Forum » Operacijski sistemi » Kriv MBR?
Kriv MBR?
Sims ::
Zdravo,
imam 2 systema linux Mandrake in Windows 2003
Nekako mi lilo poka?e oba sistema, ko pa zberem winse se pa ne za?enejo.... linux pa deluje.
Vredu sem dal fdisk /mbr ob bootu napise (mysing operating system). Ok, bootam winse s CD ja in formatiral c (je bilo ?e potrebno ...) Ko nalo?i systemske file se winsi resetirajo .. nato pa ...
napaka:
"error loading operating system "
ko bootam z linux CD ja dam update in mandrake lilo se spet postavi in linux deluje
nekako ne spravin windowse v pogon ... upam, da sem razumljivo napisal ...
LP,
Sims
napaka:
LP,
Sims
Sims ::
# File generated by DrakX/drakboot
# WARNING: do not forget to run lilo after modifying this file
boot=/dev/hda
map=/boot/map
install=menu
default="linux"
keytable=/boot/slovene.klt
prompt
nowarn
timeout=100
message=/boot/message
menu-scheme=wb:bw:wb:bw
image=/boot/vmlinuz
label="linux"
root=/dev/hda8
initrd=/boot/initrd.img
append="devfs=mount acpi=ht resume=/dev/hda7 splash=silent"
vga=788
read-only
other=/dev/hda1
label="Windows_2003"
table=/dev/hda
image=/boot/vmlinuz
label="linux-nonfb"
root=/dev/hda8
append="devfs=mount splash=silent acpi=ht resume=/dev/hda7"
read-only
image=/boot/vmlinuz
label="failsafe"
root=/dev/hda8
append="failsafe splash=silent acpi=ht resume=/dev/hda7 devfs=nomount"
read-only
lilo.conf
za fdisk bom pa spet bootal v dos in napisal .. samo grem v kino, bom to kasneje naredil ... Hvala!
boot=/dev/hda
map=/boot/map
install=menu
default="linux"
prompt
nowarn
timeout=100
image=/boot/vmlinuz
label="linux"
root=/dev/hda8
vga=788
read-only
other=/dev/hda1
table=/dev/hda
image=/boot/vmlinuz
label="linux-nonfb"
root=/dev/hda8
read-only
image=/boot/vmlinuz
label="failsafe"
root=/dev/hda8
read-only
lilo.conf
- spremenil: Sims ()
Sims ::
Disk /dev/hda: 60.0 GB, 60022480896 bytes
16 glav, 63 sektorjev/stezo, 116301 stez
Enote = cylinders od 1008 x 512 = 516096 bajtov
Naprava Boot Start End Blocks Id System
/dev/hda1 * 1 20321 10241406 7 HPFS/NTFS
Razdelek 1 se ne kon?a na meji stez.
/dev/hda2 20321 116301 48374266+ f W95 Ext'd (LBA)
Razdelek 2 se ne kon?a na meji stez.
/dev/hda5 20321 22361 1028128+ 7 HPFS/NTFS
/dev/hda6 22361 71576 24804328+ 7 HPFS/NTFS
/dev/hda7 71577 73680 1060384+ 82 Linux swap
/dev/hda8 73681 116301 21480952+ 83 Linux
lol, pardon
imam 3 ntfs particije (c,d,e) d(hda5(, e(hda6) ne smem zgubit ... za ostalo mi je vseeno ...
torej naj bi mel 3 NTFS eno swap in ext2 nekako ni temu tako ... kolko vidim
lol, pardon
ghibly ::
Imel sem isti problem MBR-ja z mandrake 10 in windowsi, ko sem MBR namestil na disk. Potem sem dal lilo na disketo in bootal iz Floppy-ja in je štartalo vse normalno - tako linux, kot windows.
Sims ::
problem je, da sem particijo c ?e sformatiral ... ko pa ho?em winse nanovo nalo?it pa ob prvem resetu javi da ne more nalo?it systema. ?e sem prav razumel bi naj dal lilo na disketo, problem je, da nimam disketnika
lahko bi ga probal dat na CD? ?e ja, kako? tega ?e nisem po?el ...
Hvlala.
LP,
Sims
Hvlala.
LP,
Sims
CaqKa ::
Sims ::
Hvala vsem, se opravičujem, da se sedaj komaj javljam ... Pozabil sem si nastavit, da mi pošlje mail ob odgovoru.
Sem rešuil zadevo z low level format
Sem poskušal v repair conzoli, ni pomagalo, sem na koncu disk nesel sosedu in probal z PM8 in ni hotel formatirat in nič, nato sem popucal particije v win2003 cd ju in ni naredil 1 neparticiran priostor tmveč 2 ... Pol sem se pa razjezo pa namontiral dikstnik in low level format ... podatke sem pred tem presnel na sosedov comp. in sedaj je vredu.
CaqKa ::
mam občutek da bom jaz tudi moral počasi nekaj podobnega ubrat ker mi tak mbr j*** da je kuj hudo :) morem najt dovolj velik disk za backup.
spet čečkam v slotech linuxu ker nimam drugega :)
| » | dual boot xp/ubuntuOddelek: Operacijski sistemi | 2300 (2181) | misek |
| » | Kako instalirati Linux in xp?Oddelek: Operacijski sistemi | 2722 (2643) | Blinder |
| » | Dva diska, dva OS, en GRUB -> kako izklopit grub in linuxOddelek: Operacijski sistemi | 2288 (2126) | zee |
| » | LILO -- kako spremeniti boot zaporedjeOddelek: Operacijski sistemi | 1613 (1460) | BigWhale |
| » | Gentoo Linux - bootanjeOddelek: Operacijski sistemi | 1855 (1742) | jaBo |
