File delete --> access is denied --> ?
Alen T 1978 ::
Kako najlažje ugotoviti, kateri program uporablja določen fajl. Obstaja kak "files in use" viewer. Sploh bi mi to prav prišlo, ko v TaskManagerju ni programa, ki ga sumim.
Na primer: danes sem z NeroImageDrive naložil nek .iso file, ga nato ejectal, in nato hotel zbrisat. Pa žal ni šlo, zaradi "Access is denied". Pol sem šu pa u explorerja, stisnu F3, poiskal vse .exe fajle v nero dir in pogledal, če se kateri nahaja v TaskManagerju, kjer na moje začudenje ni bilo nobenga.
V glavnem, kako naj rešim ta in temu podobne probleme. Da se z reštartom, sam zarad vetrocvetk nebi to počel kar naprej. Prosim, če mi kdo pomaga, ker bom mogu upgrejtat živce.
PS. najprej bi prosu za softverski nasvet, potem hardverski (u smeti)...
  • spremenil: gkovac ()
Pyr0Beast ::
msconfig, regedit, CTRL-ALT-DEL
cookie ::
ponavadi dela, ce zalaufas command prompt pa nardis del. file.*
  • spremenilo: cookie ()
Tr0n ::
To se tudi dogaja pri audio in video datotekah zaradi vgrajenega previewa.
Unable to Delete AVI Fix.
Open regedit and go to:
HKEY_CLASSES_ROOT\SystemFileAssociations\.avi\shellex\PropertyHandler
Delete the value you find there.
HKEY_CLASSES_ROOT\SystemFileAssociations\audio\ShellEx\ContextMenuHandlers\WMPAddToPlaylist
HKEY_CLASSES_ROOT\SystemFileAssociations\image\ShellEx\ContextMenuHandlers\ShellImagePreview
HKEY_CLASSES_ROOT\SystemFileAssociations\video\shellex\ContextMenuHandlers\WMPAddToPlaylist
And so on.
Any entry in the ContextMenuHandler key will override whatever you try and do, there's no easy way of telling it you want a different default option.
This leaves us with deleting these keys as a final solution. As always, back up your registery before doing any changes.
Caligula ::
Al pa gres v nerota pa tam najdes file in ga deletas.
Meni to vedno dela in se mi sploh ne da drugace zafrkavat. RAZEN ce uporabljas kak Alcohol 120 ali kaj takega in je file ravno nalozen na virtual drive.
Čiščenje kontekstnega menija
81902 (1745) gzibret
Ikone w widows xp so izginile !!!
202502 (2220) K0K0
Kako izbrisati datoteko ?!??!
333060 (2659) ahriman
Kako izkljucit preview media datotek v explorerju?
Oddelek: Operacijski sistemi
61324 (1235) bf4ed
Windows XP in AVI datoteke
183973 (3973) AtaStrumf
