Artemis II
Artemis II
KBraneK007 ::
Artemis II bo prvi poskusni polet s posadko raketnega sistema Space Launch System in vesoljskega plovila Orion okoli Lune.
Če bo vse po sreči se bodo 8. februarja prižgali motorji na raketi, katera ima drug namen za človeštvo kot pa uničevanje ipd.
Tukaj lahko dobite boarding pass:)
https://www3.nasa.gov/send-your-name-wi...
"We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard." J.F.K.
Malajlo ::
Torej danes ponoči štart?
makucv ::
Tukaj imaš vse zelo izčrpno napisano:
https://www.rtvslo.si/znanost-in-tehnol...
M.B. ::
Upam da se Challenger ne ponovi ampak zgleda ni daleč.
The OIG identified three issues that could potentially kill the crew on Artemis II:
Heat shield spalling.
Impact from heat shield fragments.
Bolt erosion.
So Orion had come back from the moon with damage severe enough to kill a crew three different ways. Not good!
In a nutshell, heat shield expert and Shuttle astronaut Charles Camarda, the former Director of Engineering at Johnson Space Center argues that NASA is demonstrating the same dysfunction that led to the Columbia and Challenger disasters. Faced with an unexpected engineering failure, it has built toy models to convince itself that the conclusion it wants to reach (it's safe to fly) are supported by evidence. These toy models are not grounded in physics, but because they appear to be quantitative, they create a false sense of security and understanding, an epistemic fig leaf for management to hide behind.
Put more simply, NASA is going to fly Artemis II based on vibes, hoping that whatever happened to the heat shield on Artemis I won't get bad enough to harm the crew on Artemis II.
driftwood ::
Ali bi raje šli na luno ali v podmornico?
Veliko sreče želim nasi pri izstrelitvi rakete. :))
blay44 ::
Upam, želim jim tehnično popolnost, malo sreče in božje pomoči.
V vesolju si bodo itak morali pomagati sami.
Razen preverjenih motorjev rd25 iz šatla se spet postavlajo mejniki prihodnosti.
Mobijo bodo šli proti IR komunikacji. Najbž z mini baznmi postajami. Še špegat
nauš več mogu:D.
Lunar Laser Communication Demonstration @ Wikipedia
A kdo ve še kaj več od tehnike. Menda je tud evropske veliko.
DamijanD ::
driftwood je izjavil:
luna itak - je pa odvisno od globine podmornice.
energetik ::
Sam takoj izberem luno in ne podmornice. V tisto kišto pod vodo me nihče ne spravi.
V vesoljskem plovilu greš po gobe vsaj z veličastnim razgledom, če gre kaj narobe.
vires in numeris
Pod vodo si hitrej fertik. V pozitivnem smislu.
energetik ::
Ni nujno. Lahko se počasi dušiš v kakšnem zračnem žepu v temi in mrazu.
V vakuumu te zmanjka v par sekundah, brez bistvenega neudobja. Pa hkrati lahko imaš nor razgled.
vires in numeris
EU_zamašek- ::
A te ne bo nič premetavalo? Saj ni nujno, da boš imel pogled na modro frnikolo skozi lino vesoljskega plovila ... Tudi zvočnih efektov ne bo.
KBraneK007 ::
Prispeli so v lunino orbito:)
Morning routine: Wake up, shave, make the bed, witness something that's never before been seen by human eyes.
The Artemis II crew is preparing for today's lunar flyby, when they will see the Moon's far side.
Flyby ni orbita. Ampak ja, dobili bomo nekaj fotk.
Upam, da bo misija uspešna in da se astronavti varno vrnejo. :D
KBraneK007 ::
Kako pa se bodo obrnili, da bodo lahko leteli nazaj proti zemlji?
driftwood ::
zato pa imajo volan vgrajen v plovilu
KBraneK007 je izjavil:
Lunino gravitacijsko polje. Ampak kolikor vem ponavadi besedo orbita uporabljamo v smislu trajektorije, ki omogoca krozenje okoli telesa. Zato tudi uporaba besede "flyby".
KBraneK007 ::
Drži. Uporabili so free-return trajektorijo.
New record
The Artemis II astronauts are now farther from Earth than humans have ever been! At 1:57 p.m. EDT, they broke the record set by Apollo 13 in 1970.
Their journey around the far side of the Moon today will take them a maximum distance of 252,752 miles from Earth.
NASA
Strel455 ::
  • spremenilo: Strel455 ()
Bellator ::
V napačni temi pišeš.
Kmalu se bodo vrnil nazaj na zemljo. Upam, da bo šlo vse brez problema.
Zanimiva primerjava trajektorije vs. Apollo 11 in 13:
https://x.com/CuriosityonX/status/20422...
  • spremenil: c3p0 ()
mihor ::
mtosev je izjavil:
https://issinfo.net/artemis
Vidim, da so se varno vrnili. Super.
Artemis II gre nazaj v hangar na servis
215021 (2397) BT52
Približuje se povratek na Mesec
265054 (2928) nekikr
Mednarodna vesoljska postaja dopolnila četrt stoletja
226523 (4563) T_F_7
Artemis I
221749 (858) xseki
