U4GM: How to Create a Balanced Tight End in College Football 27
Sjolund ::
Building the perfect tight end in College Football 27 Dynasty Mode is more complicated than simply recruiting a fast player with good hands. After experimenting with different positions, archetypes, and skill upgrades, one important lesson becomes clear: finding the right balance between receiving ability and blocking strength requires careful planning. Whether you are developing prospects with CFB 27 Coins or focusing on smart recruiting decisions, understanding how each archetype works can help you create a much more effective tight end.
Why Converted Wide Receivers Aren't Perfect Tight Ends
Keenan Jackson is a good example of why converting a wide receiver into a tight end does not automatically produce an ideal all-around player. He has excellent speed, acceleration, and route-running ability, making him a dangerous receiving option. However, his conversion places him into the Vertical Threat archetype.
This creates a major problem when developing his blocking ability. Although you can improve his regular run-blocking rating, his run-block power and run-block finesse remain extremely low. These attributes are essential for winning physical matchups against defensive players.
The opposite problem appears with traditional blocking tight ends like Ryan Woler. He offers considerably better blocking ability than Jackson, but his receiving skills are much weaker. His speed, route running, and catching ratings make him far less dangerous as a passing option.
These two players represent the biggest challenge when building a complete tight end: receiving ability and blocking strength are difficult to develop together.
The Four Most Important Tight End Attributes
There are four key areas to consider when evaluating a tight end:
- Athleticism: Speed and acceleration determine how effectively the player can create separation.
- Route Running: Good routes help the tight end become a reliable passing target.
- Hands: Catching ability is important for securing receptions, especially in traffic.
- Blocking: Run blocking, run-block power, run-block finesse, and impact blocking determine how effective the player is in the running game.
All four attributes contribute to a balanced tight end. However, the way EA organizes skill upgrades makes certain archetypes much better suited to specific roles.
Why Pure Blockers Have a Major Advantage
Among the available tight end archetypes, Pure Blockers stand out because all four important blocking attributes are included in their upgrade group. This means investing skill points into their blocking development can improve more than just the visible run-blocking rating.
Testing also reveals that certain hidden ratings improve when upgrading this group. Run-block power, run-block finesse, and impact blocking can benefit from these upgrades, making Pure Blockers particularly valuable for players who want a dominant running game.
However, their biggest weakness is athleticism. Pure Blocker tight ends generally start with much lower speed than receiving-focused archetypes. For example, improving a player from 72 speed to 90 speed requires an enormous investment of skill points.
You can upgrade their catching and route running, but their limited athleticism makes it difficult to turn them into explosive receiving threats.
Why Position Conversion Doesn't Solve Everything
One possible solution is converting fast players from other positions into Pure Blocker tight ends. A wide receiver with 90 speed and acceleration would seem like an excellent starting point.
Unfortunately, position conversion has several limitations.
First, some players have poor skill caps. North-South Blocking running backs, for example, can offer decent speed when converted to tight end, but their route-running and catching potential is often limited. Even with substantial investment, reaching 75 in those receiving attributes can be difficult.
Second, EA calculates a player's overall rating for different archetypes when determining their new position. The game considers the weighted attributes associated with each archetype. Since Vertical Threat tight ends prioritize speed, acceleration, and catching, converted wide receivers usually become Vertical Threats instead of Pure Blockers.
Experiments with athlete linebackers and other converted players also produced inconsistent results. Even when some players successfully became Pure Blockers, their skill caps often prevented them from developing into complete receiving options.
The Best Strategy for Building a Complete Tight End
When comparing different archetypes with equal skill-point investments, Pure Blockers provide the best overall balance across the four major categories. Other archetypes can perform extremely well in athleticism, route running, and catching, but their blocking development usually falls significantly behind.
This does not mean every team should recruit only Pure Blockers. Instead, the smartest approach is to build a tight end room with two different specialists.
First, recruit a fast Pure Blocker whenever possible. Prioritize prospects with strong starting speed, then develop their blocking attributes while investing remaining points into catching and route running.
Second, keep a converted wide receiver as your receiving-focused tight end. This player can stretch the field, create mismatches against linebackers, and provide another dangerous option in passing situations.
The ideal setup is not necessarily one player who does everything. Having two tight ends with complementary strengths gives your offense more flexibility and makes it harder for opposing defenses to predict your next move. When recruiting in Dynasty Mode, prioritize the fastest Pure Blocker prospects available rather than trying to transform an entirely different archetype into something it was never designed to be. With smart development and the right cheap NCAA 27 Coins resources, you can build a tight end rotation that supports both an effective passing attack and a powerful running game.
Buy College Football 27 Coins with confidence at U4GM.com, a reliable marketplace for CFB 27 Coins and NCAA 27 Coins. Enjoy fast, secure delivery for PS, Xbox, and PC, along with responsive 24/7 live customer support to ensure a smooth and convenient shopping experience. Have fun on the field!
Predlogi novic (strani: 1 2 3 4 … 50 51 52 53 )
Oddelek: Slo-Tech
2621527243 (1172) MrStein
For Honor (strani: 1 2 3 )
Oddelek: Igre
14727707 (2430) oo7
Manj znane igre (strani: 1 2 3 4 )
Oddelek: Igre
15049235 (21975) D3m
Super Bowl 2019
241966 (1576) jb_j
Valve & STEAM & On-Line gaming (strani: 1 2 )
Oddelek: Igre
719981 (8403) Tilen
