Forum » Programiranje » sql
sql
BRBR ::
Avto
Kako dobim ven B na osnovi pogoja, da mora imeti kolo, ne sme pa imet vrat. Join. Kajpak spiski delov/pogojev-on/off so daljši.
master a b detail a kolo a vrata b kolo
Never underestimate the power of idiots in large groups.
- spremenil: BRBR ()
imena polj?
prvi stolpec 1, drugi 2
select b.1 , b.2 from detail b , master a where b.2 <> 'vrata' and b.2 = 'kolo' and a.1 = b.1 and a.1 = b
- spremenilo: WizzardOfOZ ()
BRBR ::
Zadnja vrstica ?
BRBR ::
Zadnja vrstica ?
Test tabele;
CREATE TABLE IF NOT EXISTS `1_detail` (
`id` varchar(50) COLLATE utf8_slovenian_ci DEFAULT NULL,
`prop` varchar(50) COLLATE utf8_slovenian_ci DEFAULT NULL
) ENGINE=MyISAM DEFAULT CHARSET=utf8 COLLATE=utf8_slovenian_ci;
INSERT INTO `1_detail` (`id`, `prop`) VALUES
('a', 'kolo'),
('a', 'vrata'),
('b', 'kolo');
CREATE TABLE IF NOT EXISTS `1_master` (
INSERT INTO `1_master` (`id`) VALUES
('a'),
('b');
sql kao, ki pa ne dela:
select b.id , b.prop from 1_detail b , 1_master a where b.prop <> 'vrata' and b.prop = 'kolo' and a.id = b.id
Probaj potem samo to:
select id , prop from 1_detail where prop <> 'vrata'
bemfa ::
Najlepša rešitev bi bila nosql baza, najenostavnejša pa subquery.
Če je performančno problem, pa kak dodatn view, ki predprocesira podatke (označi vsakemu masteru 0/1 kot has_vrata).
SELECT m.id FROM master m LEFT JOIN detail AS d1 ON d1.id = m.id WHERE (SELECT d2.id FROM detail d2 WHERE d2.id=m.id AND d2.prop='vrata') IS NULL
| » | [php] encoding nizaOddelek: Izdelava spletišč | 4549 (2464) | BivšiUser2 |
| » | Šumniki v php-juOddelek: Izdelava spletišč | 5170 (3673) | JoSmo |
| » | Šumniki in phpOddelek: Izdelava spletišč | 1939 (1729) | shadeX |
| » | Java - Problem zarad šumnikov pri SQLOddelek: Programiranje | 1928 (1679) | DiTi |
| » | kako spreminiti vse php fajle in celo bazo v utf-8Oddelek: Izdelava spletišč | 1602 (1382) | Senzacionale |
