Forum » Loža » reddit karma
reddit karma
Ferdo Piš ::
Prijavil sem se v reddit, vendar ne morem objavljati, ker kao nimam nekih karma točk.
Sploh ne razumem te zadeve. Kako dobim te karma točke?
Kurzweil ::
Pač karma točke so tvoj reputation, malce zaupanja in tako je celotna skupnost precej bolj clean, kar se trollov in daily spammerjev tiče. Na kratko, Karma točke dobiš, ko ti folk lajka oz. upvota komentarje... ali drugače, ko dobiš dober reputation oz. imaš dovolj karma točk, boš tudi malce pazil, da ne pišeš neumnosti...
Sicer pa takole:
Karma is like a community points that show Agreeableness towards you. There are two karma - post karma and comments karma. Post karma are something which you post to subreddits and if people like that your post fits the subreddit agenda they upvote your post. The more the post gets upvoted the better its chances it would be shown on your top in the specific subreddit
Če iz nekega razloga ne znaš angleško, pa frcni tole v google translate, je precej lepo napisano, tako da bi tudi prevod znal biti znosen. Sicer pa nobena znanost...
Sicer pa takole:
Comment Karma is something which you gain when you post comment on someone post in ssubreddit. If the people upvote your comment it would gain momentum and likely would be higher in the discussion. The comment karma is somewhat hard to gain because Ideally you need to be early to comment on that specific post elsewise your comments may get no traction with a lot of people commenting. You can get the trending posts by clicking on the popular on reddit home screen or on the tab rising if you are filtering in specific subreddits
The total karma is the addition of the post karma + comment karma. Futhermore the post karma does not have a one to one correspondence with the upvote you getting. Instance if your post gets 1000 upvotes the reddit might give you 500-1000 karma depending upon the algorithm implementation the reddit have...
Ferdo Piš ::
Hvala. Ampak to že vem. Kako naj mi drugi uporabniki lajkajo komentarje, če jih pa sploh ne vidijo?
Ko pridem na reddit, svojega komentarja ne vidim. Torej ga ne vidijo niti drugi.
Moram se prijaviti, da ga vidim.
Kurzweil ::
Potem pa malce bolj razloži stvar... ne pa da ti pomagamo, ti pa potem negiraš, kot da kdo od nas ni prebral, kar bi ti moral napisat, pa nisi.
Poglej malo noticifatione, maile... če so te kaj kaznovali, imaš kristalno jasno vse napisano.
An restriction je tudi age oz. leta... si slučajno ob registraciji naklikal, da si mladoleten?
Si dobil confirmation mail? Si potrdil svoj mail?
Ta account si naredil povsem na novo? Ali si že kdaj uporabljal in si že lahko komentiral?
Ferdo Piš ::
Se opravičujem za premalo vhodnih podatkov...
Tak notification sem dobil:
Unfortunately, your submission to r/Slovenia has been removed because your comment karma is too low. This action is automatic.
Our community requires a minimum of 20 comment karma to participate. This helps ensure that discussions remain constructive and respectful.
Nisem mladoleten, confirmation maila se ne spomnim, ampak domnevam da sem ga dobil, ker se lahko logiram.
Ja account sem naredil na novo.
energetik ::
Se opravičujem za premalo vhodnih podatkov...Komentiraj v drugih subih, kjer je to dovoljeno z 0 karme. Tudi jaz nisem mogel na začetku v r/Slovenia.
vires in numeris
Ferdo Piš ::
To je pa tako, kot da bi rekel, da ne morem jesti mesa, ker imam gnile zobe.
Ti bi mi pa svetoval, naj jem pač čokolino.
MIHAc27 ::
Saj ti je dal dober nasvet. Boš jedel čokolino, dokler se ti zobje ne pozdravijo.
Komentiraš v tistih temah, kjer lahko. Običajno če se kaj pametnega pove dobiš hitro nekaj + točk.
Izogibaj se LGBT, političnih tem. Neglede na to, na kateri strani si.
Ko imaš dovolj karme, pa prešaltaš na meso :)
lolipop2 ::
ampak, a ni to butast sistem? Nekdo, ki bi rad pametno komentiral na sub-u slovenija, mora prej v glupih temah, ki ga ne zanimajo, nabirati karmo. Nekdo, ki pa že prej vsevprek komentira po raznoraznih temah, pa lahko potem naprej kvasi po sub-ih. Saj vem, itak je point da si hooked-up. :)
Ales ::
Je pa ni... Če bi Slo-tech imel podoben sistem, bi veliko trolov in botov obtičalo z novim računom, ker bi jih moderator lahko ujel še preden se znesejo na forumu.
lolipop2 ::
je pa ni. Razumem, v čem je fajn... ampak z mojega vidika je butast. Ker bi rad sodeloval na slovenia reddit... ampak ker nimam dovolj karme, moram sedaj neke glupe objave komentirati, ko sploh nimam interesa :)
oz. če že dosežeš karmo, bi lahk ostala. Nisem aktiven na redditu vsak dan, ker nimam časa, pa mi je sedaj sped padla... in sedaj bi moral spet nabirati točke. :)
- spremenil: lolipop2 ()
Furbo ::
Najdeš temo z nahypanami ovcami, recimo kaj od kripto, poblejaš tako kot ostali in ti takoj par 100 ovc lajka post.
Mission complete.
Mission complete.
lolipop2 ::
Za komentiranje na r/Slovenia potrebuješ, če se prav spomnim, samo 50 karme.
Dan, dva dela po drugih subih kjer lahko komentiraš z 0 karme.
We are fine without wings.
twom ::
Pač karma točke so tvoj reputation, malce zaupanja in tako je celotna skupnost precej bolj clean, kar se trollov in daily spammerjev tiče. Na kratko, Karma točke dobiš, ko ti folk lajka oz. upvota komentarje... ali drugače, ko dobiš dober reputation oz. imaš dovolj karma točk, boš tudi malce pazil, da ne pišeš neumnosti...Nebi bilo slabo če bi to tudi na slo-techu uvedli, pa še omejitev števila objav na dan, da bi ljudje mal razmišljal kaj napišejo...
S tem povečujejo število smeti, pardon, vsebin, na drugih kanalih! The system works!
Tako kot na Stack overflow...
- spremenil: MrStein ()
GupeM ::
Ja kaj pa boš drugega? Se prijavil k zobarju, dobil datum čez 6 mesecev, čez en teden pa z gnilimi zobmi umrl od lakote?
Bolje, da 6 mesecev pač ješ čokolino, dokler te zobar ne dobi v roke.
raceboy ::
pejd na r/SlovenijaFIRE pa reci, da ti je stric zaupal, da bo bitcoin eksplodiral :) pa bos dobil dovolj upvote-jev :)
| » | torrenthr.org (strani: 1 2 3 4 5 6 )Oddelek: Loža | 89214 (5048) | anketar |
| » | Reddit SlovenijaOddelek: Loža | 12369 (3750) | xseki |
| » | Predlog karmeOddelek: Slo-Tech | 2315 (1946) | SodVina |
