Forum » Omrežja in internet » Ne prikaže mi Googla
scenic ::
Imam en problem in sicer ne odpre mi www.google.com prokaže mi eno zeleno stran kjer piše:
cPANEL in There is no website configured at this address.
Prav tako mi ne pokaže AltaViste.
Kaj se mi je sfizilo?
Hvala
Scenic
Hvala
Scenic
- spremenil: scenic ()
fizolcek ::
Po vsej verjetnosti mas virus Trojan.Qhosts , http://securityresponse.symantec.com/av... , poglej ce ti zadeve resolva v 207.44.220.30 pol je to to.
Fizolcek
Fizolcek
fizolcek ::
V DOS oknu napisi nslookup www.google.com in ti mora javiti priblizno takole:
C:>nslookup www.google.com
Server: taurus-1.siol.net
Address: 193.189.160.11
Non-authoritative answer:
Address: 216.239.59.99
Aliases: www.google.com
ce bo tam za server pisalo 69.57.146.14 ali kak podoben cuden IP, potem ves da ti je virus spremenil DNS serverje za tvojo povezavo v internet. Lahko tudi pogledas, ce imas v c:\windows\help\ direktoriju datoteko HOSTS, kjer je zapisano na kater IP kazejo nekateri popularni naslovi.
Fizolcek
Fizolcek
scenic ::
Napiše, da ni mogoče najti, IP si napisal tapravi, torej je spremenjen Symantec pa ga ne najde, kaj mi svetuješ. Mogoče na novo namestiti sistem.
Scenic
Scenic
scenic ::
Tole je v datoteki
88.88.88.88 elite
207.44.194.56 www.google.akadns.net
207.44.194.56 www.google.com
207.44.194.56 google.com
207.44.194.56 www.altavista.com
207.44.194.56 altavista.com
207.44.194.56 search.yahoo.com
207.44.194.56 uk.search.yahoo.com
207.44.194.56 ca.search.yahoo.com
207.44.194.56 jp.search.yahoo.com
207.44.194.56 au.search.yahoo.com
207.44.194.56 de.search.yahoo.com
207.44.194.56 search.yahoo.co.jp
207.44.194.56 www.lycos.de
207.44.194.56 www.lycos.ca
207.44.194.56 www.lycos.jp
207.44.194.56 www.lycos.co.jp
207.44.194.56 alltheweb.com
207.44.194.56 web.ask.com
207.44.194.56 ask.com
207.44.194.56 www.ask.com
207.44.194.56 www.teoma.com
207.44.194.56 search.aol.com
207.44.194.56 www.looksmart.com
207.44.194.56 auto.search.msn.com
207.44.194.56 search.msn.com
207.44.194.56 ca.search.msn.com
207.44.194.56 fr.ca.search.msn.com
207.44.194.56 search.fr.msn.be
207.44.194.56 search.fr.msn.ch
207.44.194.56 search.latam.yupimsn.com
207.44.194.56 search.msn.at
207.44.194.56 search.msn.be
207.44.194.56 search.msn.ch
207.44.194.56 search.msn.co.in
207.44.194.56 search.msn.co.jp
207.44.194.56 search.msn.co.kr
207.44.194.56 search.msn.com.br
207.44.194.56 search.msn.com.hk
207.44.194.56 search.msn.com.my
207.44.194.56 search.msn.com.sg
207.44.194.56 search.msn.com.tw
207.44.194.56 search.msn.co.za
207.44.194.56 search.msn.de
207.44.194.56 search.msn.dk
207.44.194.56 search.msn.es
207.44.194.56 search.msn.fi
207.44.194.56 search.msn.fr
207.44.194.56 search.msn.it
207.44.194.56 search.msn.nl
207.44.194.56 search.msn.no
207.44.194.56 search.msn.se
207.44.194.56 search.ninemsn.com.au
207.44.194.56 search.t1msn.com.mx
207.44.194.56 search.xtramsn.co.nz
207.44.194.56 search.yupimsn.com
207.44.194.56 uk.search.msn.com
207.44.194.56 search.lycos.com
207.44.194.56 www.lycos.com
207.44.194.56 www.google.ca
207.44.194.56 google.ca
207.44.194.56 www.google.uk
207.44.194.56 www.google.co.uk
207.44.194.56 www.google.com.au
207.44.194.56 www.google.co.jp
207.44.194.56 www.google.jp
207.44.194.56 www.google.at
207.44.194.56 www.google.be
207.44.194.56 www.google.ch
207.44.194.56 www.google.de
207.44.194.56 www.google.se
207.44.194.56 www.google.dk
207.44.194.56 www.google.fi
207.44.194.56 www.google.fr
207.44.194.56 www.google.com.gr
207.44.194.56 www.google.com.hk
207.44.194.56 www.google.ie
207.44.194.56 www.google.co.il
207.44.194.56 www.google.it
207.44.194.56 www.google.co.kr
207.44.194.56 www.google.com.mx
207.44.194.56 www.google.nl
207.44.194.56 www.google.co.nz
207.44.194.56 www.google.pl
207.44.194.56 www.google.pt
207.44.194.56 www.google.com.ru
207.44.194.56 www.google.com.sg
207.44.194.56 www.google.co.th
207.44.194.56 www.google.com.tr
207.44.194.56 www.google.com.tw
207.44.194.56 go.google.com
207.44.194.56 google.at
207.44.194.56 google.be
207.44.194.56 google.de
207.44.194.56 google.dk
207.44.194.56 google.fi
207.44.194.56 google.fr
207.44.194.56 google.com.hk
207.44.194.56 google.ie
207.44.194.56 google.co.il
207.44.194.56 google.it
207.44.194.56 google.co.kr
207.44.194.56 google.com.mx
207.44.194.56 google.nl
207.44.194.56 google.co.nz
207.44.194.56 google.pl
207.44.194.56 google.com.ru
207.44.194.56 google.com.sg
207.44.194.56 www.hotbot.com
207.44.194.56 hotbot.com
88.88.88.88 elite
fizolcek ::
Ja, pol mas 100% ta virus, cudno da ga Symantec ne najde, probal si s tem anede http://www.symantec.com/avcenter/FixQho... ? Mogoce ce pogledas se pri ostalih antivirus prouizvajlacih, ce imajo kako orodje za odstranit ta virus, jaz osebno se ne bi sel ponovno instalirat winsov.
Lahko ga pa tudi sam rocno odstranis, ce ves, da ne bos nic zafrknil:
Z http://vil.nai.com/vil/content/v_100719...
Manual Removal Instructions
Apply the MS03-040 patch http://www.microsoft.com/technet/treevi...
Delete the following files:
%WinDir%\Help\hosts
%WinDir%\winlog
Set the following registry key value (Information on editing registry keys ):
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\
Tcpip\Parameters "DataBasePath" = %SystemRoot%\System32\drivers\etc
Delete the following registry key value (Information on deleting registry keys ):
Services\Tcpip\Parameters\Interfaces\windows "r0x"
Reconfigure your DNS server settings as desired
Reconfigure your Internet Explorer settings as desired
lahko noc,
Fizolcek
%WinDir%\Help\hosts
%WinDir%\winlog
lahko noc,
Fizolcek
| » | Visok ping ob določeni uri? (Amis)Oddelek: Pomoč in nasveti | 1835 (1680) | čuhalev |
| » | Najboljši routi na optikiOddelek: Omrežja in internet | 3325 (2884) | Bakunin |
| » | Hiter tuji proxyOddelek: Omrežja in internet | 7548 (4199) | poweroff |
| » | Najmanjši ping v 100Mbit in 1000Mbit omrežjih.Oddelek: Omrežja in internet | 3093 (2584) | gumby |
| » | UPC Telemach onemogočil dostop do strani podjetja T2 !? (strani: 1 2 )Oddelek: Omrežja in internet | 8593 (6159) | elhombre |
