Novice » Zasloni / projektorji / ... » Samsung lahko na daljavo onesposobi prodane televizorje
zmist ::
vnetidebater je izjavil:
Interest-Based Advertisement Services
The Interest-Based Advertisement Services (the "IBA Services") is designed to provide the ability to obtain and view useful, interactive, and interest based advertisements about products and services offered by Samsung and third parties on your Samsung Smart TV or across various Samsung and third party platforms or devices, including linear commercials, on the web, mobile devices, and tablets.
In order to make the advertising on your devices more relevant to you, the IBA service will rely on your TV viewing history (including information about the networks, channels, websites visited, and programs viewed on your Samsung Smart TV and the amount of time spent viewing them), Samsung Smart TV usage information, and other statistical data obtained from trusted third party data sources. We may use automatic content recognition (ACR) and other technologies to capture your TV viewing history.
ah daj ne seri no.
Ene same reklame še nisem videl na svojem Samsung smart TVju, ki ga uporabljam izključno samo za predvajanje pretočnih vsebin HBO, Netflix, Amazon in ostale konkurence.
edit.: aja ne, lažem, če odprem youtube vidim več reklam kot videov ki jih želim pogledat. Kar pa je popolnoma enako kot youtube na PCu če ga odpreš v browserju brez adblocka.
A mislis, da razmisljajo razvijalci firmwara tako plitvo, na prvo zogo? Saj jim ni treba predvajati oglasov na TVju. Prodajo x ponudniku tvoje podatke, pa ti jih bojo oni rolali. Sicer pa...
https://www.flatpanelshd.com/news.php?s...
https://www.theregister.com/2015/02/17/...
https://theweek.com/speedreads/538379/s...
https://www.theregister.com/2014/03/13/...
vnetidebater ::
paranoično kompliciraš.
zmist ::
Ja, to so mi razni idioti tudi pred Snowdenom govorili. Pa so potem precej hitro utihnili. Pa za google so mi tudi enako razlagali. Zdaj malo manj
- spremenilo: zmist ()
vnetidebater ::
Enako kot ti kompliciraš in misliš da se s tem boriš proti velikanom v bistvu pa samo...kompliciraš.
- spremenilo: vnetidebater ()
zmist ::
Mah, snowden je zabit debil ki je zafural lastno življenje da ni dosegel prav dobesedno ničesar.
Ti si pa koristen clovestvu. In forumu tudi.
vnetidebater ::
hvala, to sem vedno vedel.
zmist ::
Pa si tudi kdaj prebral svoj podpis?
No mojega ne more. Ne vem, zakaj se ze enkrat ne naucite iz preteklih zgodb, da se domacih naprav ne priklaplja na internet. Kupis raspberry pi 4, gor nalozis linux/kodi/... in uporabljas to. Pa, ce uporabljas scraperje nalozis nekam se vpn v drugi routing tabeli (oz. v mojem primeru v drug fib), in nazenes proxy da jo uporablja, kodiju nastavis naslov proxya in mu na routerju prepoves dostop do interneta mimo proxya (namrec, kodi posilja zanimive zadeve na internet, ko scrapate pa sploh, celotno kolekcijo piratskih filmov posljete ven pod svojim IPjem). Mislim, malo bolj resen televizor stane koliko, 1.5k eurov? In vam je skoda dati tistih 100 eurov za rpi4 in en popoldne, da ga nalozite?
Najprej moraš znat to naredit. In dvomim, da je veliko Krajnskih Janezov to sposobnih.
Če se vrnem k temi; ideja onesposobitve TV je v določenih situacijah OK, ampak kar kliče k zlorabam.
Markoff ::
widj3098dj32 je izjavil:
Nekaj sem bral da pri nekaterih TVjih je neizogibno, da ga prikljucis na net, ko je TV nov, da gres skozi proces da se vse pripravi. Drugace pa raspberry4+kodi.
Naš domači LG 3D Smart TV. Že nekaj let nazaj. Brez priklopa na net je to samo velik obteževalnik omare v dnevni sobi. Takoj zatem sem mu disableal dostop do wifi.
zmist ::
Saj zato pa to pisem tukaj ne na med.over.net. Ker bi pricakoval, da je tukaj precej ljudi, ki niso Kranjski Janezi.
XyNOBvxWVJ ::
No, nam še nobene tv niso zabrikali. Ko bojo, bom robantil (če bo prej kot, recimo, 10 let od nakupa) brez milosti.
- spremenilo: XyNOBvxWVJ ()
zmist ::
XyNOBvxWVJ je izjavil:
Tudi meni ne :) Je pa vseeno fino vedeti, pa ne samo o tem, tudi o linkih, ki sem jih zgoraj podal, so splosno edukativni in tega bo vedno vec povsod.
vnetidebater ::
Ne paničari. Tega ne bo nič, nikdar, razen če pride do hude pizdarije (recimo finančni propad Samsunga, propad svetovnega interneta)..
Če do tega pride pa bomo se pizdili in začeli bojkotirati izdelke. Do takrat je vse samo paničarjenje in širjenje strahu na stopnji 24ur.
Ales ::
Phantomeye je izjavil:
Mislim, sej telefoni imajo moznost blokade IMEI, kar je precej podobna reč.
IMEI se lahko blokira (zasleduje, itd.) na omrežju, to se ne dela na samem telefonu.
Netrunner ::
A2233 ::
Ravno zato, ker smo na inzenerskem forumu, vemo, kaj se da narediti. Seveda pa niso vsi tukaj inzenerji oz. bomo rekli, da so nekriticni fanboyi tehnologij.
Zgoraj iz samsungovega privacy policya:
Super, se popolnoma strinjam.
Maximus ::
TV ki ima vgrajen mikrofon ali kamero ne bo vidla moje dnevne sobe :) Žalostno je, da moraš plačati za nekaj kar ne rabiš + imaš možne exploite. Pa kakorkoli se obrne, te smart zadeve na TV so bolj ne kot ja. HTPC all the way !! ..TV pa dol iz neta
se zna zgodit da čez kako desetletje takega TV-ja sploh ne bo na trgu.
Trenutno lahko še dobiš butast TV največje velikost 32". Butaste TV-je dejansko počasi "umikajo" iz prodaje....
zmist ::
Seveda, ce je pa vec denarja v vohunjenju po uporabnikovih domovih. Saj s telefoni ni nic drugace, brez googlovega spywara recimo.
zavajon ::
filip007 ::
https://www.ceneje.si/Izdelek/20742733/...
GupeM ::
zmist ::
Si si ze prebral svoj podpis? Ker jaz sem v privacyu 20+ let, verjetno sem prvi firmware flashal preden si se naucil govorit. In tocno taki pacienti zagotavljajo, da se industrija vedno bolj vtika v kupljene naprave. Ce ze dobrega ne mores narediti, vsaj slabega ne pocni.
Naj ti citiram, kar sam siris naokrog:
Dunning-Krugerjev učinek predstavlja kognitivno pristranskost,
kjer se neusposobljeni posamezniki ne zavedajo lastnega nivoja znanja o
določenem področju, kar vodi k slabim odločitvam in zmotnim zaključkom.
dexterboy ::
Danes Samsung, jutri ves svet. To NI paranoično razmišljanje, to je KONTROLA množic! Samsung bo vedel tvoj gmail naslov, njega geslo, dostop do tvojih kontaktov v telefonu, nato bo lahko zgradil mrežo ostalih uporabnikov Samsung TV-jev, katere ti imaš v imeniku, sej tvoji frendi so tudi kupili Samsung slikosuke in neumne telefone... aja, pa ne boš verjel, ker imaš na founu aplikacijo o cepljenju Covida, bo lahko tvoje podatke prodal farmacevtom, Google bo Samsungu prodal informacije o vozilu, ki si ga lastiš, Samsung bo Googlu prodal informacije o programih, ki jih gledaš...
Ja, res no, brawo, krasno novi svet. Ne moreš, verjameš, o tem je pel že Tomaž v komadu o avtomatih; le-ta ve o tebi več, kot o sebi veš ti sam.
zmist ::
vnetidebater ::
torej že 20+ let paničariš.
Sploh če si pred 20 leti flashal tiste dumb televizorje. Rofl.
pazi, tvoj printer je ravnokar naredil nek nenavaden zvok. Hitro ga s kladivom udari, sebi pa daj alu folijo okoli čela. Samo glej da boš potem tiho saj ima CIA tehnologijo s katero lahko preko vibracij aluminija z navadno kamero (ki ima velikansko povečavo) potem razloči kaj si govoril, če ima le direkten pogled nate (skozi zaprto okno recimo).
Ales ::
pazi, tvoj printer je ravnokar naredil nek nenavaden zvok. Hitro ga s kladivom udari.
A lahko nehaš smetit temo s temi idiotizmi? Smo dojeli, da "nimaš nič za skrivat", a maš dejansko še kaj drugega za povedat?
vnetidebater ::
Seveda ne. Ravnokar sem se stuširal in šel nag mimo TVja. Kako perverzno, nekdo na Samsungu me je videl :P
Vemo, smo dojeli, paranoiki ste. Kaj dafuq smetite v tej temi torej? Kupite dumb televizor in dajte mir.
Če ga najdete kje.
XyNOBvxWVJ ::
Enkrat sem videl neke spletne ankete...
Evo tule - rešite in se zjočite: klik.
Če bi vedel, kaj z bolj resno anketo, bi jo naredil.
Zimonem ::
XyNOBvxWVJ ::
Če ne, potem se namenoma ogibaš tej 'pameti' ves čas ali po treh letih?
Box je mišljen kot android tv box iz Kitajske?
Za vsak tv svoj username in to, ja/ne?
Se ne da česa 'zagregirati' glede na tvoj wifi ip?
Kaj pa je (dejanski) worst case scenario?
vnetidebater ::
Razen če kupiš projektor, potem si večino težav rešil.
Ena opcija je recimo da imaš TV povezan na guest WIFI network, ki ga redno izklapljaš (ali pa mu vklopiš urnik kdaj naj bo vključen..samo takrat ko gledaš TV).
Ales ::
In tudi pol k..ca nima veze ali je projektor ali televizor, pač pa kam in kako se naprava povezuje ter kdo vse lahko z njo upravlja.
Za tole problematiko, in še kako povezano, wi-fi guest omrežje nič ne pomaga.
XyNOBvxWVJ ::
Ja, torej ne met direkt ethernet kabla v tv? Auch, brez zveze...
Nad nami so verjetno že vsi obupali, mi nismo ne pametni, ne bogati, ne pomembni.
LG nima Android OS-a.
Ja, kaj pa so potem formalna priporočila glede pametnih tv in wifijev in kablov in boxov?
Namesto kreganja bi jaz (ja, samo jaz) pričakoval nasvete, ne pa nek brezvezen špetir.
Je tisti si-cert (ali katerakoli druga, še pomembnejša avtoriteta) izdal kakšna konkretna priporočila za to problematiko?
Zimonem ::
Ja, sploh dobiš velik zaslon brez 'pameti'?
Za Shielda dobivam , že vsaj 6 let popravke in tudi promet je zanalziran.
Pametni televizor od mame je na koncu tudi fasal Shielda.
- spremenilo: Zimonem ()
zmist ::
Omg... definitivno si preberi svoj podpis. Veckrat. Meditiraj na njega naslednjih nekaj let.
Nič od nvidie navaden shield. Daš pač Googlu svoje. Ampak ni reklam pa posodablja se.
Ja, potem pa google uporablja shield, da zbira podatke, reklame zbrane na podlagi teh podatkov pa uporablja, da ti na vseh drugih napravah prikazuje targetirane reklame.
Samo v razmislek, Pokemon od Niantic Labs verjetno poznate? Zadeva je spin off experiment od googla s katerim so testirali, kako zmanipulirat gibanje mnozic. In obnesel se je fantasticno. Se slisi kot teorija zarote? Preden zacnete o paranoji in teorijah zarot malo poduckduckgojajte. In njihove produke bi radi imeli v dnevni sobi?
Unchancy ::
Če že moraš vklopiti za prvi zagon potem pač kasneje spremeniš geslo na routerju in se lahko slika.
Adijo mod Rdeči Kmeri.
zmist ::
Zakaj bi moral biti TV povezan v internet? Gledaš straming preko nekega boxa ali apple tv.
Ne rabi biti povezan v internet. Ravno to je celotna fora. Nobene potrebe po tem ni, pac pljunes 50 eurov vec in dobis se vsa nepotrebna jajca, ki jih talcijo v tv na zunanji napravi in problem resen.
zmist ::
Če ga najdete kje.
Seveda nima nic vec za povedati: “Arguing that you don't care about the right to privacy because you have nothing to hide is no different than saying you don't care about free speech because you have nothing to say.”
Pa tule bi se dalo tudi kaj najti: https://insight.kellogg.northwestern.ed...
""If you believe that a brand is part of you, and you read something negative about it, how are you going to react?" Lee asks. "Are you going to stop using it? Or do you use it even more?" Sure enough, after crunching the numbers, Lee and her colleagues found that self-conscious, low-self-esteem subjects who said they liked Starbucks initially actually rated the coffee company more favorably after they had read the critical editorial."
Skratka nic kar psiholog/psihiater ne bi mogel pozdraviti.
XyNOBvxWVJ ::
Vsa industrija smart tv je v bistvu nateg in problematična s strani zasebnosti?
Kako se posledice vidijo v realnosti? Politika ali reklame?
Kako bi se naj to poznalo?
Je potem potrebno nastavit na routerju, da je ves promet preko vpn?
Kateri router in kateri vpn, da je zanesljiv in za izogib sledenju?
To je postalo pereče šele sedaj, ker je Samsung deaktiviral nekaj ukradenih tv?
In okvare tv takoj po garanciji so tudi ene od posledic tega?
Je potem navezanost na Samsung brand posledica tega?
Kaj pa Apple?
Kaj pa kakšna kikiriki firma iz Kitajske?
Se da kje prebrati kakšne dobronamerne (in ne toliko očitajoče) nasvete za potrošnike?
So znani slovenski strokovnjaki za zasebnost že kaj pripravili na to temo?
musli ::
Seveda, lahko rečeš da te to ne zanima, ker nimaš kaj skrivat in se nekega dne zbudiš v čisti distopiji ali pa že zdaj rečeš, da se tega ne boš šel, glasuješ vsaj z denarnico. In si pač paranoik.
XyNOBvxWVJ ::
Če se to ugotovi, se obvesti svet na veliko sredi dnevnika, portalov, EK, ker je to, zaenkrat, nedovoljen poseg v zasebnost.
Še to, ena ali dve kameri sta očitni, ker vidiš pred seboj, pri nas nobena od tv nima vgrajenih kamer.
Torej smo mi, k sreči, manj pametni od nekaterih, ki morda šele nameravajo biti.
Tudi v tem primeru je potrebno biti jasen in formalno odsvetovati tak nakup.
Sicer domnevam, da se razvoj tv, če do tega pride, ne bo končal s kamerama.
Če torej ne vidim kamer, lahko vsaj upravičeno domnevam, da prisluškujejo?
Kako bi ugotovil, kdaj (in kako pogosto) pošljejo in kam.
Je to ves čas ali gre za povzetke, skupaj s sporedom?
Logirati in analizirati ves promet (ali poskus) vsake tv na routerju?
To še ni narejeno? Neke priporočene 'varnostne' nastavitve za router, odvisno od tv?
Za notesnik/telefon/tablico je več možnosti, je tam potrebno pokrivati kamere?
Če se ugotovi, da to 'opazovanje' obstaja, se objavi skupaj z navodili, kako se temu izogniti.
Dokler si-cert, potrošniške organizacije, EK in še kdo ne posumi/ugotovi in opozori...
Je kje kakšna namenska stran s temi ugotovitvami?
Vse to so meni neka osnovna izhodišča, ki morajo biti razjasnjena.
Sicer pa, ne vem, če dobiš nek normalen velik tv brez smart funkcije.
widj3098dj32 ::
Kako 'morda pošiljajo' - to je potrebno biti jasen - znamka, model, kako, kaj, kdaj...
Zgodovina je pokazala da KO SE (ne če) to ugotovi, se placa mala odskodninca (seveda ne ovcam, pardon potrosnikom) in svet se vrti naprej. Big Tech so skapirali, da je ceneje placat odskodnine (ker sodni mlini trajajo dolgo), kot pa da bi bili posteni.
- spremenilo: widj3098dj32 ()
XyNOBvxWVJ ::
Next level je 5G eSIM in always-on povezava, kjer nobeni blockerji ne pomagajo. Razen kletka.
Ja, ampak kamere lahko prelepiš, če se gremo takšne poenostative. Potem ostane zvok, če že odmislimo direktno spremljanje sporeda in 'fokus' spremljanja oddaje. Šteti gledalcev pa ne bo moglo (no, morda preko zvoka, ja) Kaj pa tu? A misliš, da v prihodnosti boš lahko kupil kakšen dumb (=not smart, očitno) tv ali da bo še kakšen deloval? Mislim, da bo tole že veliko prej šlo na čisto personalizirano ponudbo s projekcijo direktno na mrežnico, živec ali kar v možgane... The matrix resurrections ali pa to. Po mojem bomo še porej nabavljali kakšne ventilatorje in 'odišavljalce' in direktne živčne stimulatorje za bolj pristno doživetje.
Cenovno dostopen 65" monitor? :)
Jaz nimam niti toliko prostora ...
Se strinjam z vsemi, ki pravijo, da je enostavno preveč (neuporabnih) funkcij ipd. v teh "pametnih" televizorjih.
Kmalu boš res rabil izpit za upravljanje teh naprav.
Spet bi lahko potegnili vzporednico z avtomobili:
Viri slik:
https://www.pinterest.com/pin/284500901...
https://www.macrumors.com/review/2021-c...
Lahko bi dal tudi kakšnega fičoja, starega VW-hrošča ali stoenko. Bistvo bi ostalo isto. Preveč je funkcij ...
Še ena vzporednica je: proizvajalci lahko avtomobile izklopijo na daljavo. Pa smo spet tam, kar piše v naslovu novice.
- spremenil: opeter ()
| » | Samsung lahko na daljavo onesposobi prodane televizorje (strani: 1 2 3 )Oddelek: Novice / Zasloni / projektorji / ... | 39320 (31979) | BigWhale |
| » | Prispeli prvi televizorji s Firefox OSOddelek: Novice / Zasloni / projektorji / ... | 21937 (11880) | korenje3 |
| » | Inšpektor nad oglasom na Bolhi? (strani: 1 2 )Oddelek: Loža | 13679 (10678) | mitja73 |
| » | CES 2014: Sonyjev PlayStation Now za igranje iger kjerkoliOddelek: Novice / Igre | 8532 (7674) | BlackMaX |
| » | plazma ali lcd tvOddelek: Kaj kupiti | 3621 (3304) | kokoon |
