Forum » Loža » Masovne aretacije pedofilskih zdruzb po svetu
[Michael] ::
Ste gledali film Jagten? Gre za odličen prikaz, kaj se lahko zgodi, ko imaš mesto polno pravičnikov, ki mislijo, da so od boga poklicani, da s pestmi delijo pravico.
Ravnokar, hvala ti, da si ga omenil.
Tematika je občutljiva ampak film je pa vrhunski, kot igralci.
Ni enostavno biti sodnik in presojati stvari take ali pa drugačne narave.
hr_natakar ::
"Aretirali Ghislaine Maxwell, prijateljico pokojnega bogataša Jeffreyja Epsteina." "Nekatere Epsteinove domnevne žrtve sicer trdijo, da jih je Maxwellova pripeljala v svoj krog bogatih vplivnežev, da bi jih bogataš s svojimi prijatelji spolno zlorabljal." "Maxwellova je hči pokojnega britanskega medijskega mogotca Roberta Maxwella."
https://www.24ur.com/popin/tuja-scena/a...
vostok_1 ::
Tokrat bodo dali malo debelejši toalet papir, da bo zgledalo bolj prepričljivo.
There will be chutes!
It came from the lab.
Scaramouche1 ::
https://www.emmottsnell.co.uk/blog/fema...
Looking at data from the Center For Disease Control's Survey, researchers found that in 2011 equal numbers of men and women reported being forced into non-consensual sex.
Similarly, the 2010 survey showed comparable results estimating that nearly 4.5 million men in the US had, at some stage in their lives, been forced to penetrate another person - and that in 79.2 per cent of cases, the perpetrator forcing the sexual act was a woman.
Stemple's team also considered data from the U.S. Census Bureau which revealed that in 2012, a study of a percentage women and men who admitted to forcing sex found that 43.6 per cent of that subset were women, compared to 56.4 per cent of men.
SeMiNeSanja ::
A sem štejejo tudi tiste vatiante "Če ne boš ti, bo pa sosed Polde!"?
Pričujoče sporočilo je (lahko) oglasno sporočilo
- četudi na prvi pogled ni prepoznavno kot tako.
(Zdaj me pa obtožite prikritega oglaševanja, če morete!)
Zaradi seksualne narave in dinamike spola se o tem pač ne govori, ali pa je sprejemljivo.
Ker 14 letnik, ki je bil s 30 letno na katerikoli način že, je za svojo okolico car in se enostavno sprijazni.
Hypathia ::
Lahko pa začnemo pospravljati tudi pred lastnim pragom.
Kot kaže zadnja raziskava je v Sloveniji spolno zlorabljenih 18% otrok, torej skoraj vsak peti. Kot pričakovano, je večina žrtev ženskega, večina storilcev pa moškega spola. Zgolj 6% žrtev zlorabo policiji tudi prijavi in le v 3% sledi kazenski postopek in obsodba.
Vlada je predstavila koncept Barnahus (Hiša za otroke), kjer so na enem mestu združeni sodnik, tožilec, policija, socialni delavec, psiholog in zdravnik za telesni pregled otroka, da bi zbrali dokaze, ki so potrebni za kazenski postopek in otroku hkrati nudili krizno podporo in psihosocialno pomoč ter s tem preprečili ponovno viktimizacijo otroka.
Pohvala za potezo, vendar brez spremembe miselnosti ne bo šlo, ki pa je še vedno patriarhalno mizogina, kar najbolje predstavljajo rezultati raziskave. Načeloma Slovence skrbijo zlorabe, razen tretjine, ki jo očitno tolerira ali pri njej celo sodeluje, vendar niso pripravljeni kaj veliko storiti glede tega:
Raziskava ugotavlja, da skoraj 70 % Slovencev meni, da je spolna zloraba otrok v Sloveniji resen problem. Hkrati skoraj polovica oziroma 47 % anketirancev ne bi prepoznala znakov zlorabe, ena tretjina verjame, da spolna zloraba otrok vedno vključuje tudi uporabo fizične sile, četrtina jih meni, da izpostavljanje otrok spolnosti in pornografiji ni zloraba, in 17 % misli, da otroci ne morejo spolno zlorabiti drugih otrok. Dve tretjini anketirancev meni, da šole ne zagotavljajo dovolj informacij za preprečevanje spolnih zlorab in velika večina, kar 90 %, verjame, da bi moralo biti učenje o tem del učnega načrta. Hkrati skoraj polovica staršev pravi, da bi se počutili nelagodno, če bi se o tem pogovarjali z otroki doma in le ena tretjina jih je to že počela.
https://www.gov.si/novice/2020-10-06-ra...
- spremenilo: Hypathia ()
GrX ::
Zakaj šele zdaj? Pred tedni sem na redditu zasledil, da je bila bila neka pedo spletna stran dostopna kar na surface webu. Folk je baje masovno prijavljal spletno stran ustreznim institucijam, pa se ni zgodilo nič.
Če greš malo raziskovat v pedo networks rabbit hole (primer Dutroux in še nešteto dokumentarcev), je hitro jasno zakaj.
Scaramouche1 je izjavil:
Zenske znajo biti nadlezne. Velikokrat mislijo, da mora biti tip vedno za. Zal je veliko oseb, ki izkrivlja podatke in se laze, da so zenske vedno zgolj nedolzne zrtve.
- spremenilo: tikitoki ()
Hypathia ::
Ne, nihče ne trdi, da so ženske VEDNO žrtve, vendar raziskave konstantno potrjujejo, da večinoma so, v veliko večji meri kot moški.
Raziskave kazejo, da ste zenske pri nasilju v druzini pomembni akterji. Vsaj novejse vecje razisakve. Vidim, da imas tezave s sprejemanjem rezultatov, ki se ne skladajo s tvojo ideologijo.
Sicer pa si navajala trditve, ki jih na tem forumu objavljeni podatki ne podpirajo. Imas link, kjer so objavljeni podatki, ki podpirajo, da je raziskava potrdila tvoje trditve?
Hypathia ::
Ne, kredibilne raziskave tega definitivno ne kažejo. Link sem napisala, zadnja raziskava pa še enkrat več potrjuje tisto, kar že dolgo tukaj trdim, da je večina žrtev spolnega nasilja ženskega spola, večina storilcev pa moškega spola.
globoko grlo ::
Sej to je verjetn res tko, raziskave gor al pa dol.
Me pa zanima kako to, da vecina nas sploh ne bi prepoznala spolnega nasilja?
Tudi to je pokazala ta linkana raziskava.
Slopek ::
globoko grlo je izjavil:
Verjetno je med temi dosti teh, ki so to počeli. Itak je pa vse in your face, samo nočeš videt ;)
Čeprav tudi sam ne morem verjet, da glede na te podatke, verjetno tudi poznam kakšnega izprijenca. Tudi tukaj je verjetno kakšen ;)
Btw, z ženo gledava GoT in nisem mogel verjeti, kolko pedo in drugih otroku prijaznih scen in diaologov je notri. Pa ne mislim na klanje in veliko golote in sexa. Ampak vse navadn.
- spremenilo: Slopek ()
globoko grlo ::
Sem mal narobe postavil vprašanje, zgleda.
Zanima me, kako je možno, da velika večia od nas sploh ne bi prepoznala spolnega nasilja. Če je vsak 5ti podvržen spolnemu nasilju oz. zlorabi, pol je tega velik.
Mogoče bi se moralo o tem veliko več govoriti in opozarjati?
Tu objavljeni rezultati zadnje raziskave ne potrjujejo tvojih besed. Link Al pa nehaj s propagando.
Hypathia ::
Nesposobnež, vse ti je treba k r*ti prinest. https://www.gov.si/assets/ministrstva/M...
87% storilcev je moškega spola.
Raziskava ne trdi tega. Večina bi prepoznala. Sicer majhna, a se vedno večina. Vsaj ne tu objavljeni izsledki. Manjši del se pač ne strinja z vsemi definicijami, ali ne poznajo vseh oblik, in konec koncev ne vem zakaj bi se. Nekateri ljudje hodijo na nudistični plaže, če sedaj puritanc reče, da to ni koser, je to stvar družbenih norm in ni naravni zakon.
Včasih so tud žensko ubil, če je varala. Norme se spreminjajo.
Bel tekst na belem ozadju. Ni čudno, da folk ne prebere.
Tej številki bom bolj zaupal, ko ne bo dvojni meril v smislu. Kak car je tist fant, ker je že imel odnose, četudi s starejso, ker to vpliva na percepcijo in rezultate takšnih raziskav. Kak naj tip ve, da je bil zlorabljen, če mu družba vbija v glavo dvojna merila.
globoko grlo ::
Čak, lohka, da se narobe spomnim, a niso rekl v TV prispevku, da cca 70% ljudi ne bi prepoznalo spolnega nasilja?
Tko sem si jest zapomnu, lohka, da sm kj pomešal.
V tej luči sem spraševal kako je možno, da 70% folka ne prepozna spolnega nasilja.
Nej me kdo poprav, če se komu da.
Hypathia ::
Ne 70% ampak 47%, kar je seveda še vedno veliko, vzroki pa tabuji, stigma, pomanjkanje empatije...
"Hkrati skoraj polovica oziroma 47 % anketirancev ne bi prepoznala znakov zlorabe,..."
KG-348 ::
Če greš brat knjigo boš presenečen ugotovil da je bila Daenerys stara 13 ko jo je Drogo...
Naslov teme bi moral biti: masovne kastracije pedofilov po svetu.
To je edina (pametna) rešitev.
Vse ostalo je žalitev za vsakega otroka, ki je bil kdaj koli zlorabljen.
Slopek ::
@Shields, sploh ne bi bil.presenečen. Kako le? Videl sem hujše stvari. Tip s haremom hčera, vnukinj, pravnukinj. Younger boys, so velikokrat omenjeni v zelo kočljivem kontekstu, itd. Ni, da ni. Indoktrinacija pa to. Navadn. So že včasih tako.
Sicer sem za to, da bi imeli otroke prej, ne tako, kot zdaj sistem narekuje, da oba najprej karieri, pol pri 40ih pa bejbija. To, zame nikakor ni natural. Seveda pa to prikazovanje, kako je treba deklico poročiti takoj, ko je po naravnih zakonih postala ženska, sploh ni normal in ni pot v boljši jutri.
Sistem je v zadnjih 30letih, tolikokrat zamajal družbo in jo vseskozi kar odkrito vodil po napačni poti, da...... Da je temu tako, ne gre oporekati sploh. Smo v katastrofalnih časih, kar je tudi odraz napisanega. Malo me je odneslo. Pedofilije, pa se ne bomo rešili z nekimi "masovnimi aretacijami". Vse je lari-fari. In your face. Ve se, da se nad otroci naslajajo najbogatejš, najvplivnejši. Vse drugo, so pravljice. Če bi bilo drugače, bi bilo drugače.
globoko grlo ::
Sej to sploh ne bo več problem. Ta mladi se itak ne bojo več družil, ker bo totalna prepoved stika. Otroke bojo pa naročal po pošti.
GabrieLeo ::
Bo kdo kaj rekel o tem kako Lisca pod skritimi html-ji na njihovi spletni strani skriva otroški yummy materijal?
Slopek ::
suzej ::
a dejansko yummy material (za pedofile)? al pač otroke v normalnem spodnjem perilu/kopalkah na neseksualen način?
Pridno umivajte roke, možgani so že oprani
- predlagalo izbris: Slopek ()
Slopek ::
Sori za izbris.
Deklice v samo spodnjem delu kopalk, zgoraj brez. Precej neokusno. To so umaknili, ampak še vedno je pa to, kar omenjaš skrito, in ni za širšo javnost.
Saj adrenochrome, je tudi možno naročiti ;)
GabrieLeo ::
Prijateljica je delala v poziciji v neki trgovini kjer je bilo treba nakazovati denar Lisci in vsi njihovi računi so se končali ali začeli s 666
Davčna se jim res začne s 666, pa en sam TRR vsebuje št. 666.
http://www.bizi.si/LISCA-D-O-O/
https://www.bizi.si/LISCA-D-O-O/seznam-...
vostok_1 ::
Haha, awesome.
Vrjetno bo tudi 6 ljudi max v trgovini at one time.
- spremenil: vostok_1 ()
ja, primarni trr.
No jaz kle neham ker sem lih lajf začel tako da lp
Mouthy Buddha je imel docu Pedogate, tudi na temo Lisce. Na koncu še bo res kaj na tem, lahko pa bi sicer šlo le za vdor v spletno stran.
ja, primarni trr.
Če ni naključje, potem tudi veze na DURS in bankah oz. v politiki (vprašanje, koliko so te cifre stare).
Nam, navadnim smrtnikom so te zadeve dodeljene in se ti le smejijo ali te čudno gledajo, če bi rad "customiziral" katero od teh številk.
- spremenil: c3p0 ()
Slopek ::
ja, primarni trr.
ja, primarni trr.
Pri Lisci, ne verjamem, da je šlo za vdor, ali podtikanje. Ko sem to preverjal, je bila zadeva še aktualna. Isti otroci so na fotkah tudi sicer, le fotke so druge ;)
Pedofilija je zakoreninjena globoko v vseh največjih institucijah in nihče se zares ne bori proti njej. Prej bi rekel, da nasprotno. Se normalizira in indoktrinacija je v teku.
Spock83 ::
Nizozemci baje sprejemaj zakonodajo, ki določa zakonsko lestvico še nižje za sexs z najstnico/najstnikom. Ne vem koliko je to res. Lahko kdo preveri?
Bolano.
Bolano.
svecka ::
normalizacija pedofilije se je že začela...začnemo lahko s filmom Cuties, nadaljujejmo z LGBT+ na vseh protestih zahtevajo dovoljene poroke z otroci (dosti slik na internetu), končamo pa itak z "kulturo" incesta, prisilnih porok, ki se dogajajo že desetletja v Slo med romskim prebivalstvom. Da ne govorim o muslimanskih prisilnih porokah, ki bodo kmalu v imenu "kulture" norma v EU.
V Afriki je pa prosto po prešernu možno kupovanje deklic zjutraj na tržnicah v nekaterih afriških državah.
- spremenil: svecka ()
Hypathia ::
FormerUser je izjavil:
Še eden od razlogov za porast števila pedofilov:
Norfolk Police Chief Constable Simon Bailey, the national police lead for child protection, revealed the UK is the third biggest consumer of online child sexual abuse in an interview with the Internet Watch Foundation. Some young men have begun to 'get their kicks' from child abuse imagery after becoming 'desensitised' to legal pornography, he said. The chief constable told the IWF: 'What we are seeing is a new group of young men aged between 18 and 26 who have been brought up on a staple diet of going to visit Pornhub and sites like that.'They get to the point where there's no pornographic material that is stimulating them so then they start to explore what child abuse imagery might look like. 'They start getting their kicks from that.'
https://metro.co.uk/2020/04/13/rise-pae...
Še en strokovnjak je spregovoril o očitni povezavi med gledanjem pornografije in zlorabo otrok:
How extreme porn has become a gateway drug into child abuse. Mainstream pornography sites are ‘changing what is normal’, warns child abuse expert Michael Sheath.https://www.theguardian.com/global-deve...
Over the years he has watched as the profile of the individuals appearing before him has changed, a change he sees as closely linked to the way in which some men react to watching extreme pornography at a young age.
“My earliest clients were child molesters. They tended to have been beaten, abused or have some sort of dysfunction. I’ve found in the last 10 years that increasingly people who view child sex abuse material don’t seem to have that history. They are mundane, ordinary people from all walks of life.”
| » | Nizozemski raziskovalci z virtualno deklico odkrili več tisoč spletnih pedofilov (strani: 1 2 3 4 )Oddelek: Novice / Varnost | 73212 (66545) | imagodei |
| » | Otroška pornografija (strani: 1 2 )Oddelek: Problemi človeštva | 16052 (14492) | jype |
| » | Anonymous se je lotil strani z otroško pornografijo (strani: 1 2 3 )Oddelek: Novice / Varnost | 56201 (50280) | Gregor P |
