | Radiant |
