Forum » Programiranje » [Python] Odkritje današnjega dne: deepcopy
HotBurek ::
Pozdravljeni.
Evo, da pošeram, kaj sem danes odkril.
Imel sem loop, v katerem se kopiral "osnovni" objekt, mu dodal neko lastnost, in potem append-al v list.
Primer:
Output:
Porabil sem eno uro, da sem ugotovil, kako je mogoče, da zadnji append "povozi" vse prejšne. Razlog bi naj bil v tem, da ker kopira referenco na objek in ne naredi kopije.
Ena izmed možnih rešitev:
Output:
To pa štima.
Ne vem, zakaj tega prej nisem opazil, da kakšna stvar ne bi delala pravilno.
No, sedaj je popravljeno.
Well done.
Primer:
item1 = { "name": "test" };
list1 = [];
for i in range(0 ,3):
itemx = item1;
itemx["count"] = str(i);
list1.append(itemx);
print(list1);Output:
[{'name': 'test', 'count': '2'}, {'name': 'test', 'count': '2'}, {'name': 'test', 'count': '2'}]Porabil sem eno uro, da sem ugotovil, kako je mogoče, da zadnji append "povozi" vse prejšne. Razlog bi naj bil v tem, da ker kopira referenco na objek in ne naredi kopije.
import copy;
list1 = [];
itemx = item1;
list2.append(copy.deepcopy(itemx));
[{'name': 'test', 'count': '0'}, {'name': 'test', 'count': '1'}, {'name': 'test', 'count': '2'}]To pa štima.
Well done.
root@debian:/# iptraf-ng
Please resize your window
- spremenilo: HotBurek ()
In Python, copy refers to creating a shallow copy of an object, whereas copy.deepcopy creates a deep copy of an object. Here's how they differ:
Shallow Copy (copy): Creates a new object and inserts references into it to the objects found in the original. Changes to the original object will affect the shallow copy if the referenced objects are mutable. For instance, if you modify a list within a list, the change will be reflected in both the original list and the shallow copy
Deep Copy (copy.deepcopy): Creates a new object and recursively adds copies of the objects found in the original. This means that the deep copy does not share any references with the original object. Therefore, changes to the original object will not affect the deep copy, even if the objects are mutable
na primeru pojasnjeno
https://www.geeksforgeeks.org/copy-pyth...
- spremenilo: sbawe64 ()
Rias Gremory ::
@sbawe64
Well done.
Well done.
| » | vba arrayOddelek: Programiranje | 1348 (1041) | Vazelin |
| » | [C#] WPF vprašanjaOddelek: Programiranje | 1446 (1068) | Ciklamen |
| » | Coursera naloga (python)Oddelek: Programiranje | 2578 (2206) | jype |
| » | batch fajl iz txt (strani: 1 2 )Oddelek: Programiranje | 13047 (11708) | b3D_950 |
| » | Prireditev class = classOddelek: Programiranje | 2375 (2040) | noraguta |
