kripto splošna debata
Lennzi ::
Ja čakate zdej, kako? A ni xrp top of the top, game changer?
Zakaj pa potem v zadnjem letu 50x rast, če pravite, da je nateg?
Nič več ne razumem.
Špricer ::
At its core, the Ripple business model is a pump and dump scheme, as it undergoes numerous activities to increase the value of the XRP cryptocurrency (crypto). Unlike most crypto pump and dumps, however, Ripple takes numerous steps to obscure this basic fact.
The starting point in the chart above is the issuance of many billions of XRP tokens - essentially printing Monopoly money out of thin air, except that you can play Monopoly with Monopoly money.
To obscure Ripple's founders' intentions, however, an open source 'community' - not technically Ripple itself - issued the tokens. "XRP is open source and it was not created by our company, so that existed as an open source technology," explains Ryan Zagone, director of regulatory relations for Ripple. "We didn't create XRP."
Lennzi je izjavil:
Nič več ne razumem.
https://www.forbes.com/sites/jasonbloom...
  • spremenilo: Špricer ()
Ajki ::
Špricer je izjavil:
Lennzi je izjavil:
Nič več ne razumem.
XRP je že skozi skethcy ne vem zakaj je toliko navdušena na njim, ampak mogoče je kaj kar ne vem.
Prodajajo pa na polno da se financirajo.
https://KriptoSlovenija.si
http://discord.kriptoslovenija.si (1000+ uporabnikov)
Lennzi ::
Hvala za realne odgovore.
Ja tukaj na forumu je en Merlin, po profesiji zavarovalničar, ki ga na veliko promovira. Res da ta dotični verjame tudi, da je zemlja ravna, da nam vladajo kuščarji in še v mnogo za nas laike teorij zarote, ki to niso.
Pa tudi eden redkih, ki res zna, kriptobog aka bog I batina verjame vanj in ga je kupil, za njega ubogih 500k. Ampak on ima tak risk management, da tudi če to izgubi, na drugih assetih dela par 10% dnevno.
Sedaj pa dosti heca.
A potem rajši prodam ali dokupim tele ISO20022 projekte?
globoko grlo ::
Kup, itak gre na 10 al pa 20, enkrat do konc stoletja.
PrihajaNodi ::
V kuscarhe tudi sam verjamem da je zemlja ravna pa ne cisto
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
Ajki ::
Pri XRP mi ni všeč da dejansko nimajo nekega pravega on-chain governenca in tudi validatorji niso najbolj samostojni, tako da koliko in na kakšen način dodajo tokene v cirkulacijo je vprašanje.
Če vpoštevaš da je še 56% supply na voljo je kr scary.
Problem Rippla je v tem da pride "FURS" in reče da naj osebi oz denarnici AXCVDAFKSDOFJSOF vzamejo vsa sredstva in se to dejansko lahko zgodi... medtem ko se to pri BTCju pač ne more.
PrihajaNodi ::
Sej tether isto
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
haudauprodau ::
Vsi pričakujemo, da bo BTC enkrat 300k ali več. Zakaj se nikoli ne zgodi scenarij, katerega pričakuje večina ljudi in vedno odnese največji dobiček manjšina? Ni fer!
Jaz bi želel, da gremo vsi v penzijo letos in da vsi vozimo Lambote!
BTC bo nekoč 300k, že zaradi inflacije FIAT valute... ampak bistveno vprašanje ni ali bo nekoč BTC 100k, 200k, 300k ali 1 mil EUR, ampak koliko boš takrat za te EUR dobil v trgovini? 1 kavico? 1 avto? 1 flet? 1 vilo?
matic492 ::
Penzija in Lambo bosta ja, samo ne če si investiral 100€, ampak par deset jurjev vsaj, če ne 100k+
IgorCardanof ::
IgorCardanof je izjavil:
Tezos med top gainerji med top 100. Pričakujte market wide flush v roku 24ur.
Tole šteje za dober indikator ali ne? Ni bilo 24ur, pač pa 42 ur.
Ne odgovarjam na DM.
PrihajaNodi ::
xtz je bil vedno indikator. Ko gre gor se market sesuje.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
dope1337 ::
dope1337 je izjavil:
Mogoce en dobronameren hint, kam parkirati FIAT.
Ramses exchange je od ARB DAO prejel ~1,3mil ARB kovancev (STIP backfund prop), ki jih bo naslednje ~3 mesece porazdeljeval liq providerjem. Trenutno je na usdc/usdc.e LP okoli 50% apr v obliki ARB + xoRAM. Efektivno, je to 25% apr-ja, ki ga lahko izplacate takoj (arb->usdc swap).
Ce ne zelite 1tick CL-jat, se lahko posluzite tudi storitve od Gamma.
That's the post.
In… Je padla Gamma ;(( exploit na arb delu ALM-ja je drainal USDC/USDC.e LP.
Bi se ze lahko naucil, da v tej temi ne smem resno sodelovati, ampak samo trollat.
-Albert Einstein
PrihajaNodi ::
matic492 je izjavil:
Penzija in Lambo bosta ja, samo ne če si investiral 100EUR, ampak par deset jurjev vsaj, če ne 100k+
100 k v medvedu na ordi, icp, sui, so ti lahko ze penzijo prnesl. 500 jurjev sta dva ok fleta (pri ordiju bi lahko do miljoncka prlezu s 100k). Od vsadzga pobiras 750 uer (oddajas na crno:) in je to 1500 na mesec. Hell, ker penzijoner pa dobiva tko penzijo po 40 letih dela...Pustmo borcevske penzije.
V kaki juzni ameriki, aziji mas lahko super zivljenje.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
lejko0 ::
Svetujem vam Chromio (CHR). Če se bo bull market nadaljeval lahkih 2-5x.
Ajki ::
Ima point ( če ni fejkal RSI na grafih)
IgorCardanof ::
That's the post.
A je vse ok? Upam, da niisi preveč izgubil. Si eden redkih, ki pove kaj pametnega.
Ajki je izjavil:
S tem da citiraš PlanB idiota, pa zgubiš popolnoma vso kredibilnost. Škoda.
Ajki ::
Nisem finančni svetovalec, ne prodajam paketov in izražam samo svoj pogled na situacijo v upanju da me bo nekdo popravil z dejstvi tako da lahko temu primerno spremenim mnenje.
Glede na to da zgodovina celega kripto marketa od samega začetka deluje v ciklih, kjer so peaki vedno leto+ po bull marketu, lahko rečem da za moje pojme ima point. Zgodovina sicer ne pomeni da se bo vedno isto ponavljalo ampak dokler vsaj 1x ni drugače predvidevam da bo tudi tokrat tako. Kar pomeni Bitcoin peak v letu 2025 (z majšo verjetnostjo v Q1 2026)
PlanB mi je pa itaq mimo kar se tiče njegovih ugibanj do kam in kdaj bo cena šla, none stop prilagaja svoj Stock2Flow ko mu stari useka mimo.
p.s. Bookmarkam link da obiščemo ta post v 2025 in da vidimo kakšna bo takrat situacija.
doktorproof ::
haudauprodau je izjavil:
Lambo je neuporaben voz, pa še grd povrhu. Ne moreš z njim v gozd po gobe , kostanj, drva, ne moreš z njim vozit gradbenega materiala, vleči prikolice... Samo kurčiš se lahko in to zelo glasno pred ne vem točno kom. Duster je prava stvar!
Kripto mesi ::
Jaz furam lambo Urusa, pa lahko počnem vse kar si naštel, tako da ne nekaj na pamet.
matic492 ::
Če nima šibedaha pa vlečne kljuke je zanič avto.
Rešitev je Porsche:
Špricer ::
Še čisto malo da pade sol do 90 in btc do 40000 nato pa take off.
dope1337 ::
That's the post.
Ajki je izjavil:
Pa … odvisn kak gledas. Za ene 14 Dominikanske je blo, pogreba pa ne bo zarad tega. DeFi pac … borbas naprej, pa gremo nasi.
-Albert Einstein
matic492 ::
Še ena malo bolj resna, da ne bom samo trollal:
https://twitter.com/DDhopn/status/17403...
Plutus direct debits :) Ko bo tole na voljo za vse in bull run, bom kar vse mesečne račune vezal k njim hehe, na Delavski Hranilnici sam še kredit.
PS: Če kdo rabi referal, jaz sem kupil tisti merch paket novembra za 250EUR, tako da bom imel Gold ticket referale na voljo ($50 dobiva oba), samo zaenkrat jih še ni.
https://app.loopedin.io/plutus
Res smešen je ta kripto, dejansko edina kripto zadeva, (poleg crypto.com), ki jo uporabljam čisto vsak dan in vse plačujem z njimi, pa ima MC samo 100 miljonov. Razni meme coini pa 10-50x tega :D
  • spremenilo: matic492 ()
MisterR ::
Kaka resna zadeva?
Če hočeš uporabljati Plutus moraš imeti Curve, druge opcije ni. To je tako kot da bi ti NLB rekla, da moraš uporabljati NKBM kartice.
Po pol leta, odkar so menjali ponudnika, še zmeraj ni mobilnega plačevanja (google pay/apple pay), kao da je težava pri googlu in applu.
Fizičnih kartic še zmeraj ni (naj bi šle v izdelavo! do konca tega meseca).
Kdaj bo DEX? Naj bi bil v prvi polovici 2023, sedaj nekje v Q4 2024. Mogoče.
PLU bazira na ETH chainu, najdražjemu. Zakaj, ne ve nihče. S PLU itak si nimaš kaj začeti načeloma, da bi človek rekel da res rabi ETH chain.
Direct debits bodo sprva na voljo samo v UK. Mi v EU bomo čakali do Q4 ali 2025.
Blokirali so nakazila denarja iz Plutus denarnice/kartice nazaj na Revolut/Curve, kao zaradi povečanih zlorab. Torej si prisiljen imeti denar gor, ker dol ga tako ali (razen da ga zapraviš) ne moreš dobiti.
V Q1 2024 bodo v aplikacijo dodali možnost dodajanja slik računov katere si plačal s Plutus kartico. Jaka funkcionalnost. Ko bi le znali povezati te slike s transakcijami in jih avtomatsko/ročno odobriti. Ampak bog ne daj, ker to bi bilo že preveč high-tech.
Da bi aplikacija znala prikazati trenutno vrednost PLU je preveč.Da bi spletna stran znala prikazati, kdaj se bo določen cashback sprostil je pa tudi nekaj kar ne moremo pričakovati.
Torej o kateri resni zadevi si govoril?
  • spremenil: MisterR ()
PrihajaNodi ::
Jajca, revolut-a ne bo nihce prehitel. Transakcije brez feejev:)
Sicer pa nekaj podobnega plutusu je nabijala bankera, že kar nekaj časa nazaj.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
matic492 ::
MisterR je izjavil:
Kaka resna zadeva?
Vse je res ja :) Samo enkrat bojo zrihtali. Zakaj tako dolgo traja pa ne vem, jaz bi rekel da birokracija, ker sprogramirat te zadeve ni ravno problem.
MisterR ::
Ma kaka birokracija, lepo te prosim. Nesposobni so.
Poglej si kak kader iščejo pa ti bo vse jasno https://plutus.jobs.personio.com/
sedaj pa si poglej https://www.revolut.com/careers/ ali https://traderepublic.com/en-si/about#c...
Na njihovi spletni strani na veliko piše
Bank-like App
Track your crypto rewards and manage your fiat balances in a bank-like app.
Ne se šalit, da je to resna zadeva. Zadeva laufa, če si sproti nakazuješ keš gor, 100EUR po 100EUR in da dobiš perkse ter tisti cashback. Da pa bi to uporabljal za kakšne resne zneske pa ne hvala.
PrihajaNodi ::
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
matic492 ::
Niti ne, nima nobenih perkov in cashbacka
@RockyS, kaj je potem po tvojem boljše? Torej da si nakazuješ gor po 100EUR in porabljaš pač za sprotne zadeve?
S 5 perki in 5% cashbacka dobim na plutusu okoli 150-300EUR na mesec nazaj, odvisno od tega koliko porabim. Crypto.com ponuja podobne perke šele pri 35000EUR + lockupa.
MisterR ::
Nakazuješ si pač koliko porabiš. Če veš da si boš danes v bigbangu kupil TV si pač naložiš tisti znesek, nikakor pa ne gor pustiti ležati neke vsote. Tudi PLU si redno izplačuj preko Rabitta (nižja provizija kot Metamask).
Ja, res je da dobivaš ven 150-300, ampak kakšna pa je tvoja izpostavljenost oz. koliko PLU stake-aš? Tega ne pozabi. Pa tudi ne da je PLU bil letos 10.2EUR, sedaj je 5EUR
P.S. za druge, tukaj je kalkulator https://plutus-rewards.cc/
P.S.2 obvezno si shranjuj vse račune, ker če ti ob izplačilu PLU zavrnejo kak račun si oplel.
P.S.3 fajn je tudi če imaš kake ponudnike naročnin ki omogočajo plačevanja s kartico, recimo HOT, BOB, Telemach... Da bi le še UPNe lahko kako plačevali s temi karticami. Sedaj sem pogledal in očitno ima Gorenjska banka najnižjo provizijo za nekomitente, 3EUR.
matic492 ::
Je res ja, samo sem itak konvertal moj Crypto.com stake v PLU in imam iz tega. Profit z cashbacki je trenutno v PLU 100% (moj, torej podvojil sem si število PLU s cashbacki), je pa vrednost nihala v EUR. Tako da do 5% cashback levela sem prišel samo z cashbacki samimi, nisem veliko dokupoval.
Pa še ni stake, tako kot je na crypto.com. PLU so na mojem walletu, z mojimi keyi in lahko kadarkoli prodam na DEX-ih, to je velika prednost, čeprav sem vseeno vezan na nihanje cen.
Pač zaenkrat IMO boljša opcija ne obstaja.
Če bodo dodali direktne bremenitve, bom prestavil vse moje stroške gor in pač nakazal gor tistega jurja ali 2 pred 18-im vsak mesec. Držim pa denar itak ne gor, ker nima smisla, EUR držim samo na varčevalnem računu na Delavski Hranilnici zaenkrat.
PrihajaNodi ::
Korekcije je konec
Legenda pravi da rosi se shorta do 18 k
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
matic492 ::
BEAMX je 40% up danes, pa ravno včeraj sem dokupil nekaj mallega skoraj na dnu korekcije hehe.
Špricer ::
PrihajaNodi je izjavil:
Korekcije je konec
Spet se zafrknil...no do novega padca pri 50000...pričakoval sem 40000. Lepo nas prinašajo okrog. Tehnične analize so za en drek. Samo sentiment in manipulacija.
IgorCardanof ::
Enako. Sedaj mi pa ni nekaj, da bi ga kupil. Je pa res da glavni KOL na twitterju shillajo tudi Beam sedaj. Sem pa ujel Solano na 85$ pa Mina na 1.16$. Lahko bi bilo sicer dosti boljše, če bi menjalnice delale.
Isti k*** kot:
https://bankera.com/personal/card/
Zdaj si me spomnil na to, kako si bedel do 3eh zjutraj, da si zarinil konkretno v Bankero. Lepo videt, da spletna stran še zmeraj dela 8-)
PrihajaNodi ::
An article predicting all Bitcoin ETFs would get denied went viral.
Ja. Ni blo glih 500 jurjev (ki je revscina) ene 2.5 k pa res. Tko da te kripto jajca bank se ne grem vec. Celsius je tud pogoru.
Mi je pa xtz flat kupu.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
PrihajaNodi ::
Ti bi lepo kupoval icp pa rose ko sem jih shilal. Icp je bil pod 3.
Obadva sta solid coina
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
Siso ::
glory ,luzers
matic492 ::
Špricer je izjavil:
Prej ko si to zrajtaš, boljše za tebe :))
Siso ::
IgorCardanof ::
Short je sicer že kar konkretno v minusu, ampak verjamem v TA, tako da sem si kar naštimal buy order na 18k da zaprem pozicijo. Bo na koncu lep profit ven. Če gre pa višje gor, pa normalno dodam na short. :P
Siso ::
drgač,a tle n slotehu mate saund
fakin luzers
Hvala za program,Slotech je dober forum romanum,
  • spremenilo: Siso ()
Siso ::
Nočem bit tečen,ampak res bi rad vedel na kakšnem zvoku ždi povprečen Slotech uporabnik ,namreč,distribucija zvoka se meni zdi eden večjih doseżkov oz.izumov u zgodovini Človeštva..upliva na marsikaj kvaliteta slišanega...
...u zgodovini izumov......
matic492 ::
Zvočno kartico imam ja, v matični.
Siso ::
Guten aben from Switzerland
https://m.youtube.com/watch?v=E9UMIQmlL...
bozicek ::
Je kdo kaj kihnil v InQuBeta (QUBE)
Sedaj poteka presale
Sem dal notri 100€ viška pa da vidimo kaj bo
Darila letos samo za poredne
Peter41 ::
Kaj pa MYRO, v dveh dneh je šel lepo gor, ima kdo info ali bo listan na kakšno večjo menjalnico, takrat bi znal potegnit kak x gor al kako?
1377 / 1643
