Rodnost strmoglavo pada po vsem svetu
Kayzon ::
Svetovna rodnost je strmo padla tako v razvitih državah kot v državah v razvoju in raziskovalci ne vedo, kaj je vzrok (Problem presega ženske, ki dajejo prednost izobrazbi in karieri pred družino).
Tudi če bi vlada začela oglaševati kampanje za rojstvo otrok, ne bo imelo veliko efekta pri reševanju prihajajoče krize. Nekatere države, kot sta ZDA in Japonska, so to opazile in nemudoma ukrepale z uvozom "delovno sposobnih" Indijcev, ampak države kot so Indija prav tako doživlja upad rodnosti..
https://www.theguardian.com/world/artic...
https://www.healthdata.org/news-events/...
Kaj menite da je vzrok tega? Ali se zgodovina ponavlja?
“There is considerable evidence to show that Roman society in the late Republic and early Empire was afflicted by a low birthrate. Augustus in 18 B.C. found it necessary to pass the lex Iulia de maritandis ordinibus in the hope of raising the birthrate by penalizing the unmarried and the childless. In 9 A.D. he attempted to supplement this law with the lex Papia Poppaea. The very existence of this legislation indicates that the problem of childlessness was widespread and long-Iasting, a view which is further supported by references to this subject in Latin literature.
Augustus's attempt to raise the birth-rate did not lack precedent in Roman history. Valerius Maximus teils the story that the censors Camillus and Postumius, as early as 403 B.C., had fined elderly bachelors for failing to marry and sire children and Metellus Macedonicus, censor in 131 B.C., made a speech urging men to marry and procreate, which was read out to the Senate by Augustus in support of his own legislation. However it seems unlikely that Augustus's attempts to solve the problem were very successful. Tacitus states explicitly that they were not, and in view of the fact that the Augustan legislation was reinforced by Domitian and reenacted in the second and third centuries A.D., it seems that the low birthrate continued."
Vzrok je, da evolucija deluje.
Ko družba doseže stopnjo blaginje, ki je zmožna vzdrževati individualnost, pride do upada rojstev. To upam da je nekako samoumevno.
Družbe, kjer individualnost (še) ni mogoča ali jo ne podpirajo, s tem nimajo težav.
Vzrok je, da so ugotovili da so lahko revni brez da imajo froce.
Orng davčne olajšave za starše, pa bo rodnost šla v luft.
Ja seveda.
CiClon ::
Sej Madžarska zmeče ogromen denar za starševske spodbude pa nič ne pomaga.
Glede na to, da je to več ali manj globalna težava, so se vse te "preproste" rešitve že kje uporabile pa vseeno ni haska.
Krejzi babe. Folk nima več živcev.
Kurzweil ::
Če bi si država resnično želela izboljšati rodnost, recimo v Sloveniji, ima za to številne vzvode. Recimo davčne olajšave, rešitev stanovanjskih težav, višji otroški dodatki, večja zaščita v službi, predvsem pa bolj humani pogoji za samozaposlene, da ne naštevam v nedogled. Ampak za to je treba dati nekaj denarja na mizo in si dejansko želeti. To je stvar, ki se rešuje na dolgi rok in vemo, da ima politika rada stvari, ki ima instant učinke.
Sicer pa glede na to, da vedno bolj obremenjujemo planet, je overall že prav, da se to dogaja, to je tudi stvar človeške evolucije, kot je že nekdo pred mano omenil.
V razvitih državah pač ljudje malce več razmišljajo v smeri izobrazbe, varnosti, kariere... v razvitih državah bi rekel, da je tudi vedno več individualizma, recimo Japonska je en takšen primer, je na to temo tudi nekaj dokumentarcev. Pač v "razvitem" svetu precej ljudi zelo tehtno premisli preden si zamisli otroka.
Je pa bilo pri nas včasih tudi tako, da je bilo po 10+ več otrok, ker je bila v prvi vrsti potrebna delovna sila in prav to je generiralo potem sirote in podobno, kar se dogaja v teh manj razvitih državah, se mi zdi, da je rodnost kar nekako sorazmerna z razvitostjo, vsaj takšno, kot si jo mi na zahodu predstavljamo.
Mogoče se sliši malce nesramno, ampak v raznih nerazvitih državah se zdi, kot da še niso slišali za kontracepcijo... praktično "vsak seks je nov otrok"...
Bi rekel, da s tem ni nič narobe... tako je že od nekdaj, pač se stvari malce spreminjajo, nič ni večno in razmerja na vseh področjih se spreminjajo. Sicer pa ko pogledaš... najbolj razvite države so ravno te, ki imajo najnižjo rodnost, torej od teh žepnih držav, pa do 2M, kot Slovenija... pa nekje 5-10M, kot so države Beneluksa in skandinavije... bolje, kakšen prebivalec manj, pa da je za te dobro poskrbljeno... imamo pa recimo en skrajen primer Romunije, ko je vladal Ceausescu, ko je hotel na vsak način ustvariti največjo državo v Evropi po številu prebivalstva... dobili pa so dobesedno tovarno sirot... tudi o tem je nekaj dokumentarcev...
Emancipacija zensk + pametni telefoni.
133780 ::
IL_DIAVOLO je izjavil:
Po mojem je to razlog, da je mladini nekako vcepljen strah pred prihodnostjo, vključujoč nepremičnine, precejšen del se raje odloča za pitje špricerjev na potovanjih (lahko virtualnih), igranje igric, gledanje strimov, spremljanje socialnih omrežij; menda so tudi zmenkarski app kontraproduktivni za večino. Včasih se kdo mogoče odloči še za kakšnega živalskega ljubljenčka, dokler ni, morebiti, na letališču v napoto. Od sorazmerno majhnega kroga poznanih žensk so vse precej izven najboljših let, povečini brez otrok, se pa vsaj rade slikajo na potovanjih. Moški, presenetljivo, niti ne, res je sicer, da sprijaznjeni niso z nekimi ekstra krasoticami.
Blinder ::
+ ženskam se v medijih pere možgane, da če naredijo otroka so one žrtve
Ne razumem zakaj bi hoteli več ljudi na svetu. Že tako jih je preveč.
Zadeve bodo šle nazaj slej ko prej. Ko ne bo več fosilnih goriv, posledično ne bo hrane in bo itak vse šlo na precej nižje številke, kot jih poznamo danes.
Vmes bodo še vojne, bolezni, naravne nesrece, propadi narodov in civilizacij. Meni je super, da se to dogaja. Ostala naravna nima nobene dodane vrednosti, če je človeško prisotno. Tako, da manj osebkov je, bolje bo.
Vse kar gre gor, gre tudi dol.
johnnyyy ::
Po mojem je kriva izobrazba. Pač če hočeš imeti otroke, moraš biti "malce neumen". Ker če hočeš biti pameten in naštudiraš vse kar je lahko narobe do rojstva, kaj šele po rojstvu, ugotoviš da je preveliko tveganje, da bi kar koli imel. :)
starfotr je izjavil:
Naj uganem, imas otroke? Ostalim jih pa ne privoscis?
Grinmiir3 ::
Jaz ti predlagam, da kaj narediš glede tega problema s prevečimi ljudmi. Sej veš, talk is cheap.
133780 ::
Naredi še ti nekaj na tem, da bo manj, v Ukrajini in na Bližnjem vzhodu se sicer res trudijo ampak niso dovolj učinkoviti, Evropa se menda tudi bilijonsko ponovno oborožuje, mogoče s podobnimi razlogom. Sicer pa se domač primanjkljaj tako nadomešča s priseljevanjem. Kitajski in Indiji še dopovej, mogoče posaharski Afriki.
  • spremenilo: 133780 ()
pegasus je izjavil:
Obrazlozi evolucisjki aspekt. Ker napisano nima smisla v tem kontekstu.
CiClon je izjavil:
Nope. V primerjavi s stroski gre za drobiz.
Tko, k nekateri so proti novim gradnjam, ker bo degradiralo okolje v katerem zivijo. Seveda so ze na svojem. Egoizem je zal ena poglavitnih cloveskih lasnosti.
  • spremenilo: tikitoki ()
mertseger ::
Preden pridemo do tistega 2.1 nas bo vsaj 10 milijard, a rabimo da še naprej narašča. Tudi če bo leta 2100+ samo 5 milijard ljudi v tem ne bonič narobe. Še to bo preveč ker itak bodo večinoma samo še roboti delali.
133780 ::
Sicer pa pač, država bo že delila kalorije in dopamin tistim, ki ne čakajo na boljše tržne razmere, glede česarkoli že pač, prav nič konceptualno novega v zgodovini.
Vsi, ki ocenjujete, da nas je že preveč, veste, kaj dejansko je vaša dolžnost, eni nismo zelo daleč za vami :D
pegasus je izjavil:
Kayzon je izjavil:
Vzrok je družbeni vpliv kričačev.
Ziher jih nima. :D
  • spremenil: D3m ()
stara mama ::
Hec je da tud cenejša uvožena sila ni tako produktivna - popravek..... ni tako neumna, da se bo ubijala za tisto mezdo, kot je neumna domača delovna sila (obložena s krediti in lizingi).
Tako da kdor je mal sado-mazo, hitro po avto na lizing!
Seveda tak stres nikakor ne vpliva na plodnost (v že tako prepoznih letih) :)
Ekologija™ in Trajnost™
D3m je izjavil:
Hmm, tole s svobodnim služ(b)enjem za delodajalce namesto grajenje ne-zvezdniške družine (in nošenjem 3,75 pregovornih vogalov), izgleda kot zelo nazoren primer brainwashinga vse generacije z namenom pridobitve cenejše delovne sile. Ko pa je še ta predraga, je naslednji korak uvoz iz drugih regij z namenom še večje stroškovne učinkovitosti? Še sreča, da sploh ni težav s tem zaenkrat. Oops?
To je tako, kot da bi rekel, da jaz sem sit, ostalim pa privoščim lakoto.
Dejstvo je, da je ljudi preveč na svetu. In da gre za preživetje in vzdrževanje takega sloga življenja kot je sedaj bistveno preveč raznih virov. In to se bo enkrat ustavilo, ker ni vzdržno. Pač tako bo, hočeš ali nočeš.
Ce je to dejstvo, zakaj si imel otroke?
Lakota je drugace prakticno izumrla. Lacni so samo se ljudje na politicno nestabilnih obmocjih.
Kdo je rekel, da sem jih imel?
Torej jih nimas? Fair enough. Ko bos obnemogel, se bos odrekel drzavni pomoci? Nobene negovalke ipd?
no comment ::
Koliko otrok ima pa kow?
133780 ::
Kow, ti nisi navajen brati med vrsticami, ali? Starfotr ni rekel, da jih nima, rekel je, da jih ni imel - recimo 50 let nazaj jih res ni imel.
Jaz mu predlagam, da namesto, da kupuje top belo tehniko, da gre na Nizozemsko ali kam sprobat kakšno komoro z nesmrtno glasbo.
Saj vemo, da jih nima.
Zato je pa napisal, da nas je itak preveč.
Ker pač "lisica in grozdje".
Kakšno dejstvo je, da nas je preveč na svetu? Koliko je potem ravno prav? Nič?!? Kolikor nas gre v jame?
vres.ales ::
Rodnost je itak v interes samo politikom, ker rabijo ljudi, da lahko imajo šiht. Smo jim pač surovina.
Magic1 je izjavil:
Ravno prav je toliko, da preživiš brez potebe po elektriki, gorivu. Pač, da si vse za preživetje urediš v svoji okolici. Ja in lahko pomeni jamo, kolišča, vasi itd.
Mesta ne morejo preživet brez vnosa od zunaj. Medtem ko podeželje lahko. Pač v tem smislu. Ko čez nekaj stoletji ne bo več nekega oprijemljivega vira nafte, premoga in ostalega, bo vse šlo nazaj na te tirnice.
Zadeve so enostavne in predvidljive.
133780 ::
Očitno lahko tudi sedaj - kaj že tisti vsakodnevni trol lepi glede slovenskega podeželja, mislim, da izhaja iz trde Dolenjske z vsemi podpomeni. Fak, radikalen preper proti pilotom turbopropelerskih avionov v isti temi in to na videti na lastne oči :D
CiClon ::
Ko smo pri državnih spodbudah. Madžarska troši 5% BDP na te pro-družinske politike. Za primerjavo, ko se zdaj preganjamo o 2% ali celo 3% za obrambo. Pa smo na TFR tam tam.
majo pa cel kup ukrepov
https://en.m.wikipedia.org/wiki/Family_...
no comment je izjavil:
Zakaj je to pomembno?
Kaj ti pomagajo davčne olajšave, če ni vrtca ker 'bi investitorje preveč stalo, da bi naredili obljubljeno novo enoto, zaradi katere so sploh dobili gradbeno dovoljenje'. Če šole pokajo po šivih, ker v gradnji novih oddelkov ni tolk profita, kot v 'nadstandardnih stanovanjih'. In tako naprej.
Miki N je izjavil:
Krejzi babe? Če je največ, kar jim lahko ponudiš tate-worshipping incel, ki v življenju ne bo znal poskrbet zase, se ne čudit da rečejo ne.
Bom obrnil, če bi bil 'ideal babe' v medijih taka, ki bi te 'parkat vzgojno' vsakič, ko bi imel kako idejo o tem da bi bil ti malo bolj samostojen, imel svoj denar in se sam odločal o tem, kako in s kom preživiš prosti čas, hkrati bi ti pa zastrupljala odnose z družino, obstoječimi prijatelji in bi tak ideal mlade punce posvojile, idealizirale in se ga držale - bi ti imel kako željo po otrocih?
Planeta ne briga, kaj se gor dogaja - je samo skupek ostankov iz časa formiranja osončja.
Nas pa očigledno tudi ne briga, glede na to da folk že pritrjeni zamaški spravijo iz tira.
Bolj tateizacija moških.
Blinder je izjavil:
Lahko primer, najbrž ne bo težko? Ker jaz tega nisem zasledil.
johnnyyy je izjavil:
Poznam precej precej izobraženih žensk, malokatera je brez otrok.
Ni res, zgodovinsko so egoisti kar hitro postali hrana lokalni favni. Danes pa je naše življenje tako odmaknjeno od 'naravnega stanja', da se je lahko pojavila ideja nekaterih, da kaj sploh rabijo druge ljudi, so sami sebi povsem zadosti.
Ni res.
V Evropi je rodnost najnižja na svetu, pa hočejo nevladne organizacije kot je 8. marec, da bi bila še nižja.
8. marec ti pravi, da se moraš do žensk obnašat kot kreten? Vsak dan nekaj novega...
133780 ::
TESKAn je izjavil:
Fak, noro, tak si ti!?
no comment ::
Zdelo se je, da te zanima zakaj drugi imajo/nimajo (dovolj) otrok. In zdelo se je, da te skrbi, da drugi nimajo dovolj otrok.
Pa bi lahko bilo moje vprašanje lep lead-out, da ponudiš vzgled "kako se to dela". Ah, ja, pa nič...
Jaz mislim, da imamo na svetu dovolj ljudi in da jih več niti ne potrebujemo.
Jaz pa mislim, da imamo potem preveč penzionistov (in s padanjem natalitete, jihbo še več). Kako bomo rešili problem, da jih bo manj?
  • spremenil: Magic1 ()
Narobe si razumel. Starfotr je trdil, da imajo ljudje prevec otrok. Zato sem ga vprasal, ce ima otroke (v smislu, da se jim je odrekel). Jaz sem proti vsakrsnemu reguliranju stevila otrok. Vsak si jih naj "nastepa" toliko kot mu ustreza.
Sem pa tudi mnenja, da je trenutno otrok premalo in da bomo zaradi tega imeli kar nekaj tezav.
Torej, kaj zdaj, potomci so v EU nekaj slabega ali nekaj dobrega, nekaj zaželenega ali nekaj nezaželenega? Glede na to, da je potrebno sploh spraševati to, je jasno, da je nekaj fundamentalno narobe. Zanima me, kdo vam je uspel toliko občutenja lažne krivde vcepiti. Zanima me tudi, zakaj se ni še bolj potrudil, tako temeljito kot po WWII, saj razumemo?
Izgleda so pametni telefoni bolj zanimivi kot ukvarjanje z otroci.
133780 je izjavil:
Fundamentalno narobe je, da ekonomisti želijo grafe, ki se samo vzpenjajo in zganjajo globalno paniko, če se ne. Oni so tisti, ki krvavo potrebujejo več ljudi, ker trenutna blaginja temelji na dobičkih iz prihodnosti, ki se še ni zgodila. Samo poglej pokojninske sklade ...
Če se torej želite podrediti ekonomistom, začnite gostiti mladino iz afrike v domači dnevni sobi. Če pa vam to ne diši ... ni treba tepst priseljencev, nagonit je treba ekonomiste.
nekikr ::
Magic1 je izjavil:
Na tem aktivno delamo. Nova pokojninska reforma, ki tako svečano obljublja, da bo 40 let delovne dobe dovolj, prikladno pozablja, da je naša generacija hodila v šole in tako nihče ne bo imel dovolj delovne dobe pri 60ih. Ljudje so na faksih do 30. leta. 40 let delovne dobe je potem pri 70 (da ja ne bo odbitka). Potem počakaš še dve leti in statistično te več ni.
Manj ljudi je pa preprosto zato, ker imamo zelo dober standard. Včasih so jih naredili po 10, ker trije niti preživeli niso, ostali so pomagali na kmetiji, pa tudi sicer nisi imel kaj dosti opcij. Danes? Danes ima vsak 10 hobijev, če ni na hobiju pa bulji v telefon. Jaz imam dva otroka pa mi na kraj pameti ne pade, da bi imel še kakšnega, pa bi jih imel lahko še 20. Nobena stanovanjska politika in olajšave tega ne bodo spremenile in tudi nikjer po svetu niso. Prelepo nam je, druge interesne dejavnosti imamo. Razlog je precej enostaven, rešitev pa praktično nemogoča. Če temu lahko rečemo rešitev. Polovica manj ljudi bi bila super za planet in tudi za gužvo, ki je danes povsod. Ne vem zakaj se to izpostavlja kot problem. Da bomo potem pri 20 milijardah ljudi razmišljali ali so papirnate slamice dovolj dober ukrep za preprečitev kolapsa planeta?
CiClon ::
Sej težave so že zdaj. Generacije, ki se upokojujejo 60-65 so 30k na leto (s tem da nekaj je že umrlih do 60 leta). Generacije stare 20 in čez, ki naj bi prihajale na trg dela pa so 21k. In še izobrazbena struktura je čist kontra.
S tem da smo lani padli na 16k rojstev.
133780 ::
pegasus je izjavil:
133780 je izjavil:
Spet, ti imaš, čeprav pilot, strašno zmedene pojme, nekaj ti ne paše, nekoga želiš brutalno linčati ampak nekdo ti je vcepil sovraštvo do napačnih. Tisti, ki želijo grafe, ki se vzpenjajo, niso ekonomisti, mogoče so managerji, povečini pa so to LASTNIKI, tudi penzionistični skladi in razni piloti. Po tvoji pegasovski logiki, so vsi ekonomisti bogati. Pač, bedak. Pa saj ne ti, ne jaz, v resnici nisva presenečena, a ne, pegasus?
Si ti tudi TESKAn, deluješ kar prepričljivo, zlahka zamenjam race med seboj.
Magic1 je izjavil:
Sigurno ne z vzdrzevanjem sistem, ki potrebuje konstantno rast, ker je leta neizvedljiva.
GrimReaper3 ::
Kayzon je izjavil:
WTF, kriza? Saj nas je vsaj 10x preveč že v SLO, kaj šele v bolj gosto poseljenih državah. Avtomobilov tako tudi vsaj 10x preveč, ker ima že vsak razen moje mame avto.
IMO je optimalna poselitev za ta planet 1 bilijon ljudi. To je bilo nazadnje leta 1804:
https://www.worldometers.info/world-pop...
Sicer pa ne bi bilo nič narobe, če se v naslednjih 50 letih začne vse od začetka.
Migranti prestopajo mejo ZDA v rekordnih številkah (strani: 1 2 3 4 )
18327326 (2763) Samael
Japonski demografski krizni štab (strani: 1 2 3 4 )
17735317 (31202) PovemVfaco
Kako dvigniti populacijo starjoče Evrope? (strani: 1 2 3 4 … 22 23 24 25 )
Oddelek: Problemi človeštva
1242183422 (157104) vostok_1
Kako dvigniti nataliteto? (strani: 1 2 )
6617780 (17118) jype
