kako omogočiti HDR na win10
klemenSLO ::
Imam Samsung tv ki podpira HDR10+. Nanj je preko HDMI priključen PC (intel pentium G4600 7.gen z intel 630 UHD,matična AsRock H110M-ITX) , preko katerega gledam filme/serije.
da to deluje sem na nastavitvah tvja na inputih (HDMI1..) že omogočil 'imput signal plus'
NA winsih pa nimam opcije Enable HDR v nastavitvah.
Zdej kolikor gledam dobim (3840x2160) @ 30Hz UHD na HDMI na tvju.
Kle https://www.intel.com/content/dam/suppo... piše, kaj vse naj bi rabil ;
Za to plato piše le tole:
Supports HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
• Supports DVI-D with max. resolution up to 1920x1200 @ 60Hz
• Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
Intel grafični gonilniki so najnovejši, intem management engine tut.
Iz tega nisem čist zihr če je ta hdmi na plati v2.0 oz kaj še lahko vpliva da ne morem omogočiti HDR?
Se je še kdo s tem ubadal?
Poskusi tole
https://github.com/bradgearon/hdr-switc...
https://www.reddit.com/r/pcgaming/comme...
ali
https://github.com/Codectory/AutoActions
drugače naj bi se nastavil tako:
https://lifehacker.com/how-to-set-up-au...
Right-click your desktop screen and select “Display Settings” (or open the Start menu and go to Settings > System > Display).
In the Display menu, click “Windows HD Color Settings.”
Make sure the “Use HDR” toggle is on, then scroll down and enable “Auto HDR.” (Note: If “Use HDR” and “Auto HDR” are grayed out or missing, then your monitor does not support HDR.)
Close the settings window.
The next time you play a PC game, Auto HDR will kick-in automatically if the game supports the feature.
oz tako
https://www.wepc.com/gaming/autohdr-win...
če ekran ne podpira oz ga windows ne prepozna pravilno (iz X razloga), potem bo opcija hdr zamrznjena.
  • spremenilo: sbawe64 ()
TOP ::
Ja 4K ne dobiš,ker je mašina prešvoh pa tud kabel HDMI pazi katera verzija je.
Cveto ::
Deep color in HDR10+.
Po moje ne bo šlo. Meni dela bp na monitorju (Samsung G7), ne TV-ju, ki podpira HDR 10+ in Dolby Vision, pa ne. Ovira je kabel oziroma priključek na TV-ju (pri tebi tudi na compu).
HDR10 afaik v teh generacijah podpira samo Core i3 in novejše, ne pa tudi Pentium. Tudi če pogledaš tvoj datasheet, ne piše nič izrecno za pentiume, ampak samo Core i
klemenSLO ::
Hvala za odgovore. Sem sumil da nimam ustreznega HW.
1030GT ali kaj novejšega ti reši problem..
klemenSLO ::
Na temle intel linku bi lakho potrdili da ne bo šlo s tem HW..
https://community.intel.com/t5/Graphics...
@hojnikb: morda res ni slaba ideja.
klele na bolhi vidm da en prodaja:
https://www.bolha.com/ostali-dodatki-pc...
V specifikacijah GT1030 je lepo navedno .. (Supports 4K@60Hz as specified in HDMI™ 2.0b)
A je to ok cena 50€?
ni nwm kaj cena, ker za tak denar se dobi ze 1060 :)
Zakaj ni dal v temo grafične kartice ?
https://www.bolha.com/graficne-kartice
H.265 / HEVC (strani: 1 2 )
Oddelek: Zvok in slika
5212159 (6813) Valvoline
Katero grafično kartico kupiti (strani: 1 2 )
8915084 (8195) fender2206
Kateri 4K monitor?
288901 (6301) rokp
Ps 4 pro in tv
102164 (1769) sulicar
