Forum » Loža » Temu - nerjaveče jeklo - varno za hrano?
blank3 ::
Zdravo,
našel tole https://share.temu.com/AeKsh8oqgcA in me zanima, kako bi lahko preveril ali je to varno za uživanje hrane.
Načeloma v zahodnih trgovinah zaupamo, da je to nekdo preveril, če ravno je velikokrat preprodaja iz Kitajske (npr. skoraj identičen set https://www.walmart.com/ip/CLS-CLS-Port... ). Kitajci po drugi strani sprintajo logo in to je to...
Set mi je res všeč in bi ga koristil, če je safe. Če pa kdo ve za kako podobno alternativo iz neke preverjene trgovine, bo tudi OK.
Hvala!
Hvala!
Zelo sem zaposlen. Potreboval bi brezcasje... vsaj za nekaj casa.
- spremenil: blank3 ()
u140000 ::
Ne vem, če obstaja kaka zlitina nerjavečega jekla, ki bi bila kaj fejst strupena za človeka in hkrati občutno cenejša, da bi se komurkoli ravno iz največjega strupa splačal štancat take stvari. Mene ne bi skrbelo, še posebej, če ne nameravaš v tem kuhat, ampak samo iz tega jest
Če to kupiš, bodo še tvoji vnuki podedoval. Bi reku da ne šparat? Sem lih pred kratkim bral, da ena popularna posoda (sicer iz afganistana, samo vseeno) vsebuje svinec. Jebiga, vržejo v plavž, kar majo in se ne sekirajo kaj točno je.
To je 201, umrl ne boš :)
Type 201 stainless steel is unique as it was created in response to soaring nickel prices. This means that it is cheaper, but it also has much lower nickel content. Without as much nickel, it is not as effective at preventing corrosion.
The higher levels of manganese help make type 201 one of the strongest types of stainless steel banding. Industries that prefer this type are those looking for more durability at a lower cost and are not worried about exposure to corrosive elements.
Like type 304, this type is also commonly used to attach signs, and for other plumbing needs. Although it is not as resistant to corrosion, it still has good corrosion protection.
Type 201 stainless steel is especially helpful in cold environments, as its toughness holds up in cold weather. To make up for its lack of nickel, you'll find its composed with more manganese and nitrogen.
As the cheapest type of stainless steel, type 201 seems the most appealing. Still, it will not hold up as long in highly corrosive environments.
https://indmetalstrap.com/whats-the-dif...
brizgo ::
Tukaj https://webgate.ec.europa.eu/rasff-wind... imaš primere odpoklicev nerjevečega jekla in glavni vir so kitajskega izvora.
Recimo en primer:
https://www.gov.si/novice/2020-04-01-od...
Nekaj branja na to temo:
https://nijz.si/moje-okolje/varnost-ziv...
https://www.tandfonline.com/doi/abs/10....
Eno je, kaj se napiše na embalažo, drugo je pa sledljivost uporabljenih materialov in dokazovanje na izvoru z analizami.
Npr. implementacija ISO 9001 ter seveda izvajanje predpisane procedure.
u140000 ::
Recimo en primer:
Če je nikelj pogosto problem, potem je cheap ass zlitina, ki jo je redtech opisal, itak verjetno bolj zdrava, ker ga ma manj.
Ne vem kaj je navadno problem, lahko je nikelj, krom... Dejstvo je, da se nekaj lahko izloča in da je lahko problem. Ni pa nujno, da je problem.
Bi pa še vseeno raje imel kovinski set kot pa Made in China nepreverjeno plastiko.
Morda bolj varno je, da se to kupi od znanega proizvalca.
Na primer
https://www.ekikranj.com/
Na primer
| » | Posode za hrano za sebojOddelek: Loža | 3612 (2872) | tony1 |
| » | Amazonov drugi sedež, ki to ne bo (strani: 1 2 )Oddelek: Novice / Ostale najave | 25412 (22515) | ZaphodBB |
| » | Video ne dela ?!Oddelek: Pomoč in nasveti | 3270 (3116) | nsa_ag3nt |
| » | Stainless steel kozarciOddelek: Sedem umetnosti | 3767 (3162) | Okapi |
| » | Nov računalnik - problem driverjevOddelek: Pomoč in nasveti | 3283 (2816) | Acies |
