Forum » Kriptovalute in blockchain » kripto splošna debata
Kripto ::
Brez skrbi gremo še nižje, še bomo videli crash situacije in še bodo priložnosti. Smo šele na polovici bear trenda. Ta čas se pripravite, da boste polnili vreče na razprodajah.
Wealth is mindset!
ChirkKarlle ::
Based on my review of recent DOJ Epstein file releases and fact-checks, this specific email does not appear in official documents--it's likely fabricated. Real files show Epstein's crypto investments (e.g., in Blockstream), but no such 2008 Bitcoin creation email. See DOJ site:
FEJK
FEJK
- spremenilo: ChirkKarlle ()
bonanno ::
stroj66684 je izjavil:
https://x.com/Palsvig/status/2018711692...
Tale ni v file vrjetno je scam..tisti ostali da je financiral MIT itd. Pa so.
ChirkKarlle ::
My favorite part of the bitcoin cycles on reddit is that exposes so much.
During the crash:
1. Default subs (technology, investing, economy, etc)
You see the default subs in ecstasy over crypto falling. Why? Because they feel eternally guilty and stupid for not investing a decade ago. If bitcoin falls then they could convince themselves they're not so stupid after all.
2. /r/cryptocurrency
You see this subreddit brigaded hard with thousands of upvotes on any slightly bad news. It becomes glaringly obvious how many bots and haters only come here to troll and manipulate. Honestly this sub is absolute garbage in general.
3. /r/Bitcoin
You see the newbies in the Bitcoin subreddit melting down. Plenty of vets to talk them off the ledge but the fear takes hold regardless.
Then the sky clears, BTC bottoms out and climbs back towards an ATH.
1. Default subs
The default subs and the morons therein never learn. Instead of hating they could buy the bottom and double their money. But they are hateful losers for a reason. They stay poor and bitter for a reason.
The haters and bots disappear since they have nothing to say if crypto is looking good. This sub returns to being a ghost town.
3. /r/bitcoin
Everyone wants to talk about whether they managed to buy the bottom. Which is the most healthy discourse imo.
Main takeaway: if you can ignore the noise, and very simply buy low/sell high, you are at the absolute peak of humanity in the modern age. Everyone will waste their time hating and criticizing but you just make the easiest money that has ever been made whether it's bitcoin, stocks, or other assets.
During the crash:
3. /r/Bitcoin
1. Default subs
3. /r/bitcoin
ChirkKarlle ::
Ali se nam obeta SuperBowl nedelja na 80-90k pred obiskom 50k? :D Bodo ribice prijele za vabo?
aulcnik ::
iskreno povedano, v tem trenutku je 64K linija življenja, nad to linijo ima BTC še šanse, vkolikor pa se vrenost BTC-ja spusti pod to raven , gre momentum navzdol.
aulcnik ::
iskreno povedano, v tem trenutku je 64K linija življenja, nad to linijo ima BTC še šanse, vkolikor pa se vrenost BTC-ja spusti pod to raven , plus padec delnic (S&P / Nasdaq), kaka makropizdarija kot je Fed vojna eskalacija(beri Iran),masivni pobeg velikih igralcev(beri kitov) etcetc, vsi ti dejavniki bi pripomogli, da bi lahko bTC padelna linijo ekstrema cca 52K.
iskreno povedano, v tem trenutku je 64K linija življenja, nad to linijo ima BTC še šanse, vkolikor pa se vrenost BTC-ja spusti pod to raven , plus padec delnic (S&P / Nasdaq), kaka makropizdarija kot je Fed vojna eskalacija(beri vojaška intervencija ZDA na Iran je popolnoma realen),masivni pobeg velikih igralcev(beri kitov) etcetc, vsi ti dejavniki bi pripomogli, da bi lahko bTC padelna linijo ekstrema cca 52K.
- spremenilo: aulcnik ()
ChirkKarlle ::
"Isn't verified" doesn't mean fake, yet.
Bralno razumevanje in to?
Midtermsi se bližajo, dost info - need to make crypto bro's happy, for a while.
ChirkKarlle ::
pujsekpepe ::
ChirkKarlle je izjavil:
pujsekpepe je izjavil:
Itak kr triljone bodo metal not
Cez nekaj ur ti nic ne bo jasno..![]()
ChirkKarlle ::
Od kje so dobili 33 miljard iz 2k BTC???
24kur :D Torej kaj? 2000 ali 200000+
Uslužbenec borze je tako namesto predvidene simbolične nagrade stotinam uporabnikov pomotoma poslal 2000 bitcoinov.
Men se ta stavek jasno slisi kot da so vec sto uporabnikom poslali vsakomur po 2000 BTCjev.
Seveda govorimo o virtualni poziciji na trgovalnem racunu, ni dejanski BTC zamenjal denarnice. Zato so tudi hitro revertali.
Bo pa zanimivo kako se bodo tozarili s tistimi ki so to ze pretvarjali v EUR ali morda celo si prenakazovali na TRR (ni jasno ali so kateri uspeli poleg pretvotbe v EUR tudi ze na TRR spravit).
- spremenil: Lonsarg ()
ChirkKarlle ::
Možno, da je bla panika, ker so mislili, so da je to Saylor začel dumpat. :D false alarm, upssss ;) čisto po naključju, ko je fear index 5. Lol
nurmaln ::
A ne pravi Buffet, da moraš kupovati ko drugi prodajajo?
Buffet pravi da ne bi dal 25 dolarjev za vse BTCje skupi, al nekj tazga.
Kripto ::
Še vedno je pa zmagovalna kitajsko novo leto 2018...ker so Kitajci šli domov
Bil je konec cikla bull run, ampak ne krivo je bilo kitajsko novo leto
Za vsak konec cikla se najde novica...ko neha igrat muzika se išče novica.
Wealth is mindset!
pujsekpepe ::
Evo ze gre gor. Bithump bo dal bitkojne nazaj
- spremenilo: pujsekpepe ()
stroj66684 ::
The Phantom Supply Problem: How Wall Street's Derivatives Machine May Be Quietly Dismantling Bitcoin's Scarcity Thesis : https://www.webpronews.com/the-phantom-...
bonanno ::
ChirkKarlle ::
ChirkKarlle ::
Naslednjih 14 dni bo ključnih, vsaj en teden bo hard bullish, pol pa lahko 30 ali 40 who knows.. :D
Na koliko % beara smo? Časovno bi rekel konec 1/3ne
Halving btc je še dobri dve leti
- spremenil: endelin ()
oracle ::
Bi bilo smiselno.
Naslednje vprašanje: če je bila bikovska faza dokaj šibka, ali bo tudi medvedja dokaj šibka? Ali pa so medvedi prevzeli večino in bo padec brutalen? In: Glede na vse geopolitične nestabilnosti in napihnjenost tehnološkega sektorja, ali lahko z gotovostjo pričakujemo hud kolaps že zaradi tega?
pujsekpepe ::
Enostavno ni vec retaila, kupovat btc pri teh cenah je passe, altov je pa tud prevec da bi delal x-e.
To je to.
To je to.
Zelo dvomim da do halvinga ne bo velikih pretresov na kripto trgu.
Spet so oživele zgodbice z btc 0usd. :D
Nikonja ::
ChirkKarlle ::
Luna je prešla v Bogomoljko in tudi graf nakazuje močne bike na obzorju. BTC 260k
Glede na to, da Luna v Trpotcu letos ni obrodila sadov(kot prejšnje cikle), lahko z gotovostjo zatrdim, da je cikel tragično preminil.
Lp Marjan
Lp Marjan
da smo v super ciklu in da je to samo zdrava korekcija?
Lp Zvone
Lp Zvone
Špricer ::
Traktor ANALiziraj ti tehničar. 70000 odboj dol. Raketa ki strmoglavlje, rdeči noževi. Krvave rokr. Lopof. Gotof si.
Benny123 ::
Zdej govori se da ni super cikel, da je likvidnost majhna na trgih, zaradi kitajske pa se je folk selil v kovine, ker tam država printa kot nora baje in ker je crypto banan, folk kupuje zlato.. govori se da je 4.letni cikel in bo dno enkrat do oktobra med 30000 in 50000 dolarjih
- spremenilo: Benny123 ()
Špricer ::
Idioti sayloru f glavi špila.
Strategy bought 1,142 BTC between February 2 and 8.
The company now holds 714,644 BTC which it acquired for $54.35 billion.
The MSTR stock is down over 5% at the market open today.
Strategy, previously MicroStrategy, has announced another weekly Bitcoin purchase despite its current unrealized loss of around $5 billion on its BTC holdings. Meanwhile, the MSTR stock has lost some of its gains from last week's close amid Bitcoin's drop below $70,000 today.
MSTR stock price crashes more than 17% to $106.99 as Bitcoin plunges below $65K.
Strategy reported a massive net loss of $12.4 billion in Q4 2025.
Strategy sits an unrealized loss of nearly $8.50 billion currently.
CFO Andrew Kang said Strategy's capital structure is stronger and more resilient today.
Strategy Reports Massive Net Loss
MicroStrategy reported a net loss of $12.4 billion, or $42.93 per diluted common share, in Q4 2025 earnings results, as compared to a $670.8 million loss reported in the same quarter a year earlier.
The company reported an operating loss of $17.4 billion due to an unrealized $17.4 billion loss on its digital assets under fair value accounting. Total revenues increased 1.9% to $123.0 million year-over-year.
"2025 marked a landmark year for corporate Bitcoin adoption, supported by the implementation of fair value accounting for bitcoin, clarity that unrealized gains on bitcoin are not taxed under CAMT, and the relaunch of our S&P credit rating," said chief financial officer Andrew Kang. "Strategy's capital structure is stronger and more resilient today than ever before," he added.
- spremenilo: Špricer ()
Kripto ::
To kar počne Saylor me zelo spominja na film Rogue trader...film po resničnih dogodkih. Če kdo še ni gledal, naj pogleda.
Wealth is mindset!
