Forum » Programiranje » python flappy bird
python flappy bird
dejco_h ::
dober dan malo se igram in delam nekoč popularno igro flappy bird v pythonu.Ampak ker se naletel na težavo se obračam na vas napaka je zelo banalna ampak dejansko ne vidim napake v kodi.torej namesto da bi se mi pipes(cevi) pojavljale pred mano se z nekega čudnega razloga pojavljajo za mano. kaj mi lahko prosim samo kdo pove ali namigne kje je napaka?
Hvala vsem za odgovore že vnaprej
import pygame
import sys
import random
pygame.init()
WIDTH,HEIGTH=551,720
win=pygame.display.set_mode((WIDTH,HEIGTH))
pygame.display.set_caption("FLAPY BIRDS")
black=(0,0,0)
clock=pygame.time.Clock()
bird_images = [pygame.image.load("assets/bird_down.png"),
pygame.image.load("assets/bird_mid.png"),
pygame.image.load("assets/bird_up.png")]
skyline_image = pygame.image.load("assets/background.png")
ground_image = pygame.image.load("assets/ground.png")
top_pipe_image = pygame.image.load("assets/pipe_top.png")
bottom_pipe_image = pygame.image.load("assets/pipe_bottom.png")
game_over_image = pygame.image.load("assets/game_over.png")
start_image = pygame.image.load("assets/start.png")
scrool_speed=1
bird_start_position=(100,250)
class Pipes(pygame.sprite.Sprite):
def __init__(self,x,y,image):
pygame.sprite.Sprite.__init__(self)
self.image=image
self.rect=self.image.get_rect()
self.x=x
self.y=y
def update(self):
self.rect.x-=scrool_speed
if self.rect.x<=- WIDTH:
self.kill()
class Bird(pygame.sprite.Sprite):
def __init__(self):
self.image=bird_images[0]
self.rect.center=bird_start_position
self.image_index=0
self.vel=0
self.flap=False
def update(self,user_input):
self.image_index+=1
if self.image_index>=30:
self.image_index=0
self.image=bird_images[self.image_index//10]
self.vel+=0.5
if self.vel>7:
self.vel=7
if self.rect.y<500:
self.rect.y+=int(self.vel)
if self.vel==0:
self.flap=False
self.image=pygame.transform.rotate(self.image,self.vel*-7)
if user_input[pygame.K_SPACE] and not self.flap and self.rect.y>0:
self.flap=True
self.vel=-7
class Ground(pygame.sprite.Sprite):
def __init__(self,x,y):
self.image=ground_image
self.rect.x,self.rect.y=x,y
def update(self):
if self.rect.x<=-WIDTH:
self.kill()
def main():
bird=pygame.sprite.GroupSingle()
bird.add(Bird())
pipe_timer=0
pipes=pygame.sprite.Group()
x_pos_ground,y_pos_ground=0,520
ground=pygame.sprite.Group()
ground.add(Ground(x_pos_ground,y_pos_ground))
run=True
FPS=60
while run:
for event in pygame.event.get():
if event.type==pygame.QUIT:
pygame.quit()
exit()
win.blit(skyline_image,(0,0))
if len(ground)<=2:
ground.add(Ground(WIDTH, y_pos_ground))
usr = pygame.key.get_pressed()
pipes.draw(win)
ground.draw(win)
bird.draw(win)
pipes.update()
ground.update()
bird.update(usr)
if pipe_timer<=0:
x_top,x_bottom=550,550
y_top=random.randint(-600, -480)
y_bottom=y_top+random.randint(90,130)+bottom_pipe_image.get_height()
pipes.add(Pipes(x_top,y_top,top_pipe_image))
pipes.add(Pipes(x_bottom,y_bottom,bottom_pipe_image))
pipe_timer=random.randint(180,250)
pipe_timer-=1
clock.tick(FPS)
pygame.display.update()
if __name__ == '__main__':
main()
| » | Return ne deluje[python]Oddelek: Programiranje | 1452 (1316) | Jonatan |
| » | [Python3] Izvajanje ukazov po določenem časuOddelek: Programiranje | 1946 (1556) | noraguta |
| » | Predstavitev dvojiškega drevesa z seznamomOddelek: Programiranje | 2657 (2257) | ktka |
| » | [Python]Naloga z razredi in dedovanjemOddelek: Programiranje | 1526 (1278) | ktka |
| » | python -slovarOddelek: Programiranje | 3771 (2750) | Valex86 |
