*** propad vzhoda
*** propad vzhoda
3 4
5
Task Force Iron Gate: CENTCOM Launches Task Force to Disrupt Iranian Ground Transit Routes Supporting Illegal Shipments
TAMPA, Fla. — On Nov. 7, the commander of U.S. Central Command (CENTCOM) directed the establishment of a task force that will support ongoing U.S. government efforts to prevent Iran from using ground routes to transport advanced weapons and other materials.
Adm. Brad Cooper has directed the formation of Task Force Iron Gate, an internal staff of approximately 20 civilian and military personnel based in Tampa, Florida. The new CENTCOM team will coordinate with other U.S. government agencies on preventing the movement of advanced weapons systems, dual-use technologies, sanctioned materials, and illegal revenue streams across Iran's land borders and the Caspian Sea.
"The establishment of Task Force Iron Gate reinforces the success of our ironclad blockade against Iran at sea," said Cooper. "Strengthening CENTCOM's collaboration with U.S. interagency partners will further constrain Iran's ability to finance terrorism, rebuild weapons factories, and replenish their military."
In recent months, America's naval blockade has prevented Iran from exporting more than $25 billion in crude oil. Strict enforcement at sea continues against all ships entering or departing Iranian ports.
https://x.com/CENTCOM/status/2119059918...
Spet je začelo pokati po Iranu/QESHM otoku plus zdaj imajo poleg zračne in pomorske blokade še kopensko. Pa ZDA so ravnokar onesposobile še eno iransko ladjo ker ni upoštevala blokade:
https://x.com/CENTCOM/status/2119167271...
Propad Irana oziroma države ki naj bi spadala pod vzhod
  • spremenilo: Chalky ()
Iran vsak dan pretrese ladjo ali dve, ki ne ubogata. US še zalive ne more nadzorovati 30km, kako bo tisoče km kopenske meje... ali se bo F35 skril za goro in koordiniral... se spomniš te zgodbice tvoje :))
Chinalky ::
Goran10 je izjavil:
Pa itak če bi Kitajska hotela konkurirat Zda bi partija morala predati del moči kapitalu a mu raje pristriže peruti v obliki omejitev posledično država stagnira to pa maskira s pofejkano statistiko.
Nekritični in vse bolj histerični zahodni analitiki ter proameriški apologeti se utapljajo v lastni propagandni iluziji, ko si domišljajo, da Kitajska gospodarsko stagnira in svojo moč napihuje z lažnimi statistikami, ob tem da so tovarna za cel svet, konstantno se pa krepijo še na drugih področjih. Ta kratkovidni diskurz povsem ignorira neizprosna dejstva na terenu: medtem ko Washington izgublja stik z realnostjo, kitajski proizvodni imperij v resnici obvladuje skoraj celotno globalno industrijsko proizvodnjo in zagotavlja stabilnost svetovnega gospodarstva. Ta ideološka zaslepljenost Amerike izvira iz nemoči pred tehnološkim in industrijskim razcvetom Pekinga.
Ključni stebri kitajskega zmagoslavja nad zahodno dekadenco:
• Industrijski titan: Kitajska ne proizvaja le osnovnih dobrin, temveč diktira tempo na področju visokotehnoloških rešitev, mikročipov, robotike in električnih vozil.
• Strukturna premoč: Kitajski dolgoročni strateški načrti delujejo z matematično natančnostjo, medtem ko je ameriški sistem ujet v cikle političnega kaosa in kratkoročnega populizma.
• Svetovna odvisnost: Poskusi ekonomskega "ločevanja" (decoupling) s strani Washingtona so se izkazali za farso, saj svet brez kitajske tovarne sploh ne more več funkcionirati. Zahodno samozavaravanje o domnevnem "kitajskem zatonu" je zgolj psihološki obrambni mehanizem imperija v zatonu, ki nemočno opazuje, kako Kitajska s svojo delavnostjo, disciplino in vizijo neustavljivo prevzema vlogo vodilne svetovne sile.
  • spremenilo: Chinalky ()
Chinalky ::
ZDA ponujajo milijonske denarne nagrade za informacije o iranskem jedrskem programu, kar v mednarodni skupnosti odpira več komičnih vprašanj kot pa resnih obveščevalnih podatkov. Ta najnovejša poteza Washingtona deluje skoraj absurdno, ko jo postavimo v kontekst bližnjevzhodnega dogajanja in pregovorne "vsevednosti" ključnih akterjev.
Kje se je zataknilo na liniji Tel Aviv – Washington?
Prva logična misel ob branju te novice je: Ali Benjamin Netanjahu in Mossad sploh še odgovarjata na telefon?
Izraelska obveščevalna služba Mossad se že desetletja hvali s tem, da pozna vsak vijak, vsako centrifugalno napravo in vsak kozarec čaja, ki ga popijejo iranski jedrski fiziki v podzemnih bunkerjih v Natanzu. Še več, Benjamin Netanjahu že skoraj petnajst let z matematično (ali pa umetniško) natančnostjo svetovni javnosti neutrudno riše grafikone in rdeče črte ter vedno točno ve, da je Iran od atomske bombe oddaljen "le še nekaj mesecev" ali "nekaj tednov".
Če ima Netanjahu v svojem kabinetu stalno vklopljeno jedrsko štoparico, Mossad pa v predalu celoten katalog iranskih skrivnosti, zakaj mora Bela hiša zdaj javno ponujati denar naključnim žvižgačem?
Možnosti sta le dve:
• Tehnične težave: Netanjahu je preveč zaposlen z nastavljanjem svoje jedrske ure, Mossad pa ima morda slabo mobilno omrežje v kleti svojih varovanih stavb.
• Čisti kapitalizem: Izrael morda preprosto čaka, da ZDA dvignejo nagrado na "pravo ceno", preden ameriškim zaveznikom končno razkrije naslednji dramatični datum.
enavlaka ::
Hvala ChalkyGPT za te udarne novice
Goran10 ::
Chinalky je izjavil:
Goran10 je izjavil:
Daj poglej kaj si kitajski in globalni kapital misli o kitajski. Kitajska je stagnacija Japan style. Vrednotenja kitajsih podjetij stagnirajo.
Heh. Stagnirajočih :))
Goran10 ::
Koliko je vredna Kitajska najbolke vedo tisti ki so na njo položili denar. Kitajski simpi se pa itak izobražujejo na socialnih omrežjih.
Stane2 ::
Pri kitajski demografiji vidimo, kako to laufa z "matematično natančnostjo"
Pol greš pa na eno kislo-pekočo juho ane. :)
Goran10 ::
D3m je izjavil:
Mislim da največjo pekočino ćutijo investitorji v Kitajsko. Izgube sploh pa oportunitetne so ogromne. A kitajski indexi sploh sledijo neki povprečni inflaciji zadnjih 20 let?
USS Theodore Roosevelt Arrives In Singapore Last Stop Before Third Carrier Strike Group Reaches The Middle East
CSG USS Theodore Roosevelt je ravnoakar vstopil v Bengalski zaliv. Iran ima še točno 1 teden da se preda.
Goran10 ::
Mogoće bi se Iran predal če bi bil predsednik Zda nekdo drug. Ne bodo se pa Iranci predali luzerju ravno tako kot se Ukrajinci ne bodo predali luzerju Putinu.
Predaš se zmagovalcem.
Ne luzerjem.
  • spremenilo: Goran10 ()
Na srečo niti vleče Pentagon ter vojska je pa res da bi lahko bila ta operacija v Iranu končana že 5 mesecev nazaj če bi takrat dokončali vse skupaj. Vendar ker je bil Trump obseden z Nobelovo nagrado in bluzil o tistem brez predmetnem MOU ki se ga tako nihče nebi držal je potem popustil in zato plačal visoko celo preko vmesnih volitev kjer so zasluženo izgubili. Bush ni bil ravno pameten ampak je pa točno vedel kako se porazi državo in je bil dovolj odločen da je to tudi storil. Če greš notri, potem dokončaj delo ne pa da si neodločen.
Sicer je Iran vojaško in gospodarsko premagan ampak je zdaj potrebno dobiti še tisti uran. Iran je zaprt tako po morju kot zraku in po kopnem. Vse meje okoli so zaprte imajo popolno blokado iz vseh strani in nimajo nobenih vojaških zmogljivosti več.
Ko bodo prižgali zeleno luč za končni udarec vse skupaj nebo trajalo več kot 2 oziroma 3 tedne. ZDA imajo v teatru skupaj z zavezniki preko 1000 bojnih letal ter 30 vojaških ladij ki nosijo preko 2000 raket vseh vrst. Cena nafte je pa tudi šla strmo navzdol.
C&C Generals :D
Goran10 ::
Bush je laufal na krilih 11 spetembra Trump pa tega nima. Že tukaj ga zjebe. Nima fundamenta. Bush bi namesto Trumpa verjetno finiśiral Ruse v Ukrajini saj je tam fundament za zunanjo politično zmago. Odlična ukrajinska pehota in na sploh ua deluje organizirano. V iranu pa ni pehote ni organzirane opozicije režimu. Trump je kot pravi luzer izbral napačno zunanje politično prizorišče.
Goran10 je izjavil:
Ne luzerjem.
Odlična analiza, za 5-letnika.
Goran10 ::
Fritz je izjavil:
Goran10 je izjavil:
Ne luzerjem.
Ja to situacijo tudi 5 letnik razume. Samo Putinovi feni ste izgleda na nivoju 4 letnika.:))
enavlaka ::
Ljubilci diktatorjev ameriških ali ruskih so vsi isti
3 4
5
Propad ZDA - Odštevanje (strani: 1 2 3 4 5 6 )
Oddelek: Problemi človeštva
25025462 (3071) enavlaka
Lestvica: Največje Svetovne rezervne valute 2026 (Dollar #1) (strani: 1 2 )
693219 (858) razor1911
