Bici ::
To bi potrebovali pri nas, da potrižemo peruti MMC golazni.
Je pa res hecno da je zagrizena desničarka in promotorka tradicionalnih vrednost ubistvu lezbijka in živi s partnerko :))
Povsem tipično za ruse in rusofile, laganje in sprenevedanje.
  • spremenil: Bici ()
Kako dolgo nekje traja, da moderator prebere komentar na RTV in ga odobri ali zavrne? Par ur, dan, dva, več tednov? Če ga zavrne ali pošljejo obvestilo? :D Če jim pošlješ položnico, da si plačal zadnji RTV prispevek ali zadeve pohitrijo, imaš več pravic, ali si na istem ali celo na slabšem, kot oni, ki komentira iz Rusije?
Bici je izjavil:
Spomnja nekako na tole: Jason Virgo, novorazglašeni poslanec skrajno desne stranke One Nation v južavstralskem parlamentu One Nation SA MP Jason Virgo reveals gay relationship with Muslim ... - The Australian.
Bi si skraj upal trditi, da ga je Kadirov že tudi vstavil v tazadnjo, čeprav ima tam smrtno kazen v Čečeniji, bi rekel, da bolj iz ljubosumja!
strawman ::
Rybar, ruski milblogger o stanju na južni fronti:
Problems with logistics
Deeper than they seem
The situation in Russia's southern regions is becoming increasingly alarming. Since the beginning of May, Ukrainian forces have significantly increased the number of drone strikes against vehicles transporting various cargoes to the Kherson and Zaporizhzhia regions and Crimea. On the peninsula, shortages of certain goods have emerged, while fuel is being sold with restrictions.
The threat is not limited to disrupting the tourist season in Crimea or shortages of specific products on the peninsula. Strikes against cargo transporters heading to Crimea directly affect the combat capabilities of the Russian Armed Forces on the southern fronts, where the situation is already far from stable.
?What is happening at the front?
? In the Kamenske area, the enemy has been attacking for quite some time and has managed to advance in several sectors, pushing Russian troops back: Stepnohirsk and Plavni are almost lost, along with nearly all the territorial gains achieved by the Russian Armed Forces during the offensive that began in early 2025.
? There is a risk that the enemy will not only restore the status quo but also launch its own offensive along the Kamenske-Shcherbaky line. Indirect signs indicate that attention has been drawn to the problems in this sector, although the situation remains difficult.
? The activity of Ukrainian drone operators in strikes against Kamianka-Dniprovska, Vodiane, and Enerhodar has increased significantly. Every 20-30 minutes local ??????? report drone attacks on the city, with the number reaching dozens. There are dead and wounded among the local population. Employees of the Zaporizhzhia Nuclear Power Plant have also become targets, as officially reported by the plant's resources.
? This may indicate enemy preparations for, if not a full-scale landing operation, then at least a diversionary strike through the reeds on the bottom of the former Kakhovka Reservoir.
The loss of the Zaporizhzhia Nuclear Power Plant cannot be allowed: even small enemy groups would be extremely difficult to dislodge from there. Moreover, the Russian Armed Forces would be heavily restricted in the means of attack they could use, since the ZNPP is not an object that should be subjected to airstrikes.
?Given that Ukrainian formations have already partially paralyzed logistics in southern Russia along the land corridor to Crimea, it is not difficult to imagine what would happen if the AFU managed to break through Russian defenses along the Kamenske-Shcherbaky line.
? The Russian Armed Forces would have to redeploy reinforcements toward areas like Vasylivka, the roads to which are already under frequent enemy strikes. In the worst-case scenario, stabilizing the situation would require transferring additional forces via routes through Tokmak and the more distant Berdiansk and Mariupol. These are precisely the routes where even civilian cargo deliveries are already heavily disrupted.
?So what can be done about this? The issue of organizing low-altitude air defense is understood and has been studied. It has also been raised at the highest levels. The avalanche-like increase in attacks after the May holidays is obvious to the naked eye, although the roads were unsafe even before then. Around the beginning of May, the AFU tested Hornets, and after the ceasefire they began using them on a massive scale, giving no time to develop countermeasures.
For the foreseeable future, traveling on roads near the front line (because there is no rear area anymore) will remain a dangerous lottery. And the sooner this reality is understood, the sooner, hopefully, the necessary organizational decisions will be made to protect logistics from drones.
caszafuckoff ::
strawman je izjavil:
Problem je, da eni in drugi toliko lažejo, da dobiš nek pribljižno realno sliko, če bereš oboje, česar se pa nikomur ne da.
Windlass ::
Če odmislimo click-baity naslov, zanimiva reportaža o tem kako kako rusi uporabljajo nuklearko v Zaporožju za lansiranje dronov na civiliste na drugo stran. Logično te noben ne sme ciljati nazaj, če čepiš na nuklearki. Tam bo še en kup provokacij in drugih nevarnosti ko bo to menjalo lastnika, sploh ker imajo rusi tak propagandni aparat, da so vedno ukrajinci krivi. Najprej so krivi da so jo branili, potem bojo pa krivi, ker jo bodo poskušali vzeti nazaj.
caszafuckoff je izjavil:
"moramo razumet...". Nismo mi za Ruse, a?
Che25 ::
Kaj mislite, da bo Janez kaj porihtal RTV, ali bo postalo še huje zaradi onega Rusa (podpornika), ki vodi naš parlament!?
Dvomim, da bo prišlo do nekih konkretnih sprememb. Razlogov za to je več:
- Ker so ljudje (bolj ali manj upravičeno) občutljivi na kakršnekoli politične pritiske na javni medij.
- Ker je praktično nemogoče zamenjati celotno uredništvo (to mu ni uspelo niti v prejšnjih mandatih).
- Ker se desni pol še bolj sklicuje na svobodo govora, čeprav je očitno, da se v anonimnih komentarjih na javni RTV ta pravica zlorablja.
V notranjepolitične debate se v kontekstu prokremeljske propagande nerad spuščam in se ne želim politično opredeljevati, močno pa upam, da Resnica ne bo imela vpliva na zunanjo politiko Slovenije in da bo prihodnja vlada še naprej podpirala Ukrajino v njenem obrambnem boju proti agresorju.
luli ::
Sledil bo razpad Ruske pederacije.
  • spremenilo: luli ()
Leif ::
In potem Evropa dobi prost dostop do Ruskih surovin in Američani ploskajo. Potem se boš pa zbudil
Leif je izjavil:
Dostop do tega bodo dobile ameriške multinacionalke, kot so dobile po bivših republikah Sovjetske Zveze...
Evropejci bomo dobili prst v rit, ali pa bolj ziher, en konkreten dildo...
bm1973 je izjavil:
Leif je izjavil:
Kdo bi dobil dostop se vidi na primeru Venezuele. Nafta gre preko Zda in kupcem po ceni, ki jo Zda dovolijo.
EU je "useful" idiot, ampak s tem nekateri nimate težav, niti Kaja in Ursula ne. Sta obe top v tem, glede na njune izjave.
  • spremenilo: fikus_ ()
Bici ::
bm1973 je izjavil:
Leif je izjavil:
Kvizling fikus_ spet ne zna drugega kot jamrat in zaničevat evrope.
Che25 je izjavil:
Meni ni jasno kako lahko tale komentar pride mimo moderatorja. :D
Še najbolj neumnemu je očitno, da so glavni poganjalci te vojne EU, ter Ukrajina in da bi konec vojne pomenil pogreb obeh, ter konec sprenevedanja. EU in Ukr namerno vzdržujeta vojno stanje že 4.leto, zato je bolje nehati sanjati o premirju, ali koncu, ker ga preprosto NE SME BITI. Kajti podpora Ukrajini = Podpora vojni. Enačba, ki si jo velja zapomniti. Iz nje sledi vse, kar se dogaja. Ne podpiram nikogar posebej, vsaka vojna je idiotizem, se pa bojim ukrajincev, ker so že dokazali, da so zmožni najbolj podlih in okrutnih stvari, poleg tega pa še neprestano rinejo proti nam, ter nam uvažajo kaos, ter uničenje.
Pa kaj so nori malo, za to bi moral tip sedeti, ali biti vsaj na opazovanju. V primeru napada, bo tale tip lepo javljal koordinate, če pa ne piše iz Slovenije, pa še toliko bolj žalostno, da to objavljajo tujim obveščevalcem, medtem ko naši komentarji ne pridejo mimo. Vsaj moji ne, mogoče 1 od 10 pa še ta bolj ali manj ne, kot odgovor na neumnosti.
Plačilna navodila
Sredstva za RTV-prispevek se nakazujejo na posebni račun RTV Slovenija, odprt pri UJP št. SI56 0110 0849 3106 536, koda namena: SUBS, BIC banke prejemnika: BSLJSI2X.
Knjiženje plačil
Plačila se knjižijo avtomatično in zapirajo izdane račune na podlagi 13-mestne številke, ki je za vsak mesec unikatna in izpisana na položnici (UPN nalogu) v polju Referenca prejemnika za oznako SI12. V primeru, da se znesek nakazila ne ujema s številko reference prejemnika, se nakazilo knjiži na najstarejšo neporavnano obveznost.
Postopek v primeru neplačanega računa
RTV-prispevek se v skladu z Zakonom o davčnem postopku plačuje do 15. v mesecu za tekoči mesec.
V primeru, da zavezanec svojih mesečnih obveznosti ne poravna, ga RTV Slovenija na zaostale obveznosti opomni na naslednjih mesečnih obračunih RTV-prispevka. Zavezanec ima tako pri vsakokratnem računu za tekoči mesec izpisane tudi morebitne neporavnane račune iz preteklih mesecev tekočega leta.
Zavezancem, ki svojih zapadlih obveznosti tudi po tem ne poravnajo, izda RTV Slovenija po uradni dolžnosti odločbo o obveznosti plačila prispevka za programe RTV Slovenija.
bm1973 je izjavil:
Lahko daš kaj primerov kdo, kaj in kje? "Ameriške multinacionalke" je hella generično.
bpr123 ::
Zakon, ki ga je ruska duma potrdila 13. maja, Svet federacije pa sedem dni pozneje, ruskemu predsedniku Vladimirju Putinu zdaj daje polna pooblastila za uporabo vojske za posredovanje v drugi državi, če presodi, da mora ruske državljane v tej državi zaščititi pred aretacijami, pridržanji ali (kazenskimi) pregoni.
Popoln razlog, da se vsakega ki ima karkoli z Rusijo izžene iz države.
Pač v imenu zaščite države pred morebitno rusko agresijo.
bm1973 je izjavil:
Recimo...
https://eurasianet.org/kazakhstan-cance...
Počasi jim bodo pravice vzeli...
bm1973 je izjavil:
bm1973 je izjavil:
Recimo...
Kdo je pa vložil v razvoj, tehnologijo in znanje?
Po razpadu Sovjetske zveze so se pretrgale dobavne verige. Kazahstan je bil v sovjetskem sistemu specializiran za surovine, kovine, energijo in kmetijstvo, ne pa za samostojno tržno gospodarstvo. Ena analiza navaja, da je bil realni BDP leta 1995 samo še približno 59 % ravni iz leta 1990 in 45 % ravni iz leta 1989; realni BDP, plače in investicije so močno padli.
Inflacija je bila ekstremna. Podatkovne serije za 1993–1995 kažejo padec realnega BDP v letih 1993, 1994 in 1995 ter inflacijo nad 1.000 % v letih 1993–1994.
Se pravi, kdo jim je omogčil vsaj nekaj kapitala? Rusija? :D
Pa halo, pa kako lahko Rusi komentirajo po RTV, poglejte tole, a mi ne moremo odgovarjat? NORO na našem portalu, ki ga plačujemo, noro no!
kanješna
26. 5. 2026, 13:12
Če je katera država, ki ne rabi več ozemlja in več naravnih bogatstev, je to Rusija. Ravno obratno. Rusija je začela vojno tudi zato, da bi se zaščitila pred zahodnimi hegemoni, ki pa dejansko želijo več ozemlja, več naravnih bogatstev in po možnosti kontrolo nad celim svetom.
"Kanješna" je verjetno zapis po posluhu za rusko
Pomeni:
seveda, jasno, gotovo, itak, kako da ne.
Zelenski baraba, lagal je :D
https://www.aljazeera.com/news/2022/2/2...
Govorili so vam, da Ukrajina predstavlja grožnjo Rusiji. To ni veljalo v preteklosti, ne velja danes in ne bo veljalo v prihodnosti. Vi zahtevate varnostna jamstva od Nata, toda tudi mi zahtevamo varnostna jamstva. Varnost za Ukrajino pred vami, pred Rusijo, ter druga jamstva iz Budimpeškega memoranduma.
bm1973 je izjavil:
Recimo...
Does not compute, try again.
  • spremenilo: Pac-Man ()
Windlass ::
kanješna
26. 5. 2026, 13:12
Pomeni:
Drži, pravilen prevod. Ampak glede teh west=bad in visokoletečih hvalnic tuji državi se v bistvu ni toliko za sekirat, ker se s tem hitro izdajo, da so malo čudni. To ne privabi veliko ljudi. Sploh ni nujno da je to Rus, v bistvu sem 100% da je državljan Slovenije. Lahko gre za nekakšno kompenzacijo oz. izživetje določenih pomanjkljivosti skozi neko drugo, idolizirano entiteto. Podobno kot oboževanje holivudskih igralcev/športnikov ali kaj takega. Tako je uspeh nekoga drugega lahko tudi tvoj.
Bolj sporno (in škodljivo) je ad nauseam nabijanje nekih konkretnih narativov npr.:
- 8 let obstreljevanje Dombasa
- Merklova je podpisovala Minske, da je kupila čas da je zahod oborožil Ukrajino
- Bučo so zagrešili Ukrajinci
- večinsko ˝ruske˝ regije
- Ukrajinci bombardirajo nuklearko...itd.
To so pač stvari, ki si jih uredništvo/moderator (s svojimi ljubljenci) lahko privošči, preprosto zato ker ga noben ne prime za ovratnik. Na tem bi morali delati. Vseen mi je kaj počnejo na redditu in insajderju ampak nacionalka je pa nacionalka. Nacionalna sramota. Še posebej ko enkrat pridemo do pozivov k nasilju in prikrivanju vojnih zločinov.
  • spremenilo: Windlass ()
Che25 ::
Windlass je izjavil:
This. Celotna problematika komentiranja in moderiranja na RTV, povzeta v parih vrsticah.
Kot vedno, vsaka obtožba je priznanje. Smrk smrk.
https://www.reuters.com/world/czech-pol...
Ruski pravoslavni duhovnik je bil v Češki republiki izpuščen brez obtožb, potem ko so ga oblasti pridržale, ko je policija v njegovem avtomobilu našla majhne posodice z belim prahom.
Metropolit Hilarion, ki je vodil zunanje odnose cerkve od leta 2009 do 2022, je zanikal kakršno koli povezavo s temi predmeti in obtožil policijo, da med preiskavo ni upoštevala ustreznih postopkov.
V izjavi, objavljeni v torek na njegovem Telegram kanalu, je duhovnik – čigar posvetno ime je Grigorij Alfajev – dejal, da je forenzična analiza potrdila, da je bila snov, najdena v njegovem avtomobilu, prepovedana, ter da se preiskava nadaljuje.
Tik pred njegovim poročanim izpustom je rusko zunanje ministrstvo sporočilo, da je na zagovor poklicalo češkega odpravnika poslov, da bi protestiralo proti pridržanju duhovnika in zahtevalo njegovo brezpogojno izpustitev.
Leif ::
Imate na military media kompleksu obdobje kislih kumaric ?
Če borcema proti svobodi govora rata ukiniti komentarje na mmc, potem ne vem o čem bo šla tale tema. Verjetno bodo samo pacotove tldr copypaste.
Širjenje ruske propagande in blokiranje kontraargumentov pač ni svoboda govora.
bpr123 ::
Leif je izjavil:
O čem neki?
O ruskih uspehih na fronti!
Aja, ni jih :))
Leif ::
https://www.timesofisrael.com/liveblog_...
Oy vey, res si ne delajo usluge
Stane2 ::
Che25 je izjavil:
Za Luckysssa nisem prepričan, da deluje po naročilu (če ne drugega, komentira tudi teme, ki niso povezane z Rusijo in Zahodom vs. Vzhodom), njo pa imam na sumu.
Na vprašanje, zakaj se ne preseli v Rusijo, če se ji Zahod tako gabi, je odgovorila, da bi se z največjim veseljem, ampak da dela v poklicu, kjer primanjkuje delovne sile, in ne želi, da bi jo nadomestil kakšen migrant. Prava altruistka! :))
Ta pi*ka uporablja dobesedno nešteto nickov in skoraj vsi njeni imajo žensko ime (lahko je tudi dec). Vsebina je vedno ena in ista, vsake toliko časa gobca o ruski kulturi.
Leif je izjavil:
Izrael protestira, bo začela skrajna levica podpirat Ukrajino?
Ruska propaganda nima politične pripadnosti, namen lepljenja tovrstnih člankov je samo poskus promoviranja ruskih narativ.
Na žalost jim nikoli na zmanjka koristnih idijotov.
Newly hacked files offer rare insight into Kremlin propaganda operations.
These include planting bloody pig heads in front of mosques in Paris; election interference campaigns and propaganda laundering through Israeli media.
https://x.com/Martinlaineolen/status/20...
Stane2 ::
https://x.com/silupescu/status/20592249...
"The West has created a network of digital laboratories with which it controls the opinions and behaviors of citizens of former CIS states with the aim of manipulating them".
The head of the FSB, Bortnikov, has completely lost his mind.
ModriMiha ::
Leif je izjavil:
ModriMiha je izjavil:
Stane2 je izjavil:
Leif je izjavil:
Njihov problem je predvsem imeti ameriški puppet state in njihovo vojaške prezenco na svoji meji. Vprašaj recimo Irance kako je to fajn.
To že imajo, Estonija-Litva-Latvija. Je bilo kaj hudega?
Plus dolga meja s Finsko. Plus Norveska na skrajnem severu. Putinu je uspelo svojo mejo z NATO-m mocno povecati od leta 2022.
Ali je Finska v Natu ali ne nima nobene veze, razen za Fince, ki so izgubili nekaj suverenosti. Ni vse ozemlje enakovredno. Finska ima 5 milijonov ljudi in precej neprehodno mejo z Rusi. Celo Stalin je bil zadovoljen s položajem Finske. Baltske države imajo skupaj 6 milijonov in nobenega strateškega zaledja.
Ukrajina in Belorusija imata skupaj 50 milijonov ljudi ( vsaj imeli pred vojno), ki se jih lahko uporabi in sta zgodovinsko avtocesta za invazije. Malo razlika ane.
Haha, nima veze a? Mislim, da Finci ze vedo, zakaj so sli v NATO. In jih cisto razumem. Ajde, Svedi recimo da ne bi rabili iti. Ruski narativ pa je vedno bil, da ne zelijo meje z NATO paktom. A so jo s to invazijo povecali. Ni samo to, da imata Ukrajina in Belorusija toliko vec ljudi. Ampak tudi veliko bolj so kulturno in jezikovno podobni Rusom. Ruse zelo boli da "njihovi" Ukrajinci, ki so skoraj Rusi, paktirajo z Zahodom. Ampak JBG, sami so si krivi za to.
Windlass ::
Leif je izjavil:
Pravzaprav novice za pro-ukrajinsko stran že dolgo časa niso bile tako spodbudne.
Ne vem ali si s tem mislil mene ampak zaradi mene lahko vsak piše kar hoče. Ampak:
Ne na moj denar in ne v mojem imenu.
Če plačujem in medij predstavlja mojo državo, potem:
1.) Brez preprečevanja drugim da debunk-ajo če kaj ni res.
2.) Brez kršenja zakonov.
3.) Brez astro-turfanja z nekimi neorganskimi prijemi (in to leti tudi na novinarje)
Leif je izjavil:
Se tebi zdi RTV in tale tema podobna ti je to eno in isto? Tule, čeprav verjetno delajo prostovoljno so veliko večji profiči, tukaj lahko odgovoriš, če ga dva zabluzita, te lepo pobrišejo in gremo dalje. Tam rusofilom nikakor ne moreš odgovoriti, ker moderatorji ne spustijo tvojega komentarja skozi. Rus lahko napiše budalščino in komentar se vidi na prvi strani pod novico, da je napisal neumnost z dokazi, mu nikakor ne moreš zalepiti čez usta. In to v državi kjer smo v NATO in EU, nas trolajo rusi na državnem mediju za 14EUR na mesec!!!
shmandi ::
Leif je izjavil:
Mater vas pumpajo! A ti res misliš, da je hotla Evropa napasti rusijo 1.3.2022? Fašistična ruska propaganda v vsem svojem sijaju...
Jaz napisal v tem članku ene 10 komentarjev, pa je samo 1 šel skozi najmanj pomemben.
smerrrrrrch /ruski raketni sistem
26. 5. 2026, 17:46
Končno so tudi Ukrajinci priznali, da je verzija, ki so jo širili njihovi propagandisti, da je v zgradbi pedagoške akademije bil center, kjer so se učili ruskdela z droni, kažna. S tem so postavili na laž tudi ukrajinski generalni štab. Vendar je ukrajinska publikacija "Realna gazeta" po analizi družbenih omrežij študentov in njihovih bližnjih ter videoposnetkov in seznamov žrtev v medijih ugotovila, da so žrtve resnične, vsi umorjeni so bili študenti pedagoške akademije, ki je usposabljala učitelje nižjih razredov. Enako je "Meduzi" izjavil tuj novinar, ki je bil na mestu tragedije.
Nick ima Smerč, kar je ruski raketni sistem BM-30, kažna pomeni usmrtitev! Ruskdela naj bi pomenilo Rusi delajo z droni.
Kateri Ukrajinci so postavili na laž generalni štab Ukrajine? :D
Članek je legit, prav tako medij, pozabil je pa omenit, da pišejo tudi o zlorabi dogodka za rusko propagando:
https://realgazeta.com.ua/studienti-bul...
Ena od punc je iz Novopskov @ Wikipedia :
https://vk.com/nas7uha
9.3k prebivalcev, po popisu l. 2001 84% ukrajinsko in 15% rusko govorečih.
Druga iz Bilokurakyne @ Wikipedia :
https://vk.com/anitta5
6.3k prebivalcev, 91% ukrajinsko, 9% rusko govorečih. Na njenem pogrebu se je govorilo Rusko:
https://t.me/LIC_LPR/102649
Leif ::
Leif je izjavil:
Zanimivo, ker jaz sem istega mnenja o financiranju vojne v Ukrajini in me ni tudi ni nihče vprašal.
shmandi je izjavil:
Leif je izjavil:
Pumpajo me kvečjemu, da hočejo Rusi napasti Evropo z lopatami in čipi iz pralnih strojev :D
  • spremenilo: Leif ()
Windlass ::
Leif je izjavil:
Pokaži mi obvezen mesečni prispevek za financiranje vojne v Ukrajini.
Očitno imajo velike težave z rekrutacijo kanonfutra:
https://www.mladina.si/248888/kaj-svoji...
Ruski predsednik Vladimir Putin je v ponedeljek podpisal odlok, s katerim bodo novim vojaškim rekrutom odpisali dolgove v višini do deset milijonov rubljev oziroma okoli 120.000 evrov, poroča francoska tiskovna agencija AFP. Gre za nov ukrep ruskih oblasti za pridobivanje vojakov za vojno v Ukrajini.
Odlok omogoča ruskim državljanom, ki so po 1. maju podpisali pogodbo z vojsko, in njihovim zakoncem odpis obstoječih dolgov. Pogodba mora biti sklenjena za najmanj eno leto in mora biti namenjena "izpolnjevanju nalog posebne vojaške operacije".
Windlass ::
Ja, žal. Slabo tole. Zato sem se jaz bolj ukvarjal z načinom poročanja, kot pa s tem kaj je res in kaj ne, da ne bi komu krivice delal. Zdrava mera agnosticizma pa to..
Smerrch je pa itak brezveznik. Živi od manipulacij in polresnic (čeprav po mojem te svoje izdelke zgolj iz nekje kopira), ker oblikovanje propagande vseeno zahteva nekaj konjskih moči v glavi.. cela strategije tega kar on počne je, da cilja na naključne bralce in upa da ga ne boš šel preverjat
Tudi, če so bili zraven umrli študenti, kako naj Ukrajinci začutijo, da bi se jim ti študenti zasmilili? Ob takem številu umrlih Ukrajincev in preseljenih, verjetno ne čutijo ničesar do mrtvega Rusa. To je kot, da bi leta 91 po padcu Vukovarja in srbskih pomorih, Hrvati žalovali za umrlimi Srbi. Bi morali mi obsojati Ukrajince? Zato ker vračajo Rusom? Če se posmnite je 1 teden nazaj umrla v Kijevu celotna familija, ko je dron zadel stanovanje. Rus napade in se potem čudi, če mu umrejo civilisti, je to višek, kjer se konča razum? Halo Rusi napajo bloke z 2 x ciljanjem. Najprej porušijo blok in nato na isto mesto izstrelijo še 1 raketo, da pomorijo še reševalce!!!
Leif ::
Leif je izjavil:
Ni prispevka, kar direkt vzamejo
https://www.rtvslo.si/slovenija/kijev-s...
Leif je izjavil:
Leif je izjavil:
Se pravi daš 20€, daj TRR, da ti nakažemo na Leif5 na 1919.
Windlass ::
Leif je izjavil:
Leif je izjavil:
Kako pa vzamejo za vse ostalo s čimer se ne strinjava? S to logiko (ne z mojim dnarjem) lahko greš vsakič, kadar ni tvoja politična opcija na oblasti in tam financira nekaj s čimer se ne strinjaš. V demokraciji je pač tako.
RTV pa to ni. To je anti-demokracija. Z volitvami nič ne morem vplivati na nagnjenost RTV.
Pa mimogrede, zadnjič je nekdo napisal dejanske stroške ˝financiranja vojne v Ukrajini˝, sem si prav shranil za take primere:
Republika Slovenija je med leti 2022-2025 asistirala Ukrajini s 30-100 milijoni evrov (odvisno kaj štejemo), kar vključuje direktne donacije, ceno materialne humanitarne pomoči, vplačila v sklade EU in programe za pomoč vojnim beguncem na teritoriju Republike Slovenije (npr. zdravljenje in rehabilitacija žrtev in socialna podpora). Na posameznega državljana RS to znese celokupno od 15 do 50 evrov oz. od 3,8 do 12,5 evra na leto/na osebo.
Torej 1 mesečna položnica za RTV je lahko 3x večja od tega kar ti na leto ˝financiraš Ukrajino˝. Tako za idejo o kakšnih vsotah se gre.
Windlass ::
To je vse absoulutno res, ampak ali veš za vsakega posameznega umrlega kaj je podpiral? Pomisli na enega politika, ki ga ne maraš in koliko si kriv za to kar on dela. Ja nisi, ane. Skupinskega kaznovanja se pač ne gremo. To je potem tako kot Putin, ki kolje celo državo zaradi 0,2% nacistov (pa še tisti so izmišljeni) :))
Saj nihče ne pravi, da so Ukrajinci ciljali študentski dom ali da ne smejo raketirat nazaj. Seveda smejo, še več - morajo. Ampak kolateralne škode nima smisla omalovaževat. V članku od Pacota lepo piše, da v eno od stavb niti Kremlju-prijazni novinarji niso smeli, ker vojaki niso dovolili. Pa da so zraven naselja droni natančno zadeli bivši agrokulturni obrat ki je služil kot kdovekaj (ki ga ruski mediji niti omenit nočejo).
Jaz sem 100%, da bodo Ukrajinci po koncu vojne plačali odškodnino in se upravičili tem žrtvam do katerih je prišlo, za razliko od Rusov. Primer je lahko strmoglavljeno letalo.
ICAO uradno potrdil: Rusija odgovorna za sestrelitev letala MH17
Rusija odločitve sodišča ne sprejema
https://siol.net/novice/svet/icao-uradn...
shmandi ::
Leif je izjavil:
To ravno ne sovpada s tem, da se hoče Evropa polastiti ruskih naravnih bogastev... Shizofrenija mogoče?
Leif je izjavil:
Leif je izjavil:
Preseliš se v Rusijo (ali Belorusijo) in odjaviš davčno residentstvo v Sloveniji. Problem rešen. Kaj še čakaš? Spizdi že enkrat!
Leif ::
Pithlit je izjavil:
Leif je izjavil:
Leif je izjavil:
Zakaj ne daš istega nasveta tistemu, ki jih moti plačevanja rtv prispevka ? Pa ne da sem jaz full navdušen nad njim. Kak poseben razlog za to ?
Leif je izjavil:
Leif je izjavil:
Ne, čisto resno. Naj spizdi iz Slovenije če mu kaj ne paše. Jaz ne bom zalagala zanj.
Leif je izjavil:
Pithlit je izjavil:
Leif je izjavil:
Leif je izjavil:
Sem že. Pa si ti edini k neki joka. Bil bi zu, ne bi pa sodeloval. Jok brate, ne gre to tko. Sodeluj ali pa se odstrani. Zaradi mene lahko tudi najbližji dovolj visok most uporabiš.
  • spremenila: Pithlit ()
1361 / 1427
