k4vz0024 je izjavil:
Nemški kancler Shultz opozarja, da Putler lahko zavzame Ukrajino. Je kaj na tem?
Ja, če ostane brez podpore zahoda. To je že večkrat povedal...;)
Počasi in počasi rašisti grizejo ozemlje banderaboysov. Rašistov še kaj kmalu ne bo zmanjkalo, saj je pri njih človek potrošni material. Proti takim orkom se je pa nadvse nehvaležno bojevat, saj jih nekako kar ne zmanjka.
Ta vojna se lahko neha samo, če Rusija kot država vmes razpade, bankrotira, whatever. Ampak ker so Rusi vajeni vsega slabega, in so za vse to sranje, ki jim ga Putin servira, še močno hvaležni, bodo sami vejetno za dosego cilja, to je osvojitev Ukrajine, z veseljem pristali v kameni dobi.
Zahod pa vse to anemično gleda, in se čudi. Aja, pa tu in tam pošlje kakšen paketek orožja.
Putin said that Russia is not going to go to war with NATO countries.
"Russia has neither territorial claims nor any other interest to go to war with NATO countries," Putin said.
Putin called Biden's recent words that Moscow might attack the Alliance countries in case of its victory in Ukraine "complete nonsense, and President Biden understands this."
At the same time, the Russian president said that in response to Finland joining NATO, Russia has begun to recreate the Leningrad Military District.
Javelin med 12 in 15 sekundo je kot iz filma.
https://twitter.com/Tendar/status/17363...
The Russian attacks in the vicinity of Synkivka are primarily suicide operations for them, so a pretty standard day.
In the beginning of this video you can already see four newly destroyed Russian vehicles. For the next two BMPs it looks not better. You can see a projectile (probably Javelin) reaching altitude and then slamming into the leading vehicle from above, blowing off mounted infantry.
The fact that the other Russian BMP got destroyed almost simultaneously gives this choreography a nice touch.
  • spremenilo: Lesoto ()
k4vz0024 ::
Povedano drugače. Šel v bo v vojno z NATOM, ker je patološki lažnivec in megaloman! Seveda sledi razkosanje Rusije do Urala in za Uralom!
An Ukrainian FPV drone of the 60th Brigade struck a juicy Russian target. This BTR carried around 10 Russians. The hit certainly wounded all of them and potentially killed those directly in the crosshairs.
Ukraine is preparing three lines of fortifications in case partners are slow to provide weapons and money, - People's Deputy Ustinova "In winter, it will be necessary to switch to a defensive war. Even when money is allocated, the world will still run out of ammunition"
Okapi je izjavil:
Ne morem pomagati, če ne znaš brati. Sem dal povezavo do slovenske in angleške razlage.
Razlago ti sicer lahko daš, ne razumeš pa pomena.
Tisti, ki ne razume, si ti. Evo, tule si poglej en primer sodobne modularne ročne bombe. Ofenzivna je brez fragmentacijske srajčke, ko srajčko natakneš na bombo, postane pa defenzivna.
The grenade is not just more lethal, but is safer to use. It has a distinctive design that gives flexibility of employment in both defensive (fragmentation) and offensive (stun) modes
  • spremenil: Okapi ()
tattoo ::
Opinion: Talks can't end the Ukraine war, because Russia lies
https://www.latimes.com/opinion/story/2...
  • spremenil: tattoo ()
tattoo je izjavil:
Nekaj podobnega je povedal tudi Putinov svetovalec.
A drone attack and air defence activity was reported today in Rostov and two other regions of Russia. In Rostov region, presumably, a Morozowsk airbase was a target.
/2. Russians share photos of
Su-34 with some visible shrapnel damage (Russians describe damage as not severe) and drone debris from Morozowsk airbase.
Looks like it was the friendly fire.
18:15
Two Majors: "In Mykolaiv Buk-M3 shot down a Ukrainian Su-25"
21:12
Fighterbomber: "Eternal flight, brother..."
Fritz:: danes, 20:35:47
Moraš biti pa resnično naiven da pričakuješ da bo v primeru vojne med ZDA in Kitajsko, Kitajska samo gledala Evropo. Ti veš da smo mi v NATU? Veš kaj pravi peti člen? Dejstvo je da so tiste Kitajske letalonosilke tudi za Evropo. Bo pa potrebno počakati da vidimo koliko jih bodo zgradili. Rušilce gradijo kot utrgani in ko bodo enkrat presegli ZDA se ne bodo ustavili. Kitajski ima potencial da bo njihova mornarica vsaj tako velika kot vse mornarice NATA skupaj.
Ni mi potrebno gledati na zemljevid. Dokler bo imela Kitajska na svoji strani Rusijo so takšni scenarij še kako mogoči. Kar se tiče podmornic pa to ni nič nenavadnega da so na tisoče kilometrov stran, v bistvu je celotna poanta podmornic da so čim bližje ostalim državam v primeru kakšnega jedrskega spopada in hitrega odgovora. Drugače pa niti ne gre samo ladje, tudi bombniki bodo nekega dne problem za Evropo zaradi dolgega dosega.
Bolje biti pripravljen kot se zanašati na "Kitajske letalonosilke so za ZDA", "Poglej na zemljevid" itd. Enako so govorili za Rusijo da nikoli ne bo napadla Ukrajine ker naj bi bil NATO zraven. Danes vidimo kakšna je situacija. zaspali in pogrnili smo na celi črti.
5. člen pravi, da se v primeru napada na eno članico aktivira skupno obrambo.
O upravičenosti tega odloča NAC. Recimo NAC ni odobril napada na Irak kljub lažem ZDA o vmešanosti Iraka v napad 9. 11. 2001 in o orožjih za množično uničevanje. NAC tudi ni odobril napada na Afganistan temveč le podporno ISAF misijo po tem, ko so ZDA že napadle Afganistan in tam peljale ločeno bojno misijo.
Če citiraš Severnoatlantsko pogodbo se malce bolj pouči o njej. Prvo, če se ZDA nekje na Pacifiku zapletejo v vojno s Kitajsko zaradi Tajvana ali česa drugega, se to nas in večine drugih članic NATO niti najmanj ne tiče. Poleg tega pa v Severnoatlantski pogodbi piše tudi tole:
Za namen 5. člena se šteje, da oborožen napad na eno ali več pogodbenic vključuje oborožen napad:
- na ozemlje katere koli pogodbenice v Evropi ali Severni Ameriki
, na alžirske departmaje Francije , na ozemlje Turčije ali na otoke pod jurisdikcijo katere koli pogodbenice na severnoatlantskem območju severno od rakovega povratnika;
- na sile, plovila ali zrakoplove katere koli pogodbenice, ko so na teh ozemljih ali nad njimi ali na katerem koli drugem območju v Evropi, na katerem so bile na dan začetka veljavnosti te pogodbe nameščene zasedbene sile katere koli pogodbenice, ali na območju Sredozemskega morja ali na severnoatlantskem območju severno od rakovega povratnika.
Ali sta kje omenjena Azija in Pacifik!? Sicer bi ti že ime 'Severnoatlantska' moralo kaj nakazati.
Če Kitajska napade ozemlje kontinentalnih ZDA ali ZDA celinski del Kitajske, to pomeni, da je v igri strateško jedrsko orožje in je debata o operatiki in strategiji nesmiselna, ker je to globalni Game Over. Tudi če Evropa ne bi direkt pokasirala kopice ICBM-ov, bi zaradi kontaminacije in jedrske zime izgubili večino prebivalstva. Je pa to wishful thinking ker si v primeru jedrskega spopada med Kitajsko in ZDA ne predstavljam Ruse kako mirno gledajo lansiranje več sto ameriških ICBM, njihov jedrski odgovor pa zagotovo vključuje NATO del Evrope.
Pengič 2-0 ::
Bauc je izjavil:
tattoo je izjavil:
Glede na to kakšne politične igre se gredo trenutno v ZDA kongresu kjer je njegovo krmilo prevzel krščanski fundamentalist Mike Johnson je za Skandinavijo, vzhodno Evropo predvsem pa za Baltik smiselen razvoj jedrskega orožja z ekpresno dostavo direkt v Moskvo in se preventivno rešiš konvencionalne vojne in dosežeš mir ki se ga vatniki tipa orban tako močno želijo. Seveda nihče ne razmišlja v tej smeri. Sploh Poljaki so mi malo hecni s temi megalomanskimi nabavami ameriškega orožja. Le kdo bi še hotel po tej vojni v Ukrajini pošiljat Evropsko mladino v smrt. Komu na čast? Američanom?sploh pa ne rusom.
Pengič 2-0 je izjavil:
Bauc je izjavil:
tattoo je izjavil:
Si pozabil kaj so Rusi storili Poljakom? Bomo šli v detajle, ali boš sam preučil to! In sedaj Rusi napadejo Ukrajino in v primeru poraza te države imajo Ruse na meji! Verjeti Rusu je kot bi verjel vedeževalcem na TV-ju.
Pengič 2-0 ::
Bauc je izjavil:
tattoo je izjavil:
Ja sej razvoj jedsrkega orožja je smiselen za poljake, zakaj bi se zajebaval z rusi konvencionalno? komu na čast?
Bauc je izjavil:
tattoo je izjavil:
Nedvomno ima intervju nekaj dodane vrednosti, da se spozna Putina osebno, kakšne navade ima, kako funkcionira. Tudi to je pomembno, da je Rusija prekršila pisne mednarodne pogodbe in to ne eno, ampak nekaj njih.
Zdi pa se, vsaj tako nekako človek dobi občutek, da Putin nekaj več ve, kot vsi ostali. To pa sigurno ni res. Pa pomembno je, da se je zgrešila ena druga poanta. Putin je predsednik Rusije, lahko naredi največ, kar lahko naredi Rusija. Lahko še tako bere poročila, koliko tankcev ima, poročila njegovih najbližjih kameradov so nastala na podlagi poročil, ki so jih napisali pa nižji aparatčiki.
Putin in njegovi aparatčiki preprosto ne morejo preveriti vsega. Recimo, ne morejo preveriti, da se tankist ne more pogovarjati s pilotom, ki leti nad njim, da uskladita delovanje.
Seveda lahko Putin reče, da se bo "videlo", kdo prenese več bolečine. Rusi imajo že čez pol miljona žrtev vojne, pa sem niso šteti zaporniki, wagnerjevci (dokler so bili pod Prigožinom) ipd.
Putin je na pragu, da bo ponovil napako carja Nikolaja II., ki se je igračkal z usodo carske Rusije tako dolgo, doker ni dobil kroglo v glavo. Tudi Nikolaj II. je menil, da je Rusija preprosto večna in da nič ne more spremeniti tega dejstva. Že 15km izven Carskojevega sela so bili ljudje lačni cele dneve. Enako problem ima, po moje, Putin.
Da Putin, tako kot Nikolaj II podcenjujeta trpljenje Rusov, pač saj je Nikolaj II vedel, da ljudje nimajo kaj za jesti. Vendar je šel zvečer spat sit in je na problem malo pozabil. Spomnil se je za morda mesec dni, ko so oboroženci vdrli v preddverje carske palače.
Putin sedaj vse sile usmerja v vojno proizvodnjo. To lahko traja max. 1-2 leti, potem pa bo nekomu počil film.
Previously undocumented Russian Avdiivka losses, which were published by
@OSINTua
o 1xT-62, Abandoned/damaged;
o 2xT-72B3M, Destroyed;
o 1xT-72B3M, Abandoned/damaged;
o 2xT-80BV, Destroyed;
o 3xT-80BV, Abandoned/damaged;
o 1xBMP-1, Abandoned/damaged;
o 3xBMP-2, Destroyed:
o 2xMT-LB, Destroyed;
o 2x VPK-59095S "VPK-Ural", Abandoned/damaged.
Total: 17 losses.
In total, almost 100 (97) Russian Avdiivka losses were documented thanks to footage provided by
@OSINTua, you can support him by link:
https://t.co/XS2cxcx9Nu
Bauc je izjavil:
tattoo je izjavil:
Kam boš po Evropi metal jedrsko orožje? Kam ga bo vrgla Poljske, če Rusi čez mejo vdrejo v državo? Na svoje ljudi, na svoja polja, na svojo vodo?
Pengič 2-0 ::
kam? direkt v moskvo. tako moč potrebujejo države ki so na potencialnem udaru s strani rusije da se ta saga enkrat za vselej zaključi. Rusi države z jedrskim orožjem ne bodo napadli. Ampak dober rusi so si v ukrajini že toliko polomili zobe da imamo pred njimi mir za nekaj časa.
Pengič 2-0: Tomaž Štih libertarec, si to ti? :)
Ja na Twitterju se špekulira, da bo Rusija zanetila vojno na vzhodu Evrope, napadla Poljsko in dala orožje Srbiji, ki bo napadla Hrvaško.
V primeru Ukrajinskega poraza bomo imeli vsaj vojno v Moldaviji in Gruziji ter poizkus destabilizacije baltskih držav. Glave bodo dvignili tudi drugi potencialni graditelji "imperijev", ki zdaj lurkajo v ozadju.
Bauc je izjavil:
Slovenija bo imela za vratom Madžarsko, to je sigurno. Tako da ja, ne želimo si poraza Ukrajine v prav nobeni obliki.
bbbbbb2015: Tomaž Štih je zelo dobro napisal, da imamo problem, ker je Zahod neenoten, ker je kulturno-bojniške spore v zadnjih 20 letih zanetila levica, ki ne da miru (spomnimo se protestov proti G8 v Genovi itd.)
Recimo Orban: on je bil 25 let nazaj čisto "normalen", libertarec. Ampak potem so mu preko Sorosa in blogalnih levih združenj določene mednarodne organizacije (ironično iz pro-Zahodnih ZDA in pro-Zahodnega Bruslja) v državo začele uvažati skrajno leve NVO aktiviste in financirale delovanje, ki je sesuvalo madžarske konservativne stranke (ne samo FIDESZ, tudi ostale). In tip je (logično!!!) pop****l, znorel, pošizil, in "zradiral" vse te 'Sophie In't Veld NVO-jevce' z raznimi 'Alphabet-people' agendami. Posledično so ga ti aktivisti zašpecali z Washingtonu in Bruslju, da je bad-bad-Orban. In zdaj imamo kar pač imamo.
Ukrajina ima malo tudi časovne smole.
Putin je udaril ravno zdaj, ko je velik del konservativcev, desne-sredine whatever v EU-ju, v ZDA totalno razkurjen do fundamenta, do amena, na robu vrelišča so, ker so te levičarske zadeve z 'alphabet-people' raznimi "genderji" ter premikanjem tega, kaj je sredina totalno na levo, tako da je Helmut Kohl iz leta 92 praktično postal nacist, šle vse totalno predaleč. In so dejansko po principu 'Everything-be-damned' pripravljeni POŽGATI ZAHOD DO TAL. Ironično, tako kot so Zahod do tal že dolgo pripravljeni požgati skrajni levičarji.
Tomaž Štih je lepo napisal, da so pametni ruski KGB-jevci mrtvohladno kot špricer TOČNO VEDELI, kam morajo s psy-ops warfare udariti, s svojim sklicevanjem na konservatizivem in tradicionalizem. Zahodno javno mnenje so jim Zahodni levičarji servirali na pladnju!
Elonu Musku dam v nečem prav: da dobro ve, da je s to 'hateful speech' in 'speech policingom' ter 'BLM wokizmom' potrebno nehati in on po načelu nekega anarho-liberalca z nakupom Twitterja strateško skrbi za odprtje komunikacijskih kanalov v Zahodnem javnem diskurzu.
Postavimo ironično tezo: šibek odziv desnice na Stonewall Riots je v 40 letih povzročil, da sedaj Ukrajina v ščitenju svoje samostojnosti in državnosti nima enotne podpore Zahoda :) Ergo, če bi konservativni pol takrat zadržal kulturno-bojni tok izhajajoč iz Stonewall Riots, bi danes imeli bolj enoten Zahod in Ukrajina bi imela večje šanse :)
Seveda, nič nima s tem, da dela vse kar lahko, da se obdrži čim dlje na oblasti (mediji, zakonodaja,...), ne. So vsi drugi krivi, ker on ne bi, ampak so ga drugi 'prisilili'.
Kolk je že zlajnana ta desničarska mantra in igranje žrtve, kako oni ne bi, samo ker je sosed izobesil mavrično zastavo niso mel druge, kot da ga grejo s kolom premlatit...
nejcek74 ::
@Malidelnčiral
Čemu potreba da v temo o Ukrajini vlečeš ultra desničarske blodnje s katerimi opravičujejo lastne poizkuse razgradnje demokracija.
Floskula, "druga politična opcija so nevarni extremisti, zato so dovoljena vsa sredstva", je običajen trik fašistov, tudi tistih wannabe. Vključno s Putinom, Trumpom ali pa našimi jamraci nad ukradenimi volitvami.
nejcek74: zato, ker je TRENUTNA POLITIČNA SITUACIJA (ki je posledica zadnjih 30 let kulturnih trendov na Zahodu) vzrok neenotnosti Zahoda. In je potrebno to situacijo razumeti.
Jaz si tudi želim Zahodne enotnosti, ampak je izjemno šibka. Redki so na alt-right desni sceni, ki so pro-ukrajinski (na Zahodu izstopata Melonijeva in Abascal iz španske stranke VOX).
Žrtev je pa Ukrajina.
Jaz jo razumem kot posledica tega, da imamo zaradi učinkovitega zatrtja nacijev po ww2 situacijo ko ljudje ne verjamejo, da je kaj takega spet mogoče in se potem gremo popuščanje nacijem, ker smo 'boljši', za povrh pa še diktatorji lifrajo denar ekstremistom, da furajo pro-diktatorsko propagando in prepričujejo kako je zahod slab in da mora propast, kot alternativo pa zgleda hočejo putinizem, ker ta se 'samo brani' jada jada.
Jah, ne grizeš roke, ki te hrani, ne...
TESKAn je izjavil:
Obratno. Putin govori, da so Ukrajinci 'banderisti' recimo in da se Rusija bori proti "nacizmu". Pri tem pa ga velik del skrajne levice podpira, ker ima distorziran pogled na to, kaj so skrajne ideologije in od kej prihaja največja nevarnost. V smislu kot je Churchill rekel, 'antifašisti' sedanjosti bodo 'fašisti' prihodnosti. Recimo podobno kot v sedemdesetih, ko se je globalna levica s pomočjo Sovjetske zveze ter raznih rogua akterjev kot je bila PLO posluževala terorizma ala Brigate Rosse, Baader-Meinhof itd.
Štih zato svari, da je Zahod sam sebe ošibil, ker je desno-sredino, ki je bila temelj moči Zahoda, ker je vedno z roko-v-roki sodelovala z levo-sredino (tako v Evropi kot v ZDA) izrinil iz svojega pojmovanja "civilizirane" debate.
Za to, da bo Ukrajina dobila potrebno orožje, bo potrebno očitno na Zahodu narediti politične koncesije, ki pa niso prehude, če vemo kaj je v igri - Ruska vojna v celotni vzhodni Evropi.
Torej v ZDA morajo demokrati popustiti pri odprti južni meji in pri prebujenski ideologiji, v Evropi pa mora levica popustiti pri zelenem prehodu, abecednih-ljudeh in pri migrantski trgovini.
IMHO mala cena, ki jo je potrebno plačati, da se vzpostavi koalicija voljnih, da se prepreči veliko vojno v Evropi.
Malo neumno, da bi brali zgodovino, da je prišlo do velike vojne, ker nekdo ni popustil pri solarnih panelih, vetrnicah in spolnih zaimkih him/her.
Pengič 2-0 ::
ha ha ne nisem štih, na twiterju se svašta špekulira a v živo vidimo kako je če si odvisen od zahoda. Kaj pa če se Poljaki enkrat v prihodnosti ztačnejo fajtat z rusi pa se amerom naprde neki ker s takim kongresom in predvsem s takim speakerjem mike johnsonom si lahko nato pakt nekam zatakneš. Razvoj jedrskega orožja to ti je varnostna garancija isto za ukrajino po vojni,vse ostalo je komedija.
Pengič 2-0 ::
TESKAn je izjavil:
Zdaj ima eu šanso da se zoperstavi ameriki in pokliče tale republikanski, mike johsnon blef in lepo ameriki razloži da so neresni in da gre eu v razvoj jedrskega orožja za baltik, skandinavijo in vzhodno evropo. To se seveda križa z ameriškimi interesi ker oni bi radi da se mi fajtamo z rusi konvencionalno v bistvu so nas že rusom prepustil tako da eu nima kaj za izgubit.
https://twitter.com/JayinKyiv/status/17...
Russian oil production from its decaying old soviet garbage infrastructure is now back to the level of 2010.
Meanwhile, SINCE 2010, US oil production has almost tripled, continuing to hit records.
2010 (barrrels/day)
US 5 million
Russia 9.5 million
2023 (barrels/day
US 13.5 million
Russia 9.5 million
A to smo spet pri tisti Rusiji, ki ne zmore premagati ene Ukrajine a bo jutri zavzela vso Evropo?
Pa če bi bila Ukrajina članica NATA, se je Rusija ne bi upala napasti. Zato bo Rusija po zmagi v Ukrajini šla napadati NATO države. Ta Rusija?
  • spremenilo: Fritz ()
8-O
Fantastic news
According to RU sources: 2 SU-34 destroyed, 10 - damaged in Morozovsk military airfield (Rostov region)
Fritz je izjavil:
Vpašaj Sovoljeva in podobno bando na prvi ruski TV, ki vsakodnevno grozi vsem po Evropi, da so ti in oni naslednji, ki jih bo Rusija napadla.
Pengič 2-0 ::
Fritz je izjavil:
Gladko, vpade v eno izmed držav baltika, gre kolikor gre, preden začne MAGA NATO prdet koliko orožja poslati pa kdo se bo boril se rusi vkopljejo in smo spet na istem kot v ukrajini kjer nas ruskiči prepičujete da se je zaradi mira najbolje predati, zda pa ne bodo nukale zaradi par kosov baltiške zemlje. potrebuje se jedrsko orožje pika.
Nobenenega vkkopavanja ne bo na Baltiku, ker bodo horde F-35 zmlele rusko klumparijo.
Za vkopavanje rabiš mesece in mesece časa.
Pengič 2-0 ::
A pa bodo res? A bo maga mike johnson z republikanci na čelu začel prdet o nekih migrantih v teksasu?
Saj ima Evropa dovolj F-35. Tudi Poljska jih dobiva, pa Češka.
Poland inks $4.6 billion contract for F-35 fighter jets
WARSAW, Poland — Polish Defence Minister Mariusz Blaszczak has signed a contract worth $4.6 billion under which the country will acquire 32 F-35A Lightning II fighter jets from the United States.
Da ne govorimo o enormnih količinah HIMARSov, ki so jih Poljaki naročili.
Pengič 2-0 ::
ok kul maga prdci ne dovoiljo uporabe in blokirajo rezervne dele?
Fritz je izjavil:
Spet ne razumeš. Rusija ni sposobna zavzeti Evrope je pa sposobna narediti novo pizdarijo v Evropi. Japonci niso bili sposobni premagati kitajske pa jih to ni ustavilo, da ne bi sprožili še vojne proti ZDA. Dejansko tvoja meme slika pojasni situacijo. Bolj kot je država nesposobna bolj je nevarna. Upam, da ti je zdaj bolj jasno :))
  • spremenil: Bauc ()
Pengič 2-0 ::
Lesoto je izjavil:
Poljaki naj gredo raje v razvoj jedrskega orožja.
A se hecaš? Republikanci pa oborožitvena industrija so ta najboljši frendi.
Pengič 2-0 ::
Lesoto je izjavil:
vidimo zdaj ja kaki frendi so
Pengič 2-0 ::
A ni več kot očitno da se ameri zajebavajo z ukrajino pa ne samo oni. Verjetnost da se bo morala vzhodna evropa boriti z lastnimi mladci ni zanemarljiva. Zakaj naj se tvega? jedrsko orožje pa mirna bosna.
Lesoto je izjavil:
Nič ne vidmo. Nimamo pojma, kaj se odzadaj dogaja.
Da bi Američani preprečili uporabo svojega orožja v kakšnih konfliktih ali ga na kakršenkoli način omejevale, bi bil to konec ameriškega uvoza orožja kamorkoli.
Ne zmišljuj si bedarij, ker samo zapravljamo čas.
Ni važno kdo so, republikanci ali demokrati, obojim diši denar. Vsem se smeji v Ameriki, kakšna naročila imajo njihove industrije in takšnih naročil še ni bilo nikoli, vsaj v takšnem obsegu ne.
Daj nehi sanjati o jedrskem orožju, mater ste eni fanatiki na kubik.
  • spremenil: scythe ()
Zimonem ::
Saj ne vem samo kako gre sedaj tej je zahodni ukrajinski navezi? Zmagujejo? Koliko je mrtvih na fronti?
Pengič 2-0 ::
Lesoto je izjavil:
Lesoto je izjavil:
hmmm ravno to sedaj počnejo v ukrajini zakaj ne bi na baltiku? dej raje ne tolčti po rusiji bo jedrska eskalacija pa take maga fore.
Pengič 2-0 ::
Zimonem je izjavil:
Glede na to da je pomoč pičla ker je vse blokirano s strani maga orban in mike johnsona je ukrajina zdaj prepuščena sebi, tukaj pa folk sanja da bodo prdeli f35 če putin po ukrajinski vojni eskalira na baltik.
Pengič 2-0 ::
Bi pa zdaj vprašal ruske mirovnike za koga se zdaj ukrajina bori glede na to da ne dobijo skoraj nič več pomoči? A še vedno za ameriške interese aka ameriški hlapci, spomnimo se kaj so ruski papagaji gvoril. Da ukrajina skoraj nima interesa fajtat to vojno da so jih zglumim pa ostale neumnosti.
Noben se pa ne vpraša, ali je to kakšna igra za javnost? :D Že tolikokrat smo to slišali v 2 letih vojne, ni orožja, ni ljude, ni tankov, ni granat, ni eurov, ni dolarjev..., da se ne verjame nič več. Čez 3 dni bo padel Kijev!
AtaŠtumf ::
Lesoto je izjavil:
Poudarek tukaj je sicer na naročili, ne dobili!
Sicer pa, koliko dobav orožja so ZDA že dostavile pri prejšnjih naročilih, recimo tistih naročlih še pred vojno v Ukrajini?
So dostavljeni že vsi naročeni F35, Himarsi, Patrioti, ..., po svetu?
Ne spremaljam, pa me resno zanima, da malce vidimo, kako ažurni so Ameri pri svojih dostavah.
593 / 1551
