MotionEye nastaviev teksta z URL klicem
poweroff ::
Na Raspberryu imam senzor temperature in vlage ter kamero z MotionEye. Rad bi, da se na sliki videa prikazuje besedilo s trenutno temperaturo in vlago.
Zadevo rešujem takole (temperaturo in vlago preberem v dve spremenljivki, prav tako ime kamere iz MotionEye config datoteke):
BESEDILO="(T: $TEMP C, H: $HYDRO)"
curl "http://localhost:7999/1/config/set?text_left=$CAM_NAME\%20$BESEDILO"
Na videu sem mi izpiše "Komora (T: xx.x C, H: xx)
Rad bi pa, da bi pisalo (xx.x ℃, H: xx%)
Seveda, ko dam notri unicode znak ali % je URL klic napačen... Kakšna ideja kako to rešit?
sudo poweroff
bf4ed ::
Daj unicode številko znaka.
Ali pa znak v enojni narekovaj.
perpetum ::
Rabis URI escape sekvenco procent znaka.
Tole bo v pomoc: https://www.urlencoder.org/
sepravi % zamenjaj z %25
  • spremenilo: perpetum ()
poweroff ::
Ja, to sem naredil, in se zgodi tole:
curl http://localhost:7999/1/config/set?text_left='Francois%25'
Bad Request
The server did not understand your request.
sudo poweroff
perpetum ::
Narekovaji niso primerni. Upam, da si poizkusil tudi brez.
Za primer recimo google search: https://www.google.com/search?q=%25
poweroff ::
Ja, pardon, ne vem kako so se znašli tukaj:
curl http://localhost:7999/1/config/set?text_left=Francois%25
Bad Request
Brez narekovajev javi tole.
sudo poweroff
perpetum ::
Sumljivo.
Malo sem pogledal in ce sm pogledal pravo kodo dobis bad request, zato ker delas GET request, moral bi pa POST. text_left bos moral pa zakodirati v json obliko
https://github.com/ccrisan/motioneye/bl...
Moj predlog, pisan na pamet:
curl --header "Content-Type: application/json" \
  --request POST \
  --data '{"text_left":"%%%test%%%%"}' \
poweroff ::
curl --header "Content-Type: application/json" --request POST --data '{"text_left":"%%%test%%%%"}' http://localhost:7999/1/config/set
Dobim tole:
curl: (52) Empty reply from server
sudo poweroff
Postavitev mySQL
Oddelek: Programiranje
92850 (2428) M01O
PHP POST težava
122347 (2213) DeeJay
Povezave v PHP
Oddelek: Izdelava spletišč
141350 (1145) Gost
java v javascript?
212414 (2117) boss-tech
HTTP POST
232101 (1877) kopernik
