Nov IQ Test na emode.com
undefined ::
http://www.emode.com/tests/superiq/
Your thinking style is Visual Linguist.
Visual Linguists know what they know and don't particularly enjoy having to explain why or how.
Pa vaši rezultati? :)
DMouse ::
The way you think about things makes you a Numerical Logician. This means that you're exceptionally strong in mathematics and at using logic to solve problems — you have a way with numbers. But that's not all — compared to others you're very detail-oriented, highly organized, and good at understanding things on a complex and abstract level. You're also a quick study when it comes to learning new things or understanding new concepts.
How did we determine that your thinking style is that of a Numerical Logician? When we examined your test results further, we analyzed how you scored on 8 dimensions of intelligence: spatial, organizational, abstract reasoning, logical, mechanical, verbal, visual and numerical. The 3 dimensions you scored highest on combine to make you a Numerical Logician. Only 6 out of 1,000 people have this rare combination of abilities.
Ni slabo, a vseeno ne dovolj dobro da bi ostal na FMF :|
jetam ::
jetam, your Super IQ score is 103
The way you think about things makes you an Intuitive Interpreter. This means you are a highly conceptual thinker.
in seveda: Only 6 out of 1,000 people have this rare combination of abilities.
bulsit
Error on line: Object of type SIGNATURE expected
Red_Mamba ::
David, your Super IQ score is 120
evo se še jst pohvalim :D
ank ::
Andrej, your Super IQ score is 113
DMouse ::
Aja, če se vam gre sam za številke bi pa tko rekl :)
141
  • spremenil: DMouse ()
LoneWolf ::
LoneWolf, your Super IQ score is 131.
jeti51 ::
Ah če je pa to relevanten IQ test... brezveze.:) Me prav zanima, koliko je zgornja meja tega testa. IMO prenizka za nadpovprečno visoke IQ-je.:P Naloge so namreč preveč enostavne.
jRk0 ::
Lino, your Super IQ score is 131
The way you think about things makes you a Creative Theorist. This means you are a highly intelligent, complex person. You are able to process information of nearly every kind with ease, using both creativity and analysis to make sense of the world. Compared to others you also have a very rich imagination.
Gizm0 ::
The way you think about things makes you -.
How did we determine that your thinking style is that of -? When we examined your test results further, we analyzed how you scored on 8 dimensions of intelligence: spatial, organizational, abstract reasoning, logical, mechanical, verbal, visual and numerical. The 3 dimensions you scored highest on combine to make you -. Only 6 out of 1,000 people have this rare combination of abilities.
??? očitno sem - (karkol naj bi to pomenilo) :))
your Super IQ score is 147
Tic ::
110.
Daddy, daddy!!! I am DUM!:\
Dodatek: Tole 6 out of 1000 sem dobil tudi jaz - dobi usak.
persona civitas ;>
  • spremenil: Tic ()
Tic ::
Oke... potem pa sem sel nakljucno klikat razultate, pa sem dobil 89. Krneki :)
persona civitas ;>
DMouse ::
jeti51 se strinjam. Samo če smo že pri tem, v resnici noben IQ test ne more biti relevanten, ker je preveč stvari, ki vplivajo na rezultat. Med drugim:
koliko časa si ga reševal
koliko podobnih testov si že rešil
kako si spočit
koliko si površen, raztresen
na kakšni skupini ljudi so postavili skalo
kakšen tip testa je
Sam mislim da bi bilo potrebno naresti čimbolj splošen test, ne samo iz logičnega mišljenja, ampak iz vseh področij življenja. Iz logike, 2d predstave, 3d predstave, spomina (spomin je pomemben del inteligence, saj je tvoja reakcija na neko situacijo največkrat odvisna od podobnih situacij v preteklosti), medosebnih odnosov (čustvena inteligenca - žal težko izmeriti), sposobnost izražanja, kreativnost... Vprašanja bi morala biti združena po tipih, vsak tip vprašanj pa časovno omejen (tako da (skoraj) nihče ne bi prišel do konca). Na podlagi takih testov bi se podala splošna analiza osebnosti, ki bi ti dejansko povedala kakšen nekdo je, kako razmišlja, kako ustvarjalen je, na katerih področjih je uspešen in na katerih ne tako zelo.
andper ::
Creative Theorist. (125)
Kar pa v bistvu ne drži, namreč veljam za takega, ki nima kaj veliko domišljije, a test me prepričuje ravno nasprotno. Kr neki. |O
ank ::
Na tej strani vam hočejo prodati 37 strani dolgo poročilo o vašem IQ-ju.
Tisto kar pokaže (Creative Theorist in podobno) pa je samo primer od nekoga ki je ta test naredil pred vami.Torej če hočete vedeti morate kupiti ta report ali pa iti delati test nekam drugam>:D
Upam da je vsaj your Super IQ score is 113 pravilno (bi znalo bit):P
undefined ::
Ne drži. Kar ti napiše tebi, je sample samo o tebi. Tudi točke. Obsežnejši test pa je seveda možno naročit, to je vse. :)
attackiko ::
Attackiko, you got it all right. Congratulations, you are the smartest man we've ever tested. You're creative, smart, intelligent, witty and funny. 'nuff said.
undefined ::
Attackiko, kolk pa je to zneslo točk? :D
boom-bar ::
jej 106 pik
Buuuuuuuuuul shit
Legalizirajte mehke droge!!!
OrkAA ::
130 mam... tako kot na ostalih...
Super Sonic ::
When we examined your test results further, we analyzed how you scored on 8 dimensions of intelligence: spatial, organizational, abstract reasoning, logical, mechanical, verbal, visual and numerical. The 3 dimensions you scored highest on combine to make you an Information Organizer. Only 6 out of 1,000 people have this rare combination of abilities.
110
bah>:D
p.s.
buče nam prodajajo se mi zdi
]Fusion[ ::
mam 109 :8)
Kaj me zalijo s tem, ko pisejo da sem - ?;((
"I am not an animal! I am a human being! I... am... a man!" - John Merrick
jamiroq ::
141
The way you think about things makes you a Complex Intellectual. This means you are highly intelligent and have extraordinarily strong verbal and math skills. Compared to others you are a highly conceptual and complex thinker and are able to understand information in an abstract form. You also show great attention to detail. In fact, it's hard to find something you're not good at.
samo bolj ko gledam tisto stran bolj mi zgleda kot en fensi dating servis :-/
btw tole "Only 6 out of 1,000 people have this rare combination of abilities." se pa pri vsakemu ponovi :D
njok ::
2. Which of the images below is a perfect square?
F. None of above. :D
OZZY ::
hm... score 131
The way you think about things makes you an Intuitive Investigator. This means you have multiple talents and can do anything you set your mind to. You're able to detect numerical patterns easily and are able to grasp the true complexity of the world, both in its details and in a more abstract form. You've got a sharp logical mind and are adept at using words to get even a difficult point across. The combination of all these things makes you truly brilliant.
Zanimivo.
Go with the flow.
Primoz ::
Če slučajno rata komu pod 80 prilezt (moj rekord)... naj napiše natančne odgovore za tak izjemni dosežek (še vedno ste 6 of 1000) :)) Nagrada: slo-tech majica :) Če bo uspešnih več, dobi majico, tisti ki pride najnižje... v primeru več enakih rezultatov pa tisti, ki prvi pošlje rešitev.
There can be no real freedom without the freedom to fail.
  • spremenil: Primoz ()
jamiroq ::
nekako se mi zdi da je minimum 80... sem probal rešit vse napačno in mi je vrglo ven 80 (res pa je da se nisem kaj dosti trudil :D
Primoz ::
... , your Super IQ score is 80
Your overall intelligence quotient is the result of a scientifically-tested formula based on how many questions you answered correctly. But it's only part of what we learned about you from your answers on the test. We also determined the way you process information.
The way you think about things makes you an Information Organizer. This means you have an eye for detail. You can scan a page and find the one mistake on it. You're also able to organize things in a way that makes sense and arrange information so that it is easier to understand. This makes you a very valuable resource for others who aren't organized or who have trouble catching their own mistakes. It's often difficult for traditional intelligence tests to pick up your particular set of abilities because the talent of organizing information and spotting inconsistencies is much harder to measure than other abilities.
How did we determine that your thinking style is that of an Information Organizer? When we examined your test results further, we analyzed how you scored on 8 dimensions of intelligence: spatial, organizational, abstract reasoning, logical, mechanical, verbal, visual and numerical. The 3 dimensions you scored highest on combine to make you an Information Organizer. Only 6 out of 1,000 people have this rare combination of abilities.
Find out which 3 intelligence dimensions you scored the highest on and how your IQ score compares to others in your personalized, 31-page Super IQ Report. It's ready right now!
In to naj bi bilo najslabse mozno? :)
Matek ::
Mja, zdejle sm šou odgovarjat čist v 3 piskre marmelade, pa sm dobu 80, bomo vidl če bo kdo manj, možno da je to kak limit...
A
Marshall
95
They are the same size
"22
It's impossible to know
Motivating
Worbs are six times as long as Marts
They are the same price
A
Kirkwood Kensington Kempthorn Kentfield
C
Flamboyant
A
32
Nose Hair Heart Head
The back wheel
Bold
C
Nail, fish, cat - Pet, dog, tool, hammer
B
She liked red flowers less than orange flowers
Yellow
10
A
Wish, look - Search, hope
3
Picturesque
A
300
Book 3 should be on the bottom, book 2 on the top.
8,382,311,119
7/2
B
Wichenhausingtonshire
2
Moderate
10
1 mile
0
Pulley B
155
16 miles
2
The reds have beaten both the greens and the blues -> my favourite :D
All Laps are Loops
The teeter-totter won't move
Silly
15
No, 80 IQ.
EDIT: Mja, kr vzpodbudno, glede na to da sm odgovarjal kot ena blond tajnica. Sm pa dobu isto, Information organizer.
Do i get the T-Shirt? :D
  • spremenil: Matek ()
undefined ::
LOL! Se vidi, da so nižji rezultati prirejeni, le zato, da bi dobili več članov, ki bi kupilo detaljni test. Ne dokazuje pa to tega, da so višji IQ rezultati nekorektni. Razen tistih 6 of 1000 izpadov, seveda. :)
Primoz ::
Majice so samo za ljudi z manj kot 80 :)) Posebna kategorija ljudi (poglejte v kaksno knjigo, kako se loči med idioti, debili, imbecili... )
vasquez ::
80 pik ti dajo že zato, ker si se prebil do konca testa :D
undefined ::
Ja. Že to je znanje, da se priklopiš na net, greš na web, se prijaviš in uspešno prideš do zadnje strani testa... to že šteje za 80 pik. Bush verjetno kaj takega komaj obvlada, al pa še to ne. ;)
VuLc4n0 ::
Jaz sploh nič nisem bral samo klikal sem in pove mi da je moj iq 94. :D
http://christinalake.cjb.net
Aspie test (strani: 1 2 )
6216884 (11028) Mavrik
personality disorder test (strani: 1 2 )
609987 (2062) mtosev
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820267 (17107) arrigo
Encarta prek MSNja (strani: 1 2 )
Oddelek: Novice / --Nerazporejeno--
8412988 (10472) Dragi
IQ test
294043 (3198) _marko
