DarkSite ::
wtf: :D
Russian media:
"The source says there is panic in the Kremlin, no one can reach Putin"
"Source: Right now the Kremlin is negotiating about something with general governor Dyumin"
Source: Some people in the Kremlin, from the presidential administration, are finding out about a possible emergency relocation. One of the few available destinations is Uruguay".
https://twitter.com/machiavelli_gr/stat...
  • spremenilo: DarkSite ()
DarkSite je izjavil:
wtf: :D
Zakaj Uragvaj, če gre lahko pobirat krompir v Belorusijo?
On June 24th at 00:01 Lukashenko's personal business jet Bombardier Challenger 850, number EW-301PJ, took off from "Minsk" National Airport and flew in the direction of Moscow.
Arresting Prigozhin is no trivial job. He has an almost unparalleled Pretorian guard and his security chiefs were poached from the best FSO and FSB had on offer. And they've been preparing for this moment for months.
Tomorrow will be an interesting day. One way or the other.
wcpapir ::
Izgleda, da ima Moskva lockdown :D
Dejansko jem kokice in malo spremljam tu gor, kaj se dogaja. In potem baje Rusija zmaguje, pravijo Rusofili. :)):D
Drekožin je baje zagrozil z maščevanjem Kremlju. :)
https://edition.cnn.com/europe/live-new...
  • spremenil: BorutO ()
Wrop ::
FSB Border Guards were ordered to allow the Wagner PMC columns through from Ukraine at the border check point in Rostov region, Russia. Prigozhin appears to have planned the coup meticulously and secured many allies at high places within the Kremlin regime.
Zgleda, da se bodo kar sprehodili do Moskve.
Težko, ker na Bildu pišejo, da so postavili moskviči avtocestne zapore na večih mestih ... po mojem bo še pokalo nocoj. :D To bi bilo svetovno, če bi prišli do moskve. :D
Na bildu še pišejo, da je prigožin rekel, da bo uničil vse, kar mu bo stalo naproti, da bo šel do konca. :D
https://www.bild.de/politik/ausland/pol...
Vse kar hočem je, da Putlerja pospravijo, potem pa še tega drekožina. Me zanima kakšne izjave bo kdo dal po tem napadu za javnost. :D Končno bodo Ukrajinci imeli malo več svobode za protiofenzivo :) Naj to rusko golazen natirajo nazaj tja, kamor spadajo - pred letom 2014.
Unilseptij ::
Tukaj ti nekaj ne štima. Če Putina zamenja Prigožin oz. nekdo, ki bo njemu pogodu, bo takoj napadel z vso silo... ali misliš, da se Prigožin jezi na Kremelj, ker hoče mir :D in umik na meje pred invazijo? Njega žuli to, da so dosegli premalo...
Kje je danes tista vsemogočna Rusija, ki jo Rusofili opevajo? Baje, da gre vse po načrtih, da se imajo vsi lepo in fajn ... Lepo imajo sprane možgane od teh putlerjevih medijev. Bolj, ko jim trobiš, da ni tako, kot oni berejo pri teh rusofilskih medijih, bolj trobijo, da je. No, slika se danes obrača. :) Ampak ... kakor koli bo, bo pa zanimiva debata za celo zgodovino Rusije. Kako je vsemogočna Rusija doživela "prvi" državni udar. :)
Današnji dan je tragedija za Rusofile.
Itak, zato pa sem napisal, da moreta oba umreti nocoj. :) Ta drekožin se mi zdi veliko bolj mentalno prizadet kot putler. Ta model hoče samo smodnik in kri. Itak pa drekožin nima šans, ker ruska vojska je velik (kolikor je še je ostalo) in imajo v rokah vso možno orožje, ki ga rusija premore, med tem, ko so wagnerjevci omejeni. Dvomim, da bodo uspeli priti v kremelj. Lahko pa .. kaj pa veš kdo vse se bo obrnil proti putlerju, ki ga mara vedno manj rusov ..
jernejl ::
Kakšno vso silo? Bo dal starim mamam grablje in jih poslal osvajat ozemlje sosednje države?
MadMen ::
Možna kolona?
Čeprov zgleda ta "kolona" bolj kot ne da gre nekdo na protest za bolšo menzo.
  • spremenilo: MadMen ()
Unilseptij ::
Zanimivo bo, to drži.... že RT govori o udaru:
https://ibb.co/dLDK2pn
Keri pester teden :D ... prvo čez 500 migrantov, potem podmornica, potem toča vse povsod, zdaj pa še ruska predstava. :)
Začelo se je ...
Wagnerjevci so baje sestrelili ruski vojaški helikopter.
Šef Wagnerja poroča o streljanju ruskega vojaškega helikopterja
Borci ruske plačanske sile Wagner je po besedah šefa Wagnerja Jevgenyja Prigozhina sestrelil helikopter ruske vojske. "Helikopter je pravkar odprl ogenj na civilno kolono, sestrelile so ga enote Wagnerja," je v zvočnem sporočilu, objavljenem v soboto zvečer, dejal Prigožin.
Po prigozhinih besedah so Wagnerjevi plačanci že prej napadli rusko ozemlje, potem ko je plačani poglavar pozval k uporu proti vodstvu vojske v Moskvi.
sparklyslo ::
The jet of the Belarus Dictator Lukashenko family took off from Belarus and is now in the sky over Turkey .
Upon entering Russian airspace, the aircraft turned off the transponders and turned them on only over Kalmykia, when exiting Russia.
Ti mater. Za Ukrajince je to definitivno dobro, ne vem pa koliko za nas. Za nas bi bilo najbolje, da se dobro zbombajo med seboj, ampak da na koncu vseeno zmaga Putler, ker tist je pa še večji norc. Če to traja teden, dva, bo dovolj da Ukrajinci vržejo ven rusko vojsko, ki ne bo zmogla dveh front, niti ne bo neke volje, če imaš vojno doma.
V vsakem primeru bo ruska vojska toliko oslabela, da bo morala it iz Ukrajine. Upajmo.
  • spremenil: Utk ()
sparklyslo ::
Wagner forces have surrounded the headquarters of the Russian Southern Military district in Rostov.
https://twitter.com/Tendar/status/16724...
Fascinantno, kako v nasih medijih ni omembe dogajanja v Rusiji, razen nekaj obrobnega na Siolu. Ni nocne izmene, ali nimajo twitterja?
sparklyslo ::
"Rostov airfield under Wagner's control, Wagner does not interfere in any way to fight with Ukraine" - Prigozhin
"We lost huge amount of territories in Ukraine. The Russian losses in Ukraine are 3-4 times higher than reported by the Russian High Command. Up to 1000 casualties a day (KIA + WIA)."
Vojska in policija se očitno Wagnerju v Rostovu ni uprla...
yayo ::
Comandante je izjavil:
malce brskam srbske tabloide, tistih par katere poznam, zaradi smeha. Tudi tam so bili do pred pol ure tiho kot riti. Sedaj povzemajo novice iz Guardiana, BBC itd. Ponavadi so novice vezane za Ukrajino polne sočnih komentarjev, ampak trenutno vlada kat tišina. Morda je prezgodaj.
DarkSite ::
Cilj Prigozina bi oz je prvo zasesti in obkoliti RU vojsko. Se pravi od Krasnodorja, Rostova do Belgoroda. Nato lahko celotno RU armado pocasi spravi na svojo stran. Potem je pa konec.
martincek1 ::
Putin bo imel govor ob 8:00 po našem času.
sparklyslo ::
Izjava Prigožona z ang. podnapisi:
MadMen ::
martincek1 je izjavil:
To drži, predvidevam da se bo drama končala. Kako mislijo pa zadevo zavit v celofan in se delat kot da se nič ni zgodilo pa ne vem...
To pomeni, da še veno velja "vse gre po načrtu"?
RedDrake ::
Moj denar je na tem, da je to "izhodna strategija" za Putina.
Zdaj lahko reče "Meni so lagali, jaz nisem vedel da je situacija tako slaba, čas je da prenovimo našo vojsko od zgoraj dol, izdajalce (Šojgu, Gerasimov, ?) zapremo in ponovno ocenimo kaj lahko dosežemo.".
In gre za pogajalsko mizo kjer so v igri tudi stvari, ki niso aneksacija zasedenih območij, ipd ...
Mislim, da jim je že od zime dalje jasno, da te vojne ne morejo zmagati, kar je na dolgi rok katastrofa za Putina. Tudi če Ukrajinci letos ne uspejo s protiofenzivo, bodo pa čez 2 ali 3 leta. Tako kot je Oluja pometla s Srbi, se tu pripravlja podobno.
To je imho edini način, kjer on ostane na oblasti in se vojna za njega kljub vsemu "pozitivno" (na nek način s porazom) zaključi.
Ajde, da vidimo, kaj bo povedal.
P.S.: Pismu, tako zanimivo je, pa glih ta vikend imam na vikendu polno za postoriti ...
  • spremenil: RedDrake ()
DarkSite ::
Kje pa bo prenos govora? link
Sc0ut ::
Kolko raket so spet ponoci na Kijev spustili barbari?
Čeprav, tole vse skupaj je lahko zgolj dobro orkestrirana dimna zavesa, zabava za rajo, da je neka druga stvar lahko skrita pod našim radarjem.
sparklyslo ::
Sheteentz je izjavil:
https://www.rtvslo.si/svet/evropa/prigo...
Kokice, majkemi!
Uh, danes bo zabavno prebrati komentarje zagovornikov Putina. Še posebno tistih, ki dan za dnem opravičujejo specialno vojno operacijo in fantazirajo o nepremagljivosti Rusije.
bla bla, CIA kriva za Majdan .... lahko ugibamo kdo bo za Rostov :D
RedDrake ::
sparklyslo je izjavil:
Prigo bo kriv, itak. Na daleč se vidi da je CIA agent. Saj vidiš da zadnjih nekaj tednov ponavlja zahodno propagando o velikih žrtvah, izgubah rusov, ipd ...
Jasno kot beli dan, da je CIA asset.
/s
DarkSite ::
Za UA je slabše, če zmaga Prigožin.
UA bi edino ustrezalo, če bi se ta situacija zavlekla. Morebiti bo RU povlekla kake enote iz UAja.
Prigozin bo naredil red v ru vojski in nato bo za UA težje.
RedDrake ::
Pozabljaš, da je Prigo v svojih "intervjujih" povedal tudi tole dvoje:
Potrdil je tudi, da so se spopadi leta 2014 v Donbasu pričeli zaradi vstopa ruskih paravojaških sil in šele nato je sledil odgovor ukrajinske vojske. "Ukrajina ni bombardirala Donbasa, temveč samo ruske položaje," je dejal med drugim. Zraven je tudi priznal, kako so ruski vojaški poveljniki kradli po Donbasu.
in pa
V seriji videposnetkov je tudi dejal, da je odločitev ruskega predsednika Vladimirja Putina za napad na Ukrajino temeljila na lažeh, ki so si jih izmislili vojaški vrhovi. "Vojna je bila potrebna, da bi Šojgu lahko postal maršal, da bi lahko dobil drugo junaško medaljo. Vojna ni bila potrebna za demilitarizacijo ali denacifikacijo Ukrajine," je dejal.
Če on "prevzame" Rusijo, komot reče - "lagali so vam, dajmo se sedaj umirit in pogledat racionalno", in gre za pogajalsko mizo kjer "lahko" povleče ven marsikaj "pozitivnega". Recimo, na zahodu se pričakuje, da bo Rusija plačala enormno škodo, ki je nastala. Morda bi se dalo temu "izogniti" s tem, da se rajši zaseže premoženje oligarhov, ki so itak komot tisti "sovražnik naroda", ki je kriv za vse to.
Lej, če poslušaš Prigota vidiš, da je 100% mnogo bolj inteligenten kot Putka in verjetno večina Kremlja. Tak človek, komot zrihta sebi optimum, ki 100% ni nadaljevanje vojne, ampak to da postane on "rešitelj" Rusije. Neke vrste ruski Garibaldi, če hočeš.
DarkSite ::
mikhaair ::
Voronezh
Mogoče pa prigozin ustvarja tamponsko cono med mockbo in Nato UA.
https://twitter.com/KareemRifai/status/...
"THE UKRAINIAN COUNTEROFFENSIVE IS FAILING!!"
48 hours later...
Russia's own paramilitaries are marching toward Moscow.
Vsaj Hinkle je tudi malo griftal
https://twitter.com/Mosesphotoworx/stat...
If you want to remind traitor Hinkle of his past transgressions now is the time
https://twitter.com/DrewPavlou/status/1...
CONFIRMED: THE JACKSON HINKLE WAGNER T SHIRT STORE IS DOWN, I CAN REPEAT, THE JACKSON HINKLE WAGNER T SHIRT STORE IS DOWN. MAY THE LORD HAVE MERCY ON HIS SOUL
video s podnapisi
Just wow. A video has surfaced showing Prigozhin at the Southern Military District HQ in Rostov-on-Don talking to (and HUMILIATING) Deputy Defense Minister Yunus-bek Yevkurov. He threatens to blockade Rostov and head for Moscow!
I have extreme trouble understanding Yevkurov and the cross-chatter, but I did my best here with the subtitles.
P.S. And, yes, I bought a month of Twitter Blue so I could post this slightly longer video.
Wagnerjevci naj bi prevzeli nadzor tudi nad jedrskim orožjem v južnem vojaškem okrožju. Izgovor za kak upsi?
"Nismo bili mi, samo par jedrskih teroristov."
TukiUki ::
Zakaj se mi zdi da je to samo PR show Rusov, da bi se Ukr ponovno ujeli v past v protiofenzivi?
Cope over 9000 :))
Duhec ::
A Lukašenko pa kar v Turčijo?
http://blackbird.si/
RedDrake ::
Če Putka slučajno odleti, potem bo Luka hiter za glavo krajši, če bo ostal na "dohvat ruke" razdalji.
Boljš bit ziher, kot ne, eh?
Če ne bo nič hujšega, še vedno lahko reče, da je šel na dopust na morje, ker mu je doktor svetoval morski zrak, pa je Krim malce preveč nevaren trenutno :)
Tule naj bi bil prenos Putinovega govora, ko pač bo. Že kar debelo zamuja.
https://rutube.ru/video/49184e61b6e8014...
martincek1 ::
Basically, govori da to kar počnejo je treason in da jih bodo uničili.
DarkSite ::
Glede na govor Putina. Se pravi, Prigozinu ne ostane drugega, kot da odstrani Putina.
sparklyslo ::
Putin se ne misli umakniti, govori o izdaji in kaznovanju tistih, ki so se obrnili proti vodstvu.
Tri dni do moskve :D.
Kevin je prevajal
Putin se je postavil na stran Šojguja. Kam bo šlo ljudstvo?
video
https://twitter.com/michaelh992/status/...
Cyclist passes Russian troops in Rostov while blasting "Because I got high".
That's it, that's the tweet.
RedDrake ::
Jah, težko bo tu kaj drugega reči kot:
TukiUki ::
Kako se že zadnji dan smejem :D
Nikec3 ::
Evo točno to. Ne razumem narative tukaj, da je prigožin hujši od Putina. Ne ni! Če Prigožin zmaga gre naslednji dan na rokovanje s Von Der Leyen in Bidenom.
@WarpedOne o Elonu Musku:
RedDrake ::
Jep, jaz tudi to tako vidim.
Možno celo, da je bil v stiku z "zahodom" že dalj časa. Tip je tisti, ki v očeh Rusov "nekaj naredi" za razliko od onih v Kremlju. Posledično je v Rusiji postal popularen, in komot "razreši" tole godljo (jasno najbolj sebi v prid, ampak v končni fazi tudi v prid Rusije in posledično Ukrajine).
DarkSite ::
Nikec3 je izjavil:
Ne. Je kriminalec. Njegovi so kriminalci. So pobijali, posiljevali, kradli, ubijali svoje s kladivi. Ne, ne bo se rokoval s Von Der XXXi, Bidni.
Je pa definitivno bolj realen kot RU vodstvo, ki živi v oblakih. Ve, kaj se dogaja na fronti. Zato lahko sprejema boljse odlocitve, strategije in zaradi tega je lahko bolj nevaren oz težji nasprotnik za UA.
444 / 1549
