Forum » Programiranje » pylint3
pylint3
HotBurek ::
Dobro jutro.
Danes sem našel program, ki se kliče pylint3. Namenjen je čekiranju, kako ok je koda.
https://www.pylint.org/
V .pylintrc fajl sem si shranil sledeč konfig:
Sam check se požene z ukazom: pylint3 file.py --rcfile=/home/user1/.pylintrc
Errorji/warningi, ki jih dobim:
Module 'requests.packages' has no 'urllib3' member (no-member)
Pride iz:
R0903: Too few public methods (0/2) (too-few-public-methods)
Pride iz:
C0200: Consider using enumerate instead of iterating with range and len (consider-using-enumerate)
Pride iz:
C1801: Do not use `len(SEQUENCE)` to determine if a sequence is empty (len-as-condition)
Pride iz:
Tale dva:
C0301: Line too long (105/100) (line-too-long)
in
R1702: Too many nested blocks (6/5) (too-many-nested-blocks)
Pa nista kritična. No, sej tudi ostali niso.
Je pa našlo nekaj napak, ko sem ponovno definiral sprejemljivke znotarj funkcij. Ter for/for zanki (ena v drugi), kjer sem pri obeh uporabljal sprejemljivko i (namesto i/j).
To je to.
[MASTER]
disable=
W0301, # Unnecessary semicolon (unnecessary-semicolon)
C0103, # Constant name "test" doesn't conform to UPPER_CASE naming style (invalid-name)
C0111, # Missing class docstring (missing-docstring)
W0702, # No exception type(s) specified (bare-except)
Pride iz:
# avoid InsecureRequestWarning requests.packages.urllib3.disable_warnings();
Pride iz:
class Item:
def __init__(self):
self.id = None;C0200: Consider using enumerate instead of iterating with range and len (consider-using-enumerate)
Pride iz:
for i in range(0, len(items)):
Pride iz:
if len(response_html) > 0:
Tale dva:
in
To je to.
root@debian:/# iptraf-ng
Please resize your window
- spremenilo: HotBurek ()
PromeuZ ::
Ni pa to edini linter za python. Poglej si recimo github workflow za linterje na django projektu
https://github.com/kiwitcms/Kiwi/blob/m... (doc8 lahko ignoriraš ker preverja dokumentacijo). Potem so tu še namenske aplikacije kot npr SonarQube, kjer imaš na kupu linterje za več programskih jezikov.
<!-- https://pisalnik.wordpress.com -->
| » | Skripta za Bolho.Oddelek: Programiranje | 5584 (2996) | planina91 |
| » | Fake traffic generatorOddelek: Omrežja in internet | 3026 (2222) | HotBurek |
| » | Kontakt obrazecOddelek: Izdelava spletišč | 2577 (2422) | betmen |
| ⊘ | python pomočOddelek: Programiranje | 3980 (2901) | Mavrik |
| » | [C#] Prosim pomagajte! Potrebujem program, ki bi pobiral podatke iz ene straniOddelek: Programiranje | 3232 (2842) | David1994 |
