Forum » Mobilne tehnologije » Gmail priponke in mobilni podatki
BCSman ::
Že dolgo časa se vleče problem, da ne gre pošiljat priponk (slike, karkoli...) v gmail appu na telefonu ko nisem na wifi-ju. Sporočilo enostavno gre v čakalno vrsto in tam očitno čaka na wifi. Kje naj nastavim da se bo dalo tudi preko mobilnih podatkov pošiljat maile s priponkami?
Realme 7 android 12
Realme 7 android 12
JanK ::
ChatGPT, nisem preverjal:
To enable sending Gmail attachments on Android when you're not on Wi-Fi, follow these steps:
1. **Open Gmail Settings:**
- Open the Gmail app on your Android device.
- Tap the **menu icon** (three horizontal lines) in the top-left corner.
- Scroll down and tap **Settings**.
2. **Select Your Account:**
- Tap the email account for which you want to change the settings.
3. **Adjust Sync and Attachment Settings:**
- Scroll down to the **Data usage** section.
- Look for the **Sync Gmail** option and ensure it is enabled.
- Check for an option like **Download attachments over Wi-Fi only** (or similar phrasing). If this option is checked, uncheck it.
4. **Check Upload Restrictions in Network Settings:**
- Go to your phone's **Settings**.
- Tap **Network & internet** > **Data usage** > **App data usage**.
- Locate the Gmail app in the list.
- Make sure **Background data** and **Unrestricted data usage** are enabled.
5. **Test the Settings:**
- Compose an email with an attachment and try sending it while on mobile data to ensure the settings work.
This will ensure that Gmail can send attachments even when you're using mobile data. If you face issues, ensure your mobile data connection is stable and has sufficient speed.
"Think about how stupid the average person is,
then realize that 50% are stupider than that"
-George Carlin
-George Carlin
BCSman ::
Popravek: sedaj vidim da vedno ko so priponke gre v cakalno vrsto na telefonu, neodvisno ali je preko podatkov ali preko wifi-ja. Torej priponk v gmailu preko telefona ni mozno posiljat.
| » | Ne glede na nastavitve iPhone 11 pozna lokacijoOddelek: Novice / Apple iPhone/iPad/iPod | 15537 (12683) | tardusm |
| » | Android 5.0 Lollipop (strani: 1 2 3 4 )Oddelek: Mobilne tehnologije | 49780 (41284) | deja |
| » | Google je postal mobilni operater (strani: 1 2 )Oddelek: Novice / Omrežja / internet | 24581 (19133) | Jupito |
| » | HTC Windows Phone 8X (strani: 1 2 3 4 5 6 7 )Oddelek: Mobilne tehnologije | 108486 (73475) | berlusconi |
| » | Android fon me je suvereno obral za 75€ (strani: 1 2 3 )Oddelek: Mobilne tehnologije | 33710 (28511) | Marat |
