Forum » Navijanje » Novi Nvidia Nforce driver Verzija 3.13
Clemento ::
Dobra novica so IDE driverji.... napisite svoje izkušnje z njimi
Link do driverjev....
Installation Notes
If you are performing an uninstall of your current nForce drivers, your system will have to re-enumerate all devices and restart prior to install of your new package. Multiple restarts may be required; please comply with all instructions to reboot. Failure to do so may cause the install to fail the installation of needed components resulting in system reliability issues.
Windows XP users must install Service Pack 1 prior to attempting to install this package. Failure to do so will result in the inability to support USB 2.0.
Audio drivers will not install on the following nForce2 products: Chaintech 7NJS. Please use the drivers that come with these products to enable audio functionality.
Release Notes
WHQL certified kit for nForce, nForce2, and nForce3
First release of NVIDIA IDE driver for Windows XP and Windows 2000
General compatibility fixes
Audio Improvements:
Realtek ALC655 codec support added
Fix for BSOD on loading DLS files
Reduced susceptibility to audio glitches under heavy system load; additional fixes for 6 channel GetPosition glitches
ASIO support for recording at sample rates other than 48kHz; lower and more predictable latency
Fixes for NOLF. The 3D minimum and maximum distance and the roll off factor were not being taken into account for air absorption. Also modified reverb gain so that the max distance was taken into account
Fix for EAX reverbs; initialized EAX reverbs to off when querying for the EAX listener interface; updated EAX property handlers to ignore invalid parameters instead of range limiting -- this matches Creative EAX behavior
Windows XP Driver Versions
Audio driver 3.66 (WHQL)
Audio utilities 3.66
Ethernet driver 3.63 (WHQL)
GART driver 3.34 (WHQL)
Memory controller driver 3.38 (WHQL)
SMBus driver 3.38 (WHQL)
IDE In-the-box driver 3.58 (WHQL)
IDE 2.0 NVIDIA driver 3.66 (WHQL)
Display driver 52.16 (WHQL)
Installer 3.77
Windows 2000 Driver Versions
Installer 3.77
Installation Notes
Release Notes
Audio Improvements:
Installer 3.77
Installer 3.77
*Epox 8rda+, XP2600+@stock speed, TT Silent Boost, AS5, Ati AH3650
*Abit NF7-S, XP2500+@2425Mhz, 1.85V(220x11), TT Volcano 12, AS5, Rage128PRO
- zaklenil: kuglvinkl ()
| » | NASA World WindOddelek: Programska oprema | 3128 (3046) | Person |
| » | Abit NF7-problem z integ. zvočnoOddelek: Strojna oprema | 1281 (1175) | VASkO |
| » | Nvidia Nforce 3.13 drivers !!! (strani: 1 2 )Oddelek: Strojna oprema | 7314 (6002) | BlackHole |
| » | KT 600Oddelek: Strojna oprema | 1458 (1262) | Clemento |
| » | Katero od teh dveh EPOX plat? (strani: 1 2 )Oddelek: Kaj kupiti | 6973 (6337) | krucymucy |
