Forum » Pomoč in nasveti » Klikanje napajalnika
DirkDiggler ::
Zdravo, danes sem si sestavil nov računalnik s spodnjimi kompnentami:
ASRock B650M Pro RS DDR5 (90-MXBLP0-A0UAYZ)
AMD Ryzen 5 7600 6C/12T 3,80/5,10 GHz (100-100001015BOX)
GAMDIAS Talos E3 WH
CORSAIR Vengeance DDR5 RAM 32GB (2x16GB) 6000MHz CL30
Corsair RM750e (2023) Fully Modular Low Noise ATX
Thermalright Peerless Assassin 120 SE ARGB White
Crucial P3 Plus 2TB M.2 PCIe Gen4 NVMe
Sapphire Pulse AMD Radeon™ RX 7800 XT Gaming 16GB
Računalnik se zažene normalno vendar sem opazil, da se ob kliku na gumb za prižig računalnika le ta prižge in v roku 1-2 sekunde napajalnik naredi klik. Sistem se normalno zažene in med delovanjem nic ne klika niti cudnega zvoka ne oddaja. Napajalnik pa ponovno naredi klik tik preden se ugasne.
A je to napaka na napajalniku ali je to kakšna funkcija napajalnika?
GAMDIAS Talos E3 WH
blackmack ::
Tako naredi tudi moj ASUS ROG napajalnik. Kot da bi se v njem ob vklopu in izklopu preklopil nek rele. Drugače med delovanjem je popolnoma tih.
Duhec ::
Po vsej verjetnosti je to klik releja pri soft-start (mehki zagon) vezju.
http://normio.si/
tony1 ::
Furbo ::
The newer RM models use a NTC thermistor for inrush current protection which have a bypass relay. The NTC thermistor limits current to prevent spikes in current when turning the unit on from damaging components in the PSU. The way the NTC thermistor works is when it's cold it provides high resistance, and as it heats up it provides less resistance. This stops the initial current spike but will then allow power to flow normally with minimal resistance. Still, there is some resistance and that wastes energy as heat, which lowers efficiency of the PSU so a bypass relay is used to bypass the NTC thermistor after the initial start up period. That bypass relay would be the click you're hearing a few seconds after turning it on.
vir: https://linustechtips.com/topic/1315737....
| » | Menjava ventilatorja v napajalnikuOddelek: Hlajenje in modifikacije | 8467 (5190) | radmannsdorf |
| » | EK-AscendacyOddelek: Strojna oprema | 1798 (1472) | user-pass |
| » | Termistor - regulacija ventilatorjaOddelek: Elektrotehnika in elektronika | 2253 (2068) | einstein :P |
| » | Okvarjen napajalnik za PCOddelek: Elektrotehnika in elektronika | 1707 (1512) | Pyr0Beast |
| » | Reguliranje ventilatorjev s potenciometrom (strani: 1 2 )Oddelek: Hlajenje in modifikacije | 5897 (5212) | Kaiser |
