Windlass ::
Machete je izjavil:
Dajte nehat nabijat v vse možne smeri v neskončnem krogu in repeticiji, preferirajmo linke in kaj je novega.
Res je, to neprestano onaniranje na rakete kljub milijon razlagam je popolnoma zasmetilo temo. Še par mesecev nazaj se je dalo približno normalno pogovarjat in predebatirat vsako stvar v parih replikah.
https://x.com/clement_molin/status/2092...
The Ukrainian 🇺🇦 General Staff is reorganizing the defense of the Donbas by establishing two distinct zones of responsibility within the "East" Operational-Tactical Group (OTU).
The 3rd Army Corps - formed around the 3rd Assault Brigade (linked to Azov) - is currently successfully holding the northern flank of the Donbas front, between Borova and Lyman (in the direction of Izyum). While this had been announced previously, its operational area now extends to Sloviansk, following the integration of several additional brigades into the corps.
The National Guard's 1st Azov Corps is currently holding the sector between Dobropillia and Druzhkivka, where the Russian offensive is most intense. Having arrived in the sector as a "savior" last year, the Corps boasts an excellent track record, having held a central section of the front for over a year. It appears set to take charge of the defense of Druzhkivka and Kramatorsk, with the 11th and 19th Corps under its command.
The new Chief of the General Staff of the Ukrainian Army, Mykhailo Drapatyi, is entrusting the defense of the Donbas to the two Azov commanders, Andriy Biletsky (3rd AC) and Denys Prokopenko (1st AC). Meanwhile, I believe he will deploy the 7th and 8th Army Corps for offensive operations in the south, as it was the case this year already under Syrskyi.
damirj79 ::
arato je izjavil:
A smo res prišli v čas, v katerem se pogovarjamo, da 200 raket na mesec ni nič?
Model, v Ukrajini skoraj ni več električnega omrežja, ni infrastrukture, ni ... Vsaka od teh raket ima moč par 10 dronov. Kako misliš bi se počutil London ali Munchen, če samo ena od zadane kritično infrastrukturo?
Še več - to je največ kar se proizvaja trenutno na svetu.
Folk, ki se raduje nad vsakim zadetkom drona in razlaga o uničevalni moči le-teh ... ne dojame kaj je prednost 200 raket na mesec?
No, ni nič, ampak kaj veliko več kot nič pa tudi ne :) Če bi se pogovarjali o zalogi na tisoče kosov ali celo 10000 in mesečna proizvodnja 1000 kosov, potem je to čisto nekaj drugega. Ampak če je to zate full veliko, potem pa naj bo no...
Model, a nisi še slišal, v Rusiji skoraj ni več delujočega wildberries skladišča, skoraj nobena rafinerija ni več cela, skoraj nobena bencinska črpalka nima več vsega goriva za vse ljudi... Kako te to nič ne skrbi? Še putina to zelo skrbi. Očitno je dal na papir in zračunal, da 10x dron v rafinerijo ali skladišče je bistveno več škode kot raketa v nek stanovanjski blok. Putinu matematika očitno deluje, tebi pa še ne.
arato ::
damirj79 je izjavil:
arato je izjavil:
še enkrat. Ruske rakete so razfukale vse kar je v Ukrajini in še več. Ti vidiš samo posnetke gorečih bajt, ker je to tisto kar ukrajinska propaganda ŽELI da vidiš.
200 raket na mesec pomeni, da v enem mesecu RAF ne obstaja več. oz. vsaj nima več letališč. to je ogromno in daleč največ trenutno.
Rusi so namenoma prešli iz dronov na rakete. Sej uporabljajo še drone ampak so bistveno zmanjšali njih uporabo.
(dajem za primer, te rakete ne morejo doseči uk)
  • spremenilo: arato ()
damirj79 ::
arato je izjavil:
arato je izjavil:
Ampak RAF še kar obstaja. Ali pač sem kaj zamudil?
Še enkrat, v Ukrajini ruske rakete ciljajo na civilne stavbe in ti je OK, kot to isto naredi Ukrajina na ruske civilne stavbe, cviliš kot muca. In ne, vidim tudi kako rusija tu in tam zadane vojaški cilj, kar je OK, ampak ti izgleda ne vidipš, kako tudi ukrajini uspe sesuti kakšen pomemben vojaški cilj...
Mene res zanima kako se bo ta vojna končala in kdo izmed vas ima prav glede take in drugačne premoči. Vsi imate neke realne argumente (razem Chalkyja, ki dobiva prompt od trumpeka).
Posledice ukrajinskih napadov vidimo vsak dan, po drugi strani pa težko verjamem, da so rusi sposobni samo par stanovanj oz. bolnic zadet.
Kakorkol upam, da jih bo srečala čimprej vse skupaj zdrava pamet.
Rusija in Severna Koreja sta zalaufali 24x7 proizvodnjo balističnih raket.
Ker vse delajo sami, niso odvisni od uvoza.
No, DRK mogoče je, ampak surovine dobavljajo Kitajci.
Kako bo EU dosegla to prizvodnjo, če morajo pa vse surovine, vključno z energijo, uvažati iz Rusije, Kitajske in ZDA?
Rusi non stop napredujejo na fronti. Počasi se bodo naučili se najti centre drone operaterjev in jih pospraviti. Kar s specialci, ker rakete in letala niso dovolj zanesljiva...
Plus, tolčejo ladje, mostove v Odessa regiji... Ladijski transport je praktično ustavljen. Ravno tako železniški, Gerani prepoznajo lokomotivo in jo stolčejo...
Zime prihaja. Rusi se najbolje borijo pozimi...
arato ::
Dal sem primer. Ne morejo vse ruske rakete doseči UK. Nekatere pa lahko. In samo ena je potrebna, da se sesuje svet kot ga poznamo.
Ni mi ok, da se cilja civiliste, kar mene najbolj skrbi so eskalacije. Ko ukrajinci zadanejo civilni cilj v Rusiji, je eskalacija skoraj nujna, ker Rus ne more pustiti Ukrajincu da zmaga.
damirj79 ::
arato je izjavil:
Ta primer je brezvezen in izven konteksta. Da iz rusije pride raketa do letališč RAF jih je na zalogi samo nekaj, manj od letališč. Ne verjamem, da si rusija upa storiti kaj takega. Kaj točno bi pa bil povod za to? V tem primerui bi verjetno tisti famozni natov 5. člen bil aktiviran, tudi putinu je jasno, da boljše če ne poskuša drezat.
Ok, ta eskalacija me ne skrbi. Kje je strop tega? Koliko rokavičk lahko še sname putin? Do sedaj jih je snel že 18x, pa ima še vedno ene gor nataknjene. Blef igra očitno.
  • spremenil: damirj79 ()
arato ::
arato je izjavil:
V Ukrajini, ki se bori iz ruševin, smo nekoliko pozabili kaj pomeni 200 raket. Zato sem dal to za primer.
Pred Ukrajino bi se bali ene, sedaj pa se kar pogumno razlaga kako nas tudi 200 ne more raniti.
Ampak finta je, da Rusi za lekcijo potrebujejo samo eno, ne 200.
RedDrake ::
Ne razumeš, za lekcijo je potrebno samo da F35 vrže v luft kontrolni stolp na poljubnem vojaškem letališču sredi Rusije.
To je potem signal, da lahko vsi umrejo, ali pa se predajo.
Sedaj boš rekel - bodo pa vsi umrli.
Yeah, ne, psihologija množic ne deluje tako.
arato ::
RedDrake je izjavil:
sej to delajo ukrajinci. pa ima kak efekt?
damirj79 ::
arato je izjavil:
arato je izjavil:
Nihče noče tiste ene poslat prvi. Saj to razumeš, ne? In ne, nihče se ni bal na začetku te "prve" rakete, saj vsi vemo, da prej ali slej bo prva. Vidimo pa, kaj je s temi 200 raketami na mesec, ki imajo omejen učinek. In to ne takšen, kot ga ti opisuješ, gre res za zelo omejen učinek, ker očitno če bi bil rezultat pravi, potem na rusijo nazaj ne bi letelo kot nazadnje 2000+ dronov nazaj z večjim ekonomskim efektom. Vojšako seveda niso na istem nivoju, ekonomsko so pa kar učinkoviti. Ne vem če si kaj pogledal, tečaj rublja strmo pada, v zadnjem mesecu -15%. In to kljub enormni vojaški proizvodnji. Rusija ne bo poražena vojaško, to vojno bo izgubila v ekonomskem in demografskem pomenu, posledično pa tudi vojaško.
RedDrake ::
Ukrajinci to delajo z low-cost droni, ki jih Muskoviti zaznajo in večino sestrelijo.
EN F35 je dovolj, da iz "praznega neba" spusti v luft neko stvar nekje, in potem je to jasen signal - ne boste nas videli - mi pa vas vedno vidimo.
To je dejstvo, ki se je videlo v Iranu. ZDA/Nato letalstvo je na drugem nivoju in lahko doseže neslutene stvari.
Ja, Irana se iz zraka ne da poraziti, kot se tudi Rusije ne da.
Ampak a misliš da je Putinu v interesu da mu en JDAM iz F35 spusti v luft rezidenco, ko bo on notri natepaval neko duckface plastik fantastik ljubico?
Ker glede na to, kakšne podatke so imeli o invaziji '22, verjemi da zahodne obveščevalne vedo presneto veliko.
In to je še dodaten dokaz, da so zahodnjaki tisti ta "miroljubni". Če ne bi bili, bi bilo že pol Muskovije mrtve.
windigo je izjavil:
Pithlit je izjavil:
Slabše od zdej ko jih njihovi ljubljeni vodje pošiljajo umret? Pa ko jim iz žepa kradejo?
Mi nimamo izkušnje kaj za nas pomeni da se odpremo zahodu?
A si res tolk trd?
Ja, v 90ih je bilo v Rusiji precej slabše kot zdaj. Mogoče ne slabše, kot bo čez dve leti, ampak tudi za to bojo z lahkoto zvalili krivdo na nas zahodne nekineki.
In od devetdesetih se je življenje Rusom najprej precej izboljšalo, na "ta pravem" zahodu pa se je ljudem življenje poslabšalo (čeprav daleč ne do te stopnje, da bi bili na ravni Rusov danes).
A si res tolk trda?
Ne vem kaj imate od tega premikanja gol štang. In to celo v odgovarjanju na vaša lastna vprašanja. Razen mogoče tega da morate po vsej sili izpasti še večji bedaki kot ste v resnici.
RedDrake ::
In točno to - 200 raket v Ukrajini OČITNO ne uspe ugasniti proizvodnje dronov, OČITNO ne uspe onesposobiti letalstva (ki še vedno prestreza vse živo, kar ni balistika). Kako bo potem tudi 400 raket mesečno to kar Ukrajini ni, vseeno storilo 20x večjemu nasprotniku?
  • spremenil: RedDrake ()
arato ::
arato je izjavil:
arato je izjavil:
Prvo : ne, ekonomski efekt ni niti primerljiv. Ukrajina kot država ne obstaja (tp. njen aparat je v celoti financiran s strani drugih držav). Napačno je misliti, da imajo omejeni ukrajinski napadi na Rusijo večji gospodarski učinek kot ruske bombardiranje glavnega mesta in vseh ostalih tarč. O gospodarstvu v Ukrajini ne govorimo, ker je zanemarljivo in ker nihče nima interesa. Je pa dobesedno NOROST misliti, da ruske rakete + droni naredijo manj gospodarske škode kot tistih par dronov nad Rusijo.
Drugo : dal sem link finske banke, ki predvideva, da se praktično nič ne bo spremenilo v naslednjem letu. Efekt na rusko gospodarstvo ni zanemarljiv, ampak obenem nima neke bistvene vloge pri sami vojni. Dosti večjo vlogo ima ruska mobilizacija in vojaško industrializiranje, kar pušča civilni sektor brez delovne sile.
Tretje: nobena država v totalni vojni ne dela profita
Kar pa se tiče eskalacije. Na neki točki bo, v kolikor NATO in US vedno bolj podpirata Ukrajino, Rusija prisiljena - hočeš:nočeš - udariti. To je osnova mednarodne politike. Deterrent deluje SAMO, če si ga pripravljen uporabiti. Če ga nisi je samo nekaj na papirju. In 100% lahko, v kolikor bodo UK rakete začele zadevati ruske cilje, pričakujemo eskalacijo s strani Rusije.
Zato je tudi CIA v Rusiji. Ker imajo Rusi dovolj.
Zato vidimo drone na nemških letališčih. Samo totalni debili govorijo o neuspelih poskusih napadov. Ne, to so samo opozorila. češ - "vidite kako blizu vam lahko pridemo?" ... podobno kot je oreshnik opozorilo. Rusi imajo počasi dovolj NATA v Ukrajini in moja ocena je, da bodo ob eskalacijah počasi reagirali.
Iran je s svojimi sistemi sklatil f35. Če kaj, potem je ravno Iran pokazal, da se vojne ne da dobiti zgolj z bombami. Da moraš biti pripravljen vkorakati.
Ne gre za to. Gre za to, da lahko Rusi prinesejo vojno na tvoj prag. Boš potem še pameten?
Teh 200 raket ne pomeni, da bodo Rusi porazili NATO ali kaj podobnega. Pomeni pa, da lahko opozorijo NATO na to, da oni neprestano kršijo rdeče linije.
RedDrake ::
Storm Shadowi so že spustili v luft Muskovitske cilje v Muskoviji proper. In to taki, narejeni v Franciji/VB
Če je Ukrajinska industrijska sposobnost uničena z 200 raketami mesečno, zakaj potem taka galama o licenci, da Ukrajinci te rakete začno proizvajati sami?
Retard logic, resno.
Povsem jasno je, da dokler EU financira Ukrajinski civilni sektor, potem lahko UA s preostankom naredi "zelo veliko".
Rusija je tista, ki neprestano krši rdeče linije, Trol Trolovič. Oni so eskalirali po Krimu, oni so uporabili svojo vojsko v Ukrajini že leta 2014, oni so prekršili vse sporazume, kjer so posredovali Nemci in Francozi, oni so sprožili invazijo '22, oni so šli nad energetsko infrastrukturo, oni izvajajo hibridne napade na EU že od leta '22, itd ...
Windlass ::
Pithlit je izjavil:
Utrujanje, zapravljanje časa in energije, večna debata/nikoli se ničemer ne pride do dna, brisanje lastnih napak in laži, onemogočanje normalnega diskurza.. in še in še.
Saj vidiš, da sploh ne ve več kaj bi si še zmislil oz. dal LLM za napisat. Že 2 meseca je zaciklan in histerično-ekstatičen na teh raketah in to je to.. se pa čudim da ob vseh zmerljivkah še nima blokiranega računa tokrat.
arato ::
Idustrijska sposobnost ni uničena, je pa otežkočena.
Res je, Rusija krši rdeče linije.
Ampak sam sem mnenja, da je prišel počasi čas, da Rusi postavijo rdečo linijo. Bomo videli, sam pričakujem, da če je šlo do sedaj bolj za retoriko, se zna zgodit, da kakšno letališče eksplodira v UK. Seveda Rusi ne bodo vedeli nič o tem.
Bomo videli, to je moje mnenje.
Windlass je izjavil:
Pithlit je izjavil:
Ja ampak dotični rusofil tega načeloma ne počne. Ni to arato ali Leif (al pa teleban, k je zaciklan v kramatorsku).
Windlass ::
Pithlit je izjavil:
Pithlit je izjavil:
Ah, pardon, nisem videl da je tokrat na windiga letelo.
arato ::
Pithlit je izjavil:
Učinek raket in glide bomb. Če pogledaš video boš videl kako obupan je avtor, kako nemogoča je situacija. Kako neizbežen je poraz.
esel ::
Pithlit je izjavil:
windigo je izjavil:
Pithlit je izjavil:
A si res tolk trd?
A si res tolk trda?
Ni kaj, Windigo je vrhunski analitik…najprej pride do zaključka, potem pa išče indice, ki ga potrjujejo. Ko ga opozoriš na nedoslednost, jo pač enostavno preskoči.
  • spremenilo: esel ()
MadMen ::
Leif je izjavil:
Upam da boste takole pogumni tudi na naboru
Najprej bomo Rusofile v pehoti poslali naprej v izvidnico.
damirj79 ::
arato je izjavil:
ampak ravno obratno je, kot ti praviš. Rusiaj je ekonomsko vedno bolj v podnu, Ukrajini pa vsi z veseljem talajo miljone, ne, miljarde. Nekaj v tej tvoji logiki ne štima. Očitno teli ukrajinski napadi le niso tako nedolžni in omejeni, kot hočeš ti prikazati. Gospodarstvo v Ukrajini je zagotovo bolj podrejeno totalni vojni, kot v rusiji. Ali kaj točno hočeš povedati?
Ampak malo nazaj si razlagal, da rusija ni v totalni vojni. Kaj sedaj? Zdaj je? Ali kdaj bo?
To seveda ne drži.
Rusi ima dovolj.. koliko časa že? 5+ let pa še kar nimajo dovolj očitno. Ne razumem tega mencanja. Če imajo dovolj, potem naj rečejo dovolj je in naredijo totalen šmorn. Pa očitno še kar nimajo dovolj.. uničenih skladišč in rafinerij. Kaj moramo še storiti, da bodo imeli tokrat pa res dovolj?
Teh 200 raket ni dovolj niti za ukrajino, kaj šele za pragove vseh ostalih.
Tvoje ocene so - ničvredne.
esel ::
arato je izjavil:
Pithlit je izjavil:
A spet poraz?
Daj, sedaj v vse tiste kitajske LLMje svojo trditev, zraven prilimaj video, ter objavi tukaj screenshot svoje interakcije.
Windlass ::
Ukrainian intelligence says Russia's General Staff has prepared an option for an additional mobilization of 600,000 people across 2026-27, targeting 300,000 each year. Ukrainian intelligence estimates Russian personnel losses at about 240,000 in January-July, including at least 140,000 irrecoverable losses, while fewer than 232,000 contract soldiers were recruited. A mobilization decision is considered most likely after the September 18-20 State Duma elections.
arato ::
Ukrajina obstaja zgolj še na evropski in ostali pomoči. Kako dobrohotna je ta pomoč se lahko vpraša Grke, mimogrede.
Rusija tudi ni brez vlagateljev. Kitajska posredno financira rusko vojsko tako da kupuje ogromne količine nafte. (to je bržkone način kako se izognejo sankcijam, mimogrede)
Rusija še ni v totalni vojni, se pa hitro pomika tja. Sam bi rekel, da je trenutno neke vrste hibrid.
To seveda ne drži.
quotes? links?
poanta totalne vojne je, da gre vse kar se lahko pogreši za vojsko.
A hočeš, da imajo dovolj? Zna bit, da bodo teli stormshadowi (včeraj so francoske različice napadle donetsk) kar dovolj. Imam čuden občutek, da se nekaj pripravlja. Ne samo zaradi CIA direktorja, ampak nasploh je vse skupaj zelo napeto in sam imam občutek, da je samo še nekaj minut do polnoči. (ne jedrske). Očitno tudi AMeri nekaj vejo.
Še enkrat - ne govorimo o tem, da bodo Rusi z 200 raketami uničili karkoli, lahko pa kar pošteno zagrenijo lajf na zahodu, če se jim zahoče. Seveda ne brez posledic.
Bi bilo pa vsaj prvo leto vojne presenetljivo slabo za NATO, če do vojne pride, ker NATO preprosto ni pripravljen na vojno trenutno.
esel je izjavil:
arato je izjavil:
Pithlit je izjavil:
A spet poraz?
poraz v regiji. poglej si video, nisem si jaz to izmislil.
windigo ::
Pithlit je izjavil:
Zdelo se mi je pomembno poudarit, da naša in ruska izkušnja iz 90ih nista glih primerljivi, čeprav jih ti (po mojem na silo) primerjaš. O tem kje so bile razlike in kakšne lahko še kaj napišem, od kod razlike izvirajo pa raje ne bi (ker ne bi imelo smisla).
Stil pisanja pa sem (precej očitno) kopiral od tebe.
Truth is not negotiable!
  • spremenilo: windigo ()
Leif ::
Heh miroljubni, F-35 morajo iz nekje vzletati in verjemi da imajo Rusi vedno zalogo za stolči evropske letalske baze. Doktrina še iz Sovjetske zveze. Brez tega bi že zdavnaj padalo po njih.
damirj79 ::
Aha, spet smo pri istem. rusija lahko, Ukrajina ne more. Ali pa ne sme :) Kitajska ne pomaga rusiji tako kot ti trdiš, da pomaga. Celo več, gospodarsko se iz rusije umika. Avtomobilska industrija npr. Ne kaže pa tudi na drugih področjih nič od tega, kar ti tu hočeš prepričati. Bo pa Rusija tenko piskala enkrat, ko bo Kitajska zahtevala vse nazaj, kar bo kmlau. Ker Zahod od Ukrajine ne zahteva vrnitev vseh sredstev pomoči nazaj... Slabo bo to za rusijo, spet.
Malo obračaš ti te besede kot odojka na roštilju.
quotes? links?
Tako je, ampak to ne pomeni, da država hira. Država bo imela dovolj, prebivalci pa manj.
Mogoče te pa občutek vara, enako kot v številu rokavic, ki jih je putin že snel z rok.
Zagrenila lajf bi že ena raketa. Če bo zagrenila napačnemu, potem bo to za rusijo katastrofa. Sej putin to ve, zato kljub 19im snetim rokavicam, še kar ni nič od tega.
arato ::
Tole smo res že nekajkrat predebatirali. Rusija v naslednjih dveh letih ne bo kolapsirala in vprašanje je ali lahko Ukrajina zadrži ozemlje, ki ga trenutno ima.
Očitno ne, ker ji UK in Francija panično pošiljajo orožje in ker CIA hodi v Rusijo prosit naj ne eskalirajo.
Situacija na fronti je kritična. Sicer kak bedak misli, da UK in Francija sedaj pošiljata orožje, ker verjameta, da se Ukrajina lahko obrani ... ampak to je bebava logika. UK in Francija vesta, da je Ukrajina v najslabši situaciji v vojni in da mora nekaj narediti.
Podobno kot je Ukrajina to vedela julija, ko je tik preden ji je zmanjkalo interceptorjev začela napad ruske cilje. Ker je vedela, da je konec blizu.
Problem je, da do vojaških baz ne more. Da nima sposobnosti, da bi uničevala ruske launcherje hitreje kot jih Rusi menjajo. Zato napada mimovrste. Ampak to na fronto nima nobenega vpliva.
Kar se tiče ene rakete. A res misliš, da bo recimo UK začela raketirat Rusijo in ogrozila svoje prebivalstvo? Ne, požrla bo ta napad in se skrila. Ker nihče na zahodu ne podpira vojne, ko pridejo rakete do njih.
Stane2 ::
Leif je izjavil:
S čim? Katere rakete imajo sploh takšen doseg? Kje je ta zaloga raket? Evropa ima en kup patriotov z raketami. Dovolj za prvi napad.
MadMicka ::
Kitajska kar lepo sproti RF proda za zlato (ne za rublje) in kupuje nafto konkretno pod tržno ceno.
Kar pa se Rusije tiče, ni Rusija, ampak Ruska federacija, kjer živi cca. 105 milijonov Rusov in še 30 milijonov drugih, ko crkne Putin, crkne oz. razpade RF.
Stane2 ::
arato je izjavil:
Pa kako je mogoč, da vam ta lažnivec še vedno serje s 200 raketami?!!?
O čem se sploh pogovarjamo? O balističnih raketah? O manevernih? O ČEM??
Balističnih raket za katere se rabi Patriote Rusija NITI POD RAZNO ne proizvede 200 na mesec.
https://x.com/ZelenskyyUa/status/209145...
Russia could have up to 1,300 ballistic missiles a year. Right now, they have 600–630. We have an approximate understanding of the volume they are counting on from today and through the end of winter. Roughly speaking, they could have 100 ballistic missiles a month. But they are not at that level yet. We are working to weaken their military industry. There are corresponding tasks involving strikes on military targets and other anti-ballistic sanctions.
Takih raket v tem trenutku proizvedejo okoli 50 na mesec. ;((
Vse ostale tipe raket se pa da sestreljevat s kupom drugih orožij, manevrirne postrelijo večinoma F-16 in Mig-29, kar ostane pa z drugimi kopenskimi sistemi.
damirj79 ::
arato je izjavil:
Tole tvojo teorijo smo že večkrat tudi zavrgli, pa še kar vztrajaš, kljub temu da nič ne kaže da imaš prav..
Akira5 ::
Leif je izjavil:
Zakaj potem ne uničijo ukrajinskih letališč?
windigo je izjavil:
Pithlit je izjavil:
Pa madona pejd prebrat kje in kako se je začelo preden glumiš no. Vas mam vseh skup poln kurac s temi vašimi gimnastičnimi vajami, prekucavanjem besed, premikanjem golov in haluciniranjem nekih vprašanj ki jih nihče ne sprašuje. Na drugi strani niti en od vas ni obsodil posiljevalske mentalitete forumskega veleuma. Verjetno zato ker vam na dušo piha z nepremagljiv veliko Rusijo... vsaj upam da zato, in ne zato ker bi tudi vi svojo lastno hčerko potisnili v roke posiljevalci ki bi vas malo postrani pogledal pa vam zagrozil da vas bo po anusu požgečkal.
Zdaj pa resno, pejd pogledat kje se je to z rusi in zahodom začelo. Ker trenutno brcaš v temo in se smešiš.
damirj79 ::
Leif je izjavil:
Verjamemo. Ampak bolj ne. Zakaj tega ne storijo? Veš na koliko boljši poziciji bi bili rusi, če bi stolkli samo eno EU bazo. A ocitno temu ni tako, ali pa rusi enostavno nočejo biti na boljši poziciji. Uživajo ko jim tolčejo ukrajinci skladišča in rafinerije...
arato ::
Akira5 je izjavil:
Leif je izjavil:
sej jih
Akira5 je izjavil:
Leif je izjavil:
ZATO KER ŠPARAJO ZA EVROPSKA. Ti ne razumeš tega 6d šaha no. To razume samo Veleum. Vsi ostali smo glupi. Rusi si raje zobe lomijo v Ukrajini, pa gledajo kako jim ekonomija in gospodarstvo freefall-ata kot da bi to na hitro (ker kapacitete ziher imajo) končali.
Stane2 ::
arato je izjavil:
sej jih
lažnivc se je že spet zlagal... vsa ukrajinska vojaška letališča še vedno funkcionirajo
arato ::
arato je izjavil:
Kaj se je zavrglo? Katero teorijo? Rusija počasi leze v Ukrajino. Ni več vprašanje ali bo DOnbass padel, ampak kdaj.
arato je izjavil:
arato je izjavil:
Prej ali po tem kot tvoja hči?
arato ::
Stane2 je izjavil:
arato je izjavil:
sej jih
"Russia's strategy has shifted to a persistent game of whack-a-mole, consistently hammering known military airfields to prevent Ukraine from establishing fixed logistics hubs or safely housing strategic assets like Storm Shadow-capable bombers or F-16s."
iiss
consistently.
ne moreš primerjat mirne evrope z ukrajino kjer so težke bombe dnevna realnost.
arato je izjavil:
Stane2 je izjavil:
arato je izjavil:
sej jih
iiss
consistently.
Čudno kako Ukrajinci še kar letijo, a? Kljub razbitim letališčem, a? Tud himarsi še kar delajo... Kljub temu da so jih rusi že najmanj 4x vse vrgli u luft (še preden jih je Ukrajina sploh dobila). Aratodamus strikes again folks.
arato ::
Pithlit je izjavil:
arato je izjavil:
Stane2 je izjavil:
arato je izjavil:
sej jih
iiss
consistently.
"If you look at the aggregate data since 2022, the total number of individual missiles and drones fired at Ukrainian air base coordinates easily numbers in the hundreds, if not thousands. It is a continuous, multi-year attempt to keep Ukrainian aircraft grounded or dispersed."
OSINT
mislim, res moraš bit omejen, če misliš da rusi ne napadajo teh tarč dnevno. so velike, vidne iz vesolja in nepremične.
Akira5 ::
arato je izjavil:
Akira5 je izjavil:
Leif je izjavil:
sej jih
Kako že?
Ukrajinci danes precej več letijo kot tri leta nazaj.
Stane2 ::
arato je izjavil:
iiss
consistently.
Zdaj si sam napisal, da so ukrajinska letališča še vedno dejavna in da ukrajinska letala še vedno letajo. WTF
arato je izjavil:
Res, kako si lahko omejen, da ne spoznaš, da tale ruski effort ni za nikamor. Evidentno niso pri tem dovolj uspešni.
  • spremenilo: Stane2 ()
arato ::
Akira5 je izjavil:
arato je izjavil:
Akira5 je izjavil:
Leif je izjavil:
sej jih
Kako že?
Kaj so letališča?
Kako bi ti "uničil letališče"?
Letališče uničiš za par ur pa se popravi. Rusi ne napadajo letališč zato da bi jih trajno onesposobili, ampak zato da onemogočajo ukrajinska letala, da uničujejo skladišča goriva, da (v kolikor ta stojijo) uničujejo kontrolne stolpe.
"It is a continuous, multi-year attempt to keep Ukrainian aircraft grounded or dispersed."
