Lesoto je izjavil:
Precej dobro zgleda za mrtvaka.
https://twitter.com/GloOouD/status/1662...
Today, the small armored artillery boat "Bucha" was handed over to the naval and boat depot of the Armed Forces of Ukraine.
The official induction ceremony was attended by Deputy Minister of Defense of Ukraine Volodymyr Gavrylov, Commander-in-Chief of the Armed Forces of Ukraine General Valery Zaluzhny, Chief of the General Staff of the Armed Forces of Ukraine Lieutenant General Serhii Shaptala
Tolk o dveh tednih konstantnega lepljenja po forumu,da je mrtev:D Rusofilski blogerji so spet peljali folk žejne čez potok.
Ja, nič. Ukrajinci stopnjujejo pritisk. Napadajo skladišča, objekte, transportna vozlišča, dronirajo, napadajo ladje, napadajo Rusijo čez mejo. Wagnerjevci so nekako odnehali (so izčrpani). Napadajo tudi transportne konvoje. Napadajo tudi naftna skladiča in železniške dispečerske postajo. Napadajo municijo, skladiščeno pri letališčih.
To je že vse v redu.
Zanimivo je, da se ne obremenjujejo samo z enim področjem. Šibajo po celotnem zasedenbm ukrajinskem delu.
Vprašanje je samo, koliko so degradirali moč Rusov? 5% 10%, whooping 50%? Bakmut je potihnil, vendar jih Ukrajinci ne pustijo iz klešč.
mini nuka
Russian positions in Bakhmut - MEGA SUPER BAVOVNA
rationlibe00 ::
https://twitter.com/DefMon3/status/1662...
Weekend starting off nicely. There is a noise complaint from the locals about a disco a Azovstal
Russians has set up checkpoints to block access to Azovstal . They are bringing in local workers to help clear debris in an effort to rescue Russian soldiers.
2x nit
https://twitter.com/MarkHertling/status...
This is a spot-on thread by @LivFaustDieJung.
Those who have never done a combined arms breach - in training or combat - will read this thread and say “wow, that sounds near impossible.”
It is. To execute a successful breach a commander had all sorts of things happening at once.
-intelligence prep of the battlefield (with shaping operations, raids, deception, etc)
-a great plan with a solid synchronization matrix
-various means to suppress the enemy (artillery, direct fire, electronic jamming & other means)
-obscuring the breach
-a well-rehearsed breach force with plows, mine clearing charges, “cutters,” etc
-marking of the breach lanes for a well-rehearsed follow-on force that will hold the shoulders of the breach
-a plan to the attack or bypass the defending force that is over watching the breach
-rapid aid/recovery for those wounded in the breach
-push of logistics and more follow-on forces through the breach to continue the attack.
And as @LivFaustDieJung said at his thread’s end, all the while the enemy is shooting at you, ‘cause the enemy always gets a vote.
jernejl ::
Če pustimo ob strani, da vojaški napad ne paše več v sedanje obdobje t.i. civiliziranega sveta, je poanta pisanja, da vsaka posledica ima svoj vzrok. Naučeni smo blažiti posledice in ne odstraniti/minimalizirati vzrok. Vem, da boste mnogi kar na prvo žogo kot iz topa izstrelili, da je kriv Putin. Seveda je kriv, da je napadel UA, potrebno je pa gledati širše, zakaj se je odločil za to, kaj je pripeljalo do tega,... (pa ne spet priti naprej s posiljevalcem).
Razlaga je komot ta, da je putler psihopat, ali pa da se je pač odločil za landgrab. Počasi bo umrl in morda si je zaželel, da bi bil tako ali drugače zapisan v zgodovino.
Torej ja, lahko rečemo, da je v vlogi posiljevalca. Tudi pri slednjem se moramo vprašati, kaj je bil vzrok posilstva. In to ni prekratko krilo, ki ga je nosila žrtev. Lahko pa je krivda na družbi, ki psihopata ni dovolj zgodaj prepoznala in mu preprečila to dejanje. Pri putlerju je to v prvi vrsti domače volilno telo, ki je dovolilo, da je situacija šla tako daleč. Potem pa tudi mednarodna skupnost. Spomniti se moramo, da je putler Ukrajincem najprej ukradel Krim. In ker je mednarodna skupnost gledala stran namesto da bi mu za to naložila veliko kazen, je pač dobil signal, da se lahko krade praktično zastonj, in je s tem nadaljeval. Saj podobno je bilo pri hitlerju. Zgodovina nas uči, da je najboljša rešitev v takih primerih ta, da se takemu agresorju čimprej polomi zobe. In to konkretno.
Most recently in Sudan, the Wagner Group has been supplying Sudan's Rapid Support Forces with surface-to-air missiles to fight against Sudan's army, contributing to a prolonged armed conflict that only results in further chaos in the region, the statement reads."
Torej eni lahko dostavljajo orožje, drugi pa ne?! Dvojni vatli?!
Čakaj, oni oborožujejo paravojaške milice, ti pa tu govoriš o dvojnih vatlih v primerjavi s pomočjo Ukrajini? :)) Ukrajina uradno prosi za pomoč, Sudan pa dvomim da prosi wagnerjevce, naj kriminalcem v njihovi državi dostavljajo orožje. Eni pomagajo žrtvi, drugi kriminalcem pri izvedbi kriminalnih dejanj.
Tvojo nelogiko ponazarja tudi spodnja zgodba.
Micka ima fanta Poldeta. Nekega dne jo posili sosed Stanko. Stanko zato gre v zapor. Zaradi spolnega občevanja z Micko je en zaprt, drugi pa ne. Dvojni vatli?!
Rambutan je izjavil:
Edini problem pri tvoji teoriji je, da bo te rakete treba nadomestit. In namesto za stanovanja in druge dobrine, bo šel ta denar za rakete. Tako da če sedaj porabimo rakete, bomo v prihodnosti namesto stanovanj delali rakete. Enako bo s tistim EU miljonom granat, pobrali bodo denar iz mirovnega sklada EU, ki je bil namenjen za grajenje cest.
To so že zdavnaj pogruntali, to je ti. dilema maslo ali topovi...
Če sovražnik rožlja z orožjem, ti pa prideluješ maslo namesto topov, te bo sovražnik podjarmil in ti vzel maslo, ti boš pa ostal brez masla in brez topov.
video s podnapisi
https://twitter.com/DefenceU/status/166...
A priest of the russian Orthodox Church calls on russian soldiers to kill Ukrainians, espousing a racist theory about Ukrainians being nothing more than “damaged russians.”
Under Patriarch Kirill, this “church” has been an integral part of the criminal ruscist regime.
Cukrček je buhanka z ikono kot potujoča kapela.
AvtoR ::
Rusija ne bo nikoli normalna država, dokler ne doživi katarze in samoočiščenja! Žal...
mackilla je izjavil:
Če bi/je imel interes pristopiti, bi prilagodil, tako kot ostale pridružene članice. Ali pa bi ostal na tem, kot Turčija.
Očitno ni imel nikakršnega interesa tako da je tudi debata okoli tega popolnoma nesmiselna. Če že bi pa zahteval,da se EU zakonodaja prilagodi po njegovem. Ko enkrat ne bo več Putina in po kakšnem desetletju normalnih razmer v Rusiji se bo pa mogoče celo začelo premikati tudi v to smer. Sicer malo verjetno,ker bodo vzhodno evropska države proti ruskemu vstopu še najmanj naslednjih sto let. Tudi to bo posledica putanove vladavine.
Mislim, da se mora v RU zamenjati cela generacija politikov za normalne politične odnose. Gospodarstvo bo prej naslo poti.
Aston_11 je izjavil:
FireSnake je izjavil:
Kdo bo vso to mašinerijo plačal? Se vpraša kdo?
Ena vodena raketa, ki jo vojak izstreli, da uniči tank, pride 100 000 €.
Koliko ste vi dali za vaša stanovanja?
To so že vse kupljene rakete in porabljen denar. Ali pa bodoče kupljene rakete in bodoče porabljen dnar. Ki bi bil porabljen za isti namen ne glede na morebitne želje po nakupu stanovanj.
Namesto, da bi poslali stvari na deponijo, že kupljene in plačane, jih pošljejo v Ukrajino.
Tako ko rambutan ropota, koliko kaj stane, v bistvu je za oživitev industrije kar dobro. Rusi nimajo kaj oživt.
Pozabljaš da je potrebno zaloge obnoviti. Razumem, da neka tehnika zastari, ima "rok uporabe", ampak zalogo npr. topovskih granat bo pa le potrebno obniviti in to bomo plačali.
  • spremenilo: fikus_ ()
Ja v bistvu je nek miks, definitivno je več kot polovica poslanih zadev šla v Ukrajino namesto na odpad, ampak ostalo polovico pa je kljub vsemu treba pridelat. Ampak vseeno je treba vedit da gre za zanemarljiv strošek zahoda ranga 0.1% GDP.
Veliko večji strošek pa je da so (predvsem EU države) povečale lastno vojaško porabo. Torej lastno oboroževanje nas košta precej več kot oboroževanje Ukrajine. Lastno oboroževanje pa bi se zgodilo tudi brez pomoči Ukrajini v še večjem obsegu, najbrž bi Poljska če bi obramba Kijeva bila neuspešna, povečala izdatek za vojsko na 10% GDPja.
  • spremenil: Lonsarg ()
Lonsarg je izjavil:
10% GBP je malo pretirano, ampak Poljaki bi gotovo pomagali. Jaz vidim težavo, da se vse države oborožujejo, Slovenija pa pač ne. Recimo, poslali smo oklepne transporterje - novih pa ni.
For the first time on Russian TV, propagandists said that Putin and the country's leaders must resign and others need to be elected.
AvtoR ::
Jaz, bi na njegovem mestu pazil, da ne bi padel skozi okno in abstiniral bi pitje čaja...
thundercat ::
Lesoto je izjavil:
Ta je že mrtev, RIP
Thundercat
Pa saj lahko da je le dvorni norček; ki mu je dovoljeno reči kakšno kritično, medtem ko se mu ostali režijo.
Lesoto je izjavil:
mini nuka
Most likely a JDAMS hit on an ammo depot.
https://twitter.com/GeoConfirmed/status...
"Ukrainians probably bombed an underground tunnel complex and/or ammunition depot near Ivanhrad."
Tunnel complex around: 48.5558, 38.0396
Wagnerjevci so izgubili 20k ljudi zgolj v Bakhmutu. Niso imeli pred vojno cca. 50k ljudi? Pomoje od tega ni ostalo kaj veliko. Ce prav razumem, so rekrutirali zapornike in jih porabili za kanon futer. Ce bi bil jaz Wagnerjevec, bi se predal prvi ukrajinski enoti.
Wagner je imel pred vojno cca 6-8k pripadnikov. Kje so našli cifro 50k in to brez onih zapornikov, mi ni čisto jasno?!
thundercat ::
https://www.24ur.com/novice/tujina/kije...
Evo, Ukrajina želi doseči Moskvo z raketami.
Thundercat
Samo 24ur si lahko privošči tako neumen naslov članka.
thundercat je izjavil:
Butasti naslov. Ukrajinci niso rekli,da jih rabijo,da bi dosegli Moskvo:D
thundercat ::
Sheteentz je izjavil:
Sej so vsi isti, klik baiti pač
Thundercat
Lesoto je izjavil:
Pa saj Wagner je rekrutiral, vse tiste, ki jih niso mogli ruski vojaki (kriminalna kartoteka, nimajo ruskega državljanstva, so v penziji - včasih prerana penzija, višje plačilo). Ko so prvi avioni bili sestreljeni, je sicer ven zlezlo nekaj ruskih pilotov, večina pa plačancev wagnerjevcev.
Odhod wagnerjevcev je v redu, ker so jih sicer zdesetkali Ukrajinci, samo implicitno je znak utrujenosti (Rusov).
asdf_jklc ::
Ukrajinci se repenčijo da bodo začel protiofenzivo - da vidmo, al bomo mel rusko al ukrajinsko pašteto.
Če jim Zaporožje uspe zasest do Krima bo to velik dosežek, na kaj več jaz ne bi računal in še to je najbrž bolj longshot. Zasedba Zaporožja bi sicer bila dober korak k zamrznitvi konflikta.
thundercat ::
asdf_jklc je izjavil:
Včasih je veljalo, da je razmerje žrtev pri napadu 3 proti 1 obrambe. Tako da smatram, da bo Ukrajina imela velike žrtve.
Thundercat
Girkin accuses Prigozhin of preparing for a coup in Russia. He says the insults towards the Russian army by Putin's cook are unacceptable, and signal a rift in the elites which Prigozhin will take advantage of with his private army that is being withdrawn from Bakhmut. Girkin adds that if Russia misses the upcoming counter-offensive, the political situation in the country may become unrecongisable by the end of summer.
Watch an excerpt from a longer video posted today.
Political posters for Prigozhin appearing in Russia:
"Yevgeny Prigozhin / Strong Leader / And not a Bunker Coward / Strength / Conviction / Stability"
Vseeno se mi zdi, da je moč Prigožina precenjena ...
https://twitter.com/mixvoronezh/status/...
Even Skabeeva mocks Medvedev. 😃
Spodaj piše nekaj v stilu "Oh, eto našla."
tomlin ::
Dobro vprašanje:
Se strinjate s francoskim predsednikom Emmanuelom Macronom, ki je izjavil, da je Rusija geopolitično izgubila vojno v Ukrajini in da jo Kitajska vazalizira?
M. Friedman
Vazalira je premocna beseda. Se pa Kitajcem smeji, ko dobivajo nafto pod ceno, hkrati pa se jim nikamor ne mudi z novim plinovodom. Na koncu bodo Rusi pristali na izredno slabe pogoje.
Nikec3 ::
tomlin je izjavil:
Dobro vprašanje:
Ja. Kitajci bodo iz te vojne zagotovo potegnili največ. Kot sem pisal že nekaj postov nazaj. Upanje Rusije, da bo Kitajska bolj zanesljiv in enakovredni gospodarski partner, kot je bila EU, je norost.
@WarpedOne o Elonu Musku:
Jaz sem nekako prepričan, da bo ukrajina dobila nazaj Krim. Tam 90% me daje upanje. Nekaj kuhajo ukrajinci. Sicer so rusi "pripravljeni" ampak s tisto staro sovjetsko tehnologijo nimajo za burek proti Zahodni. Me prav zanima kakšna bo slika na koncu. Za ukrajince je to zdaj edina možnost, preden jih Zahod prisili v pogajanja.
Lonsarg je izjavil:
Ce zasedejo Zaporozje je konec vojne in je Ukrajina zmagala. Pade avtomatsko tudi Herson, Krim je odrezan, nobena ruska ladja, ne letalo ne more letati nad nobenim ostalim zasedenim ukrajinskim ozemljem.
tomlin je izjavil:
Dobro vprašanje:
Kina minira Putinov ključni projekat, u Moskvi nervoza: "Nema druge opcije..."
Ruski premijer Mihail Mišustin napustio je Kinu bez "plena" koji Moskva dugo priželjkuje - jasne predanosti Pekinga izgradnji gasovoda Snaga Sibira 2.
Je kitajcem bilo hitro jasno, kaj pomeni plinska odvisnost od rusije. Navsezadnje so imeli dober primer leto nazaj...
Lesoto je izjavil:
Ruske cifre pravijo, da imajo letos 20k manj zapornikov kot lani.
Run-in of Ukrainian recruits with a T-64BV tank with firing, somewhere on a training ground.
Zapornikov nimajo več, ker je skoraj vsem že potekla 6-mesečna pogodba.
Wagner je končal z mobiliziranjem zapornikom nekje v sredini decembra, slabe 6 mesecev nazaj.
  • spremenilo: Lesoto ()
Poanta je, da jih je manj. Verjetno jih je vsaj 10k... mrtvih.
Za Rusijo bi bilo najbolje, če bi bili ti kriminalci VSI mrtvi.
meanwhile:
Taliban soldiers entered Iran today and attacked an Iranian military base.
At least 3 people have been killed in today’s border clashes between Iran and Afghanistan.
Wasn’t a good idea for Iran to send their suicide drones to Russia…
Rambutan ::
Lesoto je izjavil:
23.000 jih je odslužilo živih 6 mesecev, ostali so 200/300. To je verjetno tudi razlog, da se je Wagner umaknil iz Bakhmuta.
Ne verjamem, da jih je 23 tisoč, ker jih je bilo v februarju vse skupaj samo okoli jurja.
Če je pa to res, ima Rusija zdaj 23 tisoč kriminalcev, ki se sprehajajo po Rusiji.
Rambutan ::
Lesoto je izjavil:
23.000 zapornikov je odslužilo 6 mesecev in so jih spustili na prostost.
Lesoto je izjavil:
A je ta informacija iz istih virov kot novice o Zalužnijevi smrti v ruskem raketnem napadu,ki si jih posredoval praktično vsakodnevno zadnje tedne?
TESKAn je izjavil:
Plinska (in naftna) odvisnost Evrope je premočna in predvsem neprava beseda. Nemci so vedeli, da preferirajo Ruse, hkrati pa so svoje gospodarstvo gradili na za njih še vedno poceni plinu. Vendar imajo priobalne države dosti možnosti. V najslabšem primeru plavajoči plinski terminal.
Večji, ponavljam večji problem so landlocked države. Predvsem v tem kontekstu je to Madžarska, Srbija. Tud Slovenija. Slovenska infrastruktura (za plin) je izredno šibka.
Sloveniji načeloma ustreza manj dostopen plin. Potem lahko gradimo na hidro, jedrski in sončni energiji.
O kakšni nepravi besedi ti to? Šlo je preprosto za klasično korupcijo.
  • spremenil: Gregor P ()
In kje si najdel to cifro?? Pomilostitve podpisuje Putin. Jurja iz februarja se je našlo s tem, da so primerjali številke zapisnikov in so na podlagi tega predvidevali, da jih je nekaj čez 1000.
Se pravi, da jih 22,000 zdaj opravlja isto funkcijo kot so jo prej celo življenje. Gnoj.
TukiUki ::
Hmmm?
Rambutan ::
Lesoto je izjavil:
Na youtubeu, verjetno the Duran, ne spomnim se točno.
403 / 1577
