XP firewall - nastavitve ?
Cokolesnik ::
Uporabljam firewall v XPjih in me zanima, kje bi lahko nastavil določen IP range ali kakorkoli drugače nastavil, da bi imele mašine z IPji 192.168.x.x poln dostop (četudi je firewall vklopljen) - za tiskalnike/datoteke v skupni rabi recimo?
Verjetno streljam v temo? Sodeč po temle prispevku na enem od forumov: Firewall Note: In the LAN Connection Properties, there is an Advanced tab. Within this, you have the option to enable XP's built-in Internet Connection Firewall. ( A little padlock icon appears on the connection ). Do NOT enable ICF on your LAN card, or you will kill file and print sharing on your LAN stone dead. ICF is not configurable to permit your local subnet as a trusted zone. It's an 'all-or-nothing' kind of a thing. If you feel the need for a firewall in addition to the inherent protection provided by the router, then look to one of the popular commercial products, some of which offer a free downloadable version. These are configurable, and can be set to permit normal file and print sharing on your LAN whilst blocking external connections and also block malware from calling out without your consent.
Uporabniki naj pred pisanjem sporočil uporabljajo iskalnik www.google.com.
Čokolešnik ne vsebuje nobenih aditivov, konzervansov ali umetnih barvil.
Kako ranljiv je računalnik v internetu?
111985 (1546) fiction
Mreža ne dela!
5960 (938) kacza
pohitritev dsl ali kabelskega neta v win xp
Oddelek: Omrežja in internet
62177 (1915) BlueRunner
nastavljanje omrežja
61605 (1483) Wannabi
MREŽA
Oddelek: Programska oprema
151935 (1740) bojan1
