Forum » Kriptovalute in blockchain » kripto splošna debata
Prebranac ::
PrihajaNodi je izjavil:
Kaspa vam dobr dela. Cestitke
Kot vsak scam coin....veliko gor, še veliko dolje...
Kaj govoriš? Kaspa je fairlaunch. No ICO, No premine...
Povej če kaj ne vemo.
Kaj bi rad? Nategovanje kot fse do sedaj. Whitepaper, nakladanje, oh in sploh povezljivost. Prodaja se dokler je reklama. Nato sledi padec ko zmanjka hopiuma za snifanje. Nea gusi prosim.
Prebranac ::
I have seen some of the $KAS community tout it as a Bitcoin 2.0 . That it was "better" and improved.
Just an FYI.. $BTC had a fair launch and there never was (need?) for a crowdfunding for listing.
I see a centralization point (the bottleneck where "someone" gives the money to list).
Controversial crypto personality Ben Armstrong also commented on the KAS coin, saying it is a "promising" project. Given his reputation for shilling other projects, the mention might not do Kaspa any favors.
ŠE KAJ?
Nakladanje da te prime srate...kratice in cool poimenovanje da ribice zagrabite
The world's first blockDAG- a digital ledger enabling parallel blocks and instant transaction confirmation, built on a robust proof-of-work engine with rapid
single-second block intervals."
Kaspa does what no other crypto has done..
It solves the trilemma.
ŠE KAJ?
- spremenilo: Prebranac ()
Prebranac ::
Ker je bil zagnen shibarium je zacasna pumpica shibe. Vlovite val do 0,0012. Xrp se pa lepo drzi, ali je naslednja postaja iso 2023 hodlerjev 0,3?
TA je ološ. Igra custev in botof...casino alwais wins.
Prebranac ::
Za 5% procentof profita je smisleno zacasno vloziti tudi v shiba tokene kot je bones npr. Potem pa ob platoju prodati, da vas drugi panic sellerji ne dohitijo.
Kripto ::
XRP gre lahko tudi precej nižje...na 0,20. Na dolgi rok je to nepomembno.
Wealth is mindset!
Senior Dev ::
Gotof si. Ovi se sam s sabo pogovarja že 2 tedna. Čuj, ti si duševno bolani.
Prebranac ::
Senior Dev je izjavil:
Imam dve vstopnici za Ormož. Zate pa forenzika v Maribore.
Res nora igra custev in gamblinga. Fse gre f kurac. Do 2024 ne pricakovajte bulla.
Kripto ::
Ti povem, da ne gre fse v kur... Take it easy, čas je za potrpežljivost, ohranjanje hladne glave, preizkušanje živcev in weak hands.
Wealth is mindset!
- spremenilo: Kripto ()
Konec je. Odnehajte in nam prodajte.
Bull se zacne, ko v temi ostaneta samo se Nodi in Senior Dev. Prosim!
- spremenil: kow ()
Kripto ::
Mene pa iz radovednosti zanima kaj ima od tega Žan Nekrep, ko stalno ponuja neke brezplačne webinarje, vse je brezplačno ipd. na različnih področjih. Od kripta, drop shippinga, nepremičnin itd. Na kakšen način vleče denar...pri vsem tem bajnem zaslužkarskem uspehu? Verjetno shila vse te uspešneže in dobiva procente, ker jim folk denar nosi v njihovo upravljanje ali pa kakšne ponzi sheme?
Saj niti ne bi spraševal, če se mi ne bi vsak dan vsaj 15x pojavil ko kaj poslušam na youtube.
Wealth is mindset!
kriptobog ::
Ker na koncu ni zaston. Na brezplacnem webinarju dobis cenik
TheMentor ::
Samo poglej graf KAS. Podoben kot BTC na začetku. Zdej, folk je najbrš zadevo preučil in taka rast v zadnjem letu ni kar naključje kot shitcoin. Shitcoini ponavadi ne rastejo cel bear market v takem stilu kot raste KAS.
Zadeva je najbrš edini pravi konkurent BTCju. Tudi zaradi tega, ker je kar velika verjetnost, da je bil founder zraven tudi pri kreaciji bitcoina in zato zelo dobro ve kaj je šlo tam narobe kar se tiče skalabilnosti. Isti founder je bil tudi omenjen v prvem whitepaperju od etheruma. Model je eden pionirjev blokchaina, ko se je vse skupa začelo leta 2009. Njegovi članki so dokaz.
kako se bi smejal, da bitcoin maxiji začnejo pretapljat zadevo v KAS in usi saylorčki pušnejo.
Potencial v bullu je 100 miljard. Torej 100x od tukaj kjer smo.
Spremljajte hashrate. To bo najbrš edini pravi pokazatelj potenciala in zaupanja v kovanec. Usi mislimo, da je btc nesporni kralj in ni mogoče, da se ga izrine iz prestola. Mogoče. Mogoče je pa btc samo Netscape in Chrome še prihaja.
- spremenilo: TheMentor ()
IgorCardanof ::
Dokler bo kripto taka šala kot je in je njegova glavna vloga in edina uporabna vrednost to, da je največji svetovni kazino za profesionalne in amaterske gemblerje, do takrt bo Bitcoin 100% številka 1.
Ko pa se bo to začelo spreminjat (če se kdaj bo), potem pa ima šanso, da ga kdo nadomesti.
Btw, a Kaspa sploh že kaj ima? A kaj dela gor? A so jih samo same besede, kot 99.999999999% drugih kripto projektov?
Ne odgovarjam na DM.
- spremenilo: IgorCardanof ()
TheMentor ::
IgorCardanof je izjavil:
Zaenkrat je funkcionalnost ista kot Bitcoin. Torej Store of Value. Usi fundamenti so enaki kot pri bitcoinu s tem, da so rešili skalabilnost. Zadeva je lahko uporabna za mikro plačila brez dodatnih layeryev kot je bila potreba pri bitcoinu in to na globalni ravni mikroplačila.
Security je odvisen od hashrata. V tem segmentu najbrš se še ne more primerjat z bitcoinom, čeprav trenutno zadeva raste. Zato sem rekel, da je potrebno spremljat hashrate kot indikator kako bodo minerji zadevo uzeli resno. Pomoje je tukaj največ odvisno od minerjev, če se bomo lahko pogovarjali o konkurenci k btcjju.
V planu so Smart Contracti (timeline za njih je več kot 1 leto), ampak če dobro razumem trenutno vizijo, ki jo imajo je, da se konkurira btcju in niti ne toliko ethru.
PrihajaNodi ::
Clovk poglej si razvoj ade
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
kiFni ::
Ja ta hashrate pokazatelj je trenutno vprašljiv, čez teden ali dva dobijo prvi naročniki asic minerje. Kratko-srednje ročno je lahko dump, kdo ne bi dumpal če majnaš z velkim profitom.
IgorCardanof ::
Ne trigeraj me, Nodi!
Blue30 ::
Kaj zdaj, si že nakupil cardanote?
PrihajaNodi ::
Js sm dau se 50 taka v ado. Charles ve kaj dela.
Gre pa lepo gor, nic ne kaze na korekcijo
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
- spremenilo: PrihajaNodi ()
Rossi V ::
korekcijo dozivijo kovanci,ki pumpnejo,korekcija=vzet ljudem,ki so vložili.Ada ni naredila praktično nič tako da cene kovancu ne rabijo zniževat.Je bo deležna pa septembra-oktobra, tako kot vsi alti Na nov ATH pa na tvojem mestu ne bi računal
Samo itak nižje kot je, jo že težko pošljejo
no samo nižje se bo pomoje sla,tako da mi ni jasno zakaj raje ne naberes tega jurja in ga vložiš na dumpu altov
- spremenilo: Rossi V ()
Rossi V ::
sicer bi bil za ado čas tudi za tistih svojih par centov nazaj pomiga....matr je ne maram .ko je krvavela....enostavno nisem mogu pritisnit tipke buy
RNDR mi je postal ušeč ,čakam na "KOREKCIJO"
Kakšna mnenja?
mal se z alti počas začenjam ukvarjat....počas
Ima kdo kakšno mnenje o njem ?
Kakšna mnenja?
IgorCardanof ::
Cardano lepo pada. Še ene /100 je oddaljen od svoje recimo realne vrednosti, ampak mu gre dobro. Pri vrhu je bil x1000 precenjen, sedaj pa samo še x100. Le tako naprej
Sicer pa dober point, ki ga je nekdo omenil. Morda se splača it v Cardano je on par s recimo Hex kultom. Težko najdeš večji kult v kriptu. To pa pomeni, da sodelujejo osebki, ki bodo hodlali do smrti. Se najbrž da dobro zaslužit na teh revežih.
PrihajaNodi ::
Pusti Ado pr mer, pac si jo prodal. Weak hands.
Drugace pa se vedno ICP pa Rose. Nym pa takrat ko bodo povecal supply.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
Rossi V ::
očitno ne.....ušeč mi je
Razmišljam o RNDR namesto ICP.....kar se pa Rose tice mogoče bolje Fetch in Ocean,inj
PrihajaNodi ::
Pol pa kupi rdnr. Se vedno trdim da gre icp gor
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
Rossi V ::
Gor bojo sli vsi konec leta 2024.....samo koliko in izmed vsega srota katerega izbrati,ki bo najbolj pumpal
Mene zanima kaj si mislite o RNDR.Ga je kdo sploh opazil?
Jaz sem ga :-)
Rossi V ::
na pamet govorim.......5000 kovancev imate....na koga boste stavili?
Ok Nodi nima slabih.....ICP,rose,ADA...čeprav kurceve ade ne maram.......
Kaj imaš še Nodi?
xrp kaj se?
Kaj imaš še Nodi?
xrp kaj se?
PrihajaNodi ::
Ne ade nimam sarkazem detektor ti je crknil. Nym se kupim ko zdumpajo supply
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
globoko grlo ::
Baje da ma rdnr se vecji potencial kot inj, pa inj naj bi sel po poti lune, ta prve bull lune ;)
Upam da ja :)
Upam da ja :)
Rossi V ::
globoko grlo je izjavil:
Upam da ja :)
počasi bom moral z btc ko izgubi dominanco presaltat na alte....o čemer sem vam govoril.....in ta moment mi je rndr največji potencial .......ni 100x kovanec ,da se razumemo.......teh niti ne iščem oz jih bom 2024
Imaš rndr?
Definitivno se strinjam,da ima večji potencial kot INJ kakor sem ga v tem kratkem času spoznal
Svoj kapital bom kot sem vam govoril ,ko btc zgubi dominanco razpršil na 10-15 altov in kakor zdaj gledam bo RNDR imel velik delež
Debatiram z vami
Brez sarkazma
Rossi V ::
kar se mojega mišljenja tiče: obadva ščita o katerih sem vam govoril sta izgubljena in je dobil potrditev za navdol.Možna je manjša pumpa do 31.5k,da še komu potegne peneze, potem pa dol na 28k-27k v primeru močnejšega fuda ( CZ binance ) 24k.bullish postanem ponovno pri 27 ali 24k
Moja tarča ostaja ista
se odvija.....
30200 crucial
Rossi V ::
tole septembra oktobra-novemkbra bo zadnji padec btc najnizja cena 22-24k,Warkraft ce si mislil se kaj dokupit ne cakaj na Merlaka in njegovih 12k on je ze kupil......
Rossi V ::
pa samo upaj na 22k-24k.....here we go!
DOT one leg down and up!
30.6k-30.2k-30393-30k
Rossi V ::
ihaha djmo zadnje solde ko vas influencerji pumpajo btc 120k do konc leta!
halving btc!!!
cez 32k ne pride pred crashom sept/okt/nov
29848 fast scalp
halving btc!!!
29848 fast scalp
Rossi V ::
pepko bo zdele počas mignil.....sam kurc ce ne zariješ denarja not,poberes profite in ga kupiš za bull run nizje
Senior Dev ::
Upam na x10 da poberem smetano 200€ profita in grem v penzijo.
Rossi V ::
dve leti akumulacije medtem ko je edini btc ,eth,xrp,ltc ,ki so imeli dogodek naredili
Ko ima BTC dominanco ,alti pumpnejo in nižje dumpnejo ....skoz vam govorim....poglejte si ICP kje je in kje je bil leto nazaj.....samo čakate ,vlagate denar ko btc dela
pomoje si ze v penziji ce ti 200 eur manjka
Rossi V ::
vsi veste,da septembra z btc bodo dumpnili tudi alti....ni mi jasno zakaj jih zdaj kupujete.........akumulacija?.......porasti ne bodo taki kot so bili in zelo pomembno je,da kupite po najnizji ceni
oktober/november
pa vsi tudi verjetno veste,da vas pred halvingom čaka ponovni dump februarja......ta je zadnji kar se btc tice in takrat ce se mene uprasa zacne btc počasi zgubljati dominanco
oktober/november
Rossi V ::
drugace pa ja....pepeta pričakujem pumpo....ampak ce ga ne prodas bo dumpnil nizje....sicer okol 25 eur je itak useen
IgorCardanof ::
Zakaj bo septembra dump?
Če bo še kak večji dip, se pomoje na tem na polno kupuje.
Lennzi ::
Igor a ne veš? Na youTubu in na tiktoku so rekli....ta dobri trejderji aka influencerji.
Rossi V ::
EMA50(D ) je bila zgubljena,kar sem vam ze povedal,torej gremo dol.Btc se premika natanko proti likvidnostnemu bazenu 30100-32k.Najverjetneje bodo zagrabili likvidnost,nato sledi masaker bikov
27k,zelo verjetna 24k (FUD ).vse sem vam ze povedal.avg/sep/okt imate moznosti nakupa po najnizjih cenah
Na 12k pa ne cakajte
Na you tubu in tik toku se tudi ze širijo "insajderske informacije" da je BTC ETF že odobren....kar ne drži
Rossi V ::
pa brez panike....ko boste ugotovili,da 0,5 btc ja ne bo dovolj za vasega lambota ali penzijo boste zdaj dobili moznost za dokup
Torej Rossi, hočeš rečt da je predikcija da bo BTC šel do 30k+ in nato v roku 2 mesecev najkasneje pod 27k?
Rossi V ::
moje mišljenje je ja....da bodo zagrabili likvidnost med 30k-32k ,nato sledi padec do 27k v primeru večjega fuda 24k ( CZ binance )
kiti bodo akumulirali vsak short
pa ponavljam tole ni finančni nasvet v moji analizi par mesecev nazaj sem vam tole vse skupaj že napisal
O vašem denarju odločate sami
Časovno je težko določit kdaj ,govorile bodo stevilke,kdaj se market mejkerji odločijo praznit likvidnostne bazene spodaj
likvidnosti zgoraj je bore malo,na 24k pa ogromnno
Povprecen čas za odobritev ETF traja 8-16 mesecev.Ljudje z ničnim znanjem o pravdnem postopku odobritve ETF zdaj FOMO kupujejo BTC
Rossi V ::
Da sta Microstrategy ( Sailor ) in Blackrock povezana pa seveda veste .Kaj to pomeni pa tudi
