Forum » Pomoč in nasveti » Océ TC4 Scanner
Océ TC4 Scanner
fx3zRejSz0cS ::
Preko FireWire poizkušamo priklopiti omenjeni scanner Océ TC4 Scanner. Uporabljen sistem je Windows XP in v opravitelju opravil ne uspe naložiti/najti driverja: OceDocumentTechnologies SCIP1.
Po brskanju gor/dol nismo uspeli najti primernega driverja, saj gre za precej staro zadevo. Ima mogoče kdo kak predlog? Uporablja pa se program Oce Remote za povezavo do tiskalnika. Tiskalnik je preko FireWire povezan v Računalnik to je edini kabel ki ju povezuje.
Lep pozdrav!Hvala!
Lep pozdrav!Hvala!
errhec ::
https://csa.canon.com/internet/portal/u...
Océ TDS450 naj bi imel TC4 scaner vgrajen. Mogoče bo delovalo.
dd
fx3zRejSz0cS ::
Kolikor gledam te zadeve, nikjer ni datoteke kot driver-ja za prenos. Najde se samo .pdf datoteke?
fx3zRejSz0cS ::
Tukaj prejmeš samo software za upravljanje "Océ Power Logic Remote", ampak PC ne prepozna zadeve ker očitno ni primernega driverja. (OceDocumentTechnologies SCIP1 driver)
errhec ::
Đizs.
2015 Prvi
https://downloads.canon.com/csaassets/L...
Zadnji
2023
In vsi tele:
Windows Printer Driver 2
The Windows Printer Driver (WPD 2) is the second generation Windows driver that is available for select Océ printers.
Windows Printer Driver R2.19 (driverselect.2.19.exe)
February 2023
Windows Printer Driver R2.18 (driverselect.2.18.exe)
February 2022
Windows Printer Driver R2.17.1 (driverselect.2.17.1.exe)
May 2021
Windows Printer Driver R2.16 (driverselect.2.16.exe)
September 2020
Windows Printer Driver R2.15.1 Notes (TXT, 3 KB)
December 2018
December 2018
Windows Printer Driver R2.15 Notes (TXT, 3KB)
May 2018
Windows Printer Driver R2.15 (EXE, 9.3MB)
May 2018
Windows Printer Driver R2.14 Notes (TXT, 3KB)
June 2017
Windows Printer Driver R2.14 (EXE, 93.1MB)
June 2017
Windows Printer Driver R2.13.1 Notes (TXT, 4KB)
February 2017
Windows Printer Driver R2.13.1 (EXE, 93.3MB)
February 2017
Windows Printer Driver R2.13 Notes (TXT, 3KB)
October 2016
Windows Printer Driver R2.13 (EXE, 93.3MB)
October 2016
Windows Printer Driver Cleaning Tool 1.14 (ZIP, 5,608 KB)
June 2018
Windows Printer Driver Cleaning Tool 1.13
December 2015 - For use with Océ ColorWave 300/500/550/600/600PP/650/650PP/700, Océ WFPS PostScript Driver/Wide Format Printer Drivers, Océ PlotWave 300/340/345/350/360/365/450/500/550/750/900, Océ TCS300/500, Océ TDS320/450/700/750/800/860.
September 2020
Windows Printer Driver 2, v2.12.1 (EXE, 118.9MB)
Windows Printer Driver 2, v2.11 (EXE, 106MB)
2015 Prvi
Zadnji
2023
In vsi tele:
February 2023
February 2022
May 2021
September 2020
December 2018
December 2018
May 2018
May 2018
June 2017
June 2017
February 2017
February 2017
October 2016
October 2016
June 2018
September 2020
dd
Daliborg ::
hehe...moj HP Scanjet 6100 na SCSI /ISA slot-u bi rekel: what sorcery is this "firewire"
Sicer pa tale Oce TC4 zadeva izgleda masivna, verjetno za uporabo v kakšnih tiskarnah ali kaj takega?
Format life:
Warning all life will be erased!
Do you want to continue?(y/n) Y_
errhec ::
Tudi ADT_PowerLogicRemote_v1905.exe je lahko pravi.
Iz navodil:
Installation procedure for Microsoft(R) Windows(R)
platforms
1. Insert the Océ Power Logic(R)
controller Remote CD-ROM or the Océ Power Logic(R)
controller CD-ROM into the CD-ROM drive of your PC.
2. The installation starts automatically. If it does not start automatically, run Setup.exe.
3. Select the required language in the installation wizard and click 'OK'.
4. Follow the instructions on the screen to complete the installation of Océ Power Logic(R)
controller Remote.
Note:
You can only use Océ Power Logic controller Remote when TCP/IP is enabled on your
system. Ask your system administrator for help with theinstallation procedurefor TCP/IP.
Iz navodil:
platforms
controller Remote.
Note:
dd
| » | Windows - kje se nastavi DEFAULT paper size?Oddelek: Pomoč in nasveti | 1809 (1271) | Zimonem |
| » | Windows 10 in Laserjet 1020 na USBOddelek: Strojna oprema | 1281 (1098) | val1 |
| » | Računalnik ne najde tiskalnikaOddelek: Pomoč in nasveti | 2723 (2632) | Miro-Slav |
| » | Kako preverim če kaka naprava zaseda Parallelni port PC?Oddelek: Elektrotehnika in elektronika | 1082 (937) | pr25012 |
| » | LAN XP+Ubuntu (PROBLEM!)Oddelek: Pomoč in nasveti | 1935 (1791) | bibip |
